NOW FOR SOMETHING DIFFERENT
Discussion in 'Other Motorcycles' started by wizard, Jan 7, 2012.
  1. mook1al
    mook1al Member
    Talladega, AL
    Fantastic work Wiz. Coming along quite nicely.
  2. wizard
    Decals......[​IMG][​IMG]
  3. XJPilot
    XJPilot Member
    Sarnia, ON
    Did you recover the seat yourself or do you "have a guy" for that as well? :p
  4. wizard
    Neither in this inst', Pilot, I have got 'a guy' but this one I scored off the 'bay' & it's real leather.
  5. bigfitz52
    We need to talk about SR exhaust systems and "burping" the oil filter. I'll PM you over the weekend.
  6. wizard
    Conversation appreciated, Fitz, I have 'bled' the oil filter.
  7. bigfitz52
    Gotcha; wasn't sure you picked up on that.
  8. Alive
    Alive Active Member
    Queensland, Australia
    So when's it going to be ready for the ride to Brisbane? :)
  9. wizard
    I'm rebuilding the carb, Al, with all new parts, I want it to start effortlessly, then there is a bunch of chroming to be done. How far is it to QLD, 3000 clicks ? Jetstar might be the best option. Wiz.
  10. Alive
    Alive Active Member
    But they're the competition :)
    Scored a job with an Airline but got no bike yet… It’s driving me nuts, 2 months without a bike and I’m going insane :p
  11. SecaMaverick
    SecaMaverick Active Member
    Northeast Ohio
    Wiz, I wish I had your time to work on bikes (I think).
    Beautiful work, as always.
  12. shangovi
    shangovi Member
    Burtonsville MD
    beeeutiful!!!great work can't wait t see the finished project...
  13. wizard
  14. Polock
  15. wizard
    Is that damm good, or damm bad ?
  16. Polock
    that would be damm nice. you have to get some white gloves to put that stuff on with and clean your wrenches
  17. iwingameover
    iwingameover Active Member
    That is a lot of shine!
  18. wizard
    Yeh, the old bike is pretty dull without it.
  19. mook1al
    mook1al Member
    Talladega, AL
    Is that the original exhaust that was rechromed?
  20. wizard
    Sure is mook.
  21. mook1al
    mook1al Member
    Talladega, AL
    Wow! That turned out really good.
  22. wizard
    Almost there, need grips, mirrors & the bracket that holds the front hydro' line (chrome guy lost it, but has now found it)[​IMG][​IMG][​IMG][​IMG]
  23. gunnabuild1
    gunnabuild1 Member
    Nice,once again.
  24. Ground-Hugger
    Ground-Hugger Member
    Near Port Dover Ontario
    WOW!!! Nice!! Someday I'd like to do that to my XJ. We are building a lift like yours. It is mostly done just need my son to bring it from his place to mine so I can finish it.
  25. wizard
    Have you got ant pictures of your bike lift ?
  26. tskaz
    tskaz Active Member
    Saint Louis, Michigan
    Nice work as usual Wiz
  27. Ground-Hugger
    Its not finished yet wizard, but I do have some of it assembled bare bone. I should have used counter sunk bolts on the parts that move but couldn't find any in the shop.
    My son is a member of the engineer corp in the Canadian Forces at CFB Trenton. We went over to the base shop he works in on a Saturday and built it there. I had to supply my own steel. The stuff they had was to light.
    I'll post what I have as soon as I transfer them the the computer.
  28. wizard
    Yeh, I used 10mm s/s c/s bolts on the inside, what sort of winch are you using ? If I was starting again I'd pull out for an electric one. Don't forget it will probably need a little assistance, at the back end, just to get it off the horizontal.
  29. mtnbikecrazy55
    Nice work as always wiz!
  30. Ground-Hugger
    Wiz I'm waiting for when they go on sale. I'll get one then. I need to do more work on it as I said all I have done is put the frame together. Here's a couple pic of what I have got so far.
    That's my dog Roxy, aka Killer, checking out the stand. I need to put tabs for tie downs on it and it needs wheels. When I get it home I'll put a front wheel guide/clamp on it. I'm thinking of making it adjustable for different width tires. Also I'm going to put a metal bar from the winch mount down to the bottom angle bar for some added strength. And I'll replace the bolts with some cs ones as soon as I can! We used lock nuts on the bolts.
    What type of wheels did you use Wiz? My 73 Suzuki GT750K will be living on the stand for the next year. I figure it will take that long to finish it.
  31. wizard
    The wheels are about 65mm dia, neoprene, with metal hubs, about 150 kg rating, they have a flat plate for welding & they turn through 360*, I had to add a short piece of angle to the outriggers so they could spin unobstructed.
  32. Ground-Hugger
    OK thanks Wiz. My sons Warrant is also a biker, he belongs to the Cav Veterans Group in Trenton, so he was quite interested on how it works.
    So once I get it home I'll do the extras that need to be done. Meanwhile I'll hunt up some wheels.
  33. adrian1
    adrian1 Active Member
    Very nice.....can you post the name of your chrome plater? Chroming was expensive last time I looked.....they were also reluctant to tackle mufflers as it contaminates their tank?
  34. wizard
    Yeh, my guy remarked on the dirty exhaust, but didn't jib.
    I will PM you with his contact details. Wiz.
  35. wizard
    FINISHED....[​IMG][​IMG][​IMG][​IMG][​IMG][​IMG]
  36. ken007
    ken007 Member
    Brisbane, Australia
    well done, looks mint, are you making room for this one ?
  37. wizard
    No, I think I've moved on from the kick start, too much of a PITA.
  38. jmilliken
    jmilliken Well-Known Member
    Dillsburg, PA
    Wow. Fantastic job!
  39. mtnbikecrazy55
  40. RookieRider
    RookieRider Member
    Gatineau, QC
    That bike probably hasn't looked that good since beeing packed in a crate 32 years ago....
    that is amazing.
  41. xj650ss
    xj650ss Member
    Calgary, Alberta
    Well done as always Wiz I'm sure someone will be proud to show that one off for you!!
    SS
  42. pillowmaster50
    pillowmaster50 Member
  43. Alive
    Alive Active Member
    Another fine restoration Wiz... What's next? :)
