  1. randomchad
    randomchad New Member
    Massanutten VA
    New shorty exhaust and painted the collector black. Also installed a black billet side mount license plate with lights. And painted the rear peg brackets flat black.
  2. z32800
    z32800 Member
    Wellington New Zealand
    Replaced my front brake line that my dog chewed; bleed the brakes.
  3. Thrasher
    Thrasher Member
    Oak Ridge, Tennessee
    Re installed my steering damper, made a heel guard for my rear sets and installed a new shifter rubber.
  4. MarkV
    MarkV Member
    Vermont
    put bike back together after new paint, dusted her down. Only wish it wasnt pouring out.
  5. 82NewToMe
    82NewToMe Member
    Harrisonburg, VA USA
    Finished up the fuel sight gauge and remounted the tank, filled brakes with fluid and did a bleed, will bleed again later today. I'll also be filling the crank case with oil, bike has been dry for a year while I've been working on it.
      File size:
      82.1 KB
      9,036
  6. kleraudio
    kleraudio Member
    Erie, CO
    Went on a long group ride into the canyons. The second time I've been in the twisties, and it was a BLAST!!
  7. bobcat5540
    bobcat5540 Member
    Mount Sidney,Virginia
    Looks good man. I like the Satin Black as well.Did you do it yourself or have someone spray it professionally ?
  8. 82NewToMe
    82NewToMe Member
    Myself, epoxy paint.
  9. Kwiski
    Kwiski Member
    High Desert CA.
    Just checked tires & fluids to get ready for a weeks ride back & forth to work. 94,000 miles & still ticking.
  10. xjdaver
    xjdaver Member
    Medford, Wisconsin
    Gave the lower frame the best $7 paint job money can buy. Installed new rear brake pads. Found problem and solution to top steering bearing race tallness issue (allballs). Installed forks and found huge error in tightening torque in Clymers compared to Yamaha manual. Front wheel installed. Pumped out front brake piston for cleaning/rebuild. Installed valve cover and new gasket. Ordered a new chain.
  11. dowski68
    dowski68 Well-Known Member
    Medford, Oregon
    Did what I do every work day, ride with a smile. I noticed that another member has 94,000 miles on his XJ. I feel pretty confident that mine will last as long. I am at 57,000 on my 86 xj700x.
  12. RickCoMatic
    6:00 AM
    Pre-flight check:
    Oil ... OK
    Tires/Pressures ... OK
    Brake Window ... Clean / Full
    Rear Brake ... Adjusted.
    Fuel Level ... Fail. Need to gas-up.
    Wind Screen / Sport Fairing ... Windex / Secure.
    No Leaks detected.
    Lubed Side-Stand Pivot.
    Added one Level of tighter Pre-load to Rear Shocks.
  13. xjdaver
    xjdaver Member
    Medford, Wisconsin
    Clean out the front caliper for new seal dust wiper. Is it my imagination or does this need to be done often on the 550s?
  14. Polock
  15. luvmy40
    luvmy40 Member
    Y-Town, OH
    I finished up the install of a stock head light assy. and front indicators after removing a Vetter fairing.
    Anyone have a mounting bracket for the aux. lamp laying around?
  16. MidniteMax
    MidniteMax Member
    Liberty SC
    Installed euro-bars.
    Took a short 20 mile ride and really liked the new seating position.
    Bike seems a lot sportier and takes a bit of the weight off my tailbone. Probably can ride more comfortably for a longer period now.
    Not sure if I exactly like the bends of euros yet. I think I may prefer some SR500 bars.
  17. z32800
    z32800 Member
    Sent the lids off the top of my Carbies in to be re-chromed (had a spare set so can still ride)
  18. sanglasmick
    sanglasmick Member
    Wexford, Ireland
    Checked my rear brake shoes for de-lamination!
    Changed my final drive oil while I was at it.
    Replaced my standard H4 headlight bulb with high performance bulb 50% brighter according to the pack?
    Replaced my speedo backlight bulb. :idea:
  19. randomchad
    Massanutten VA
    Installed some black on black 2.5" guages. They look pretty good, but I need to reroute some wiring to make it look nicer. Also, I overlooked the neutral light and its backwards (on when in gear, off when in neutral). But it works!
  20. ElkHavenSeca
    ElkHavenSeca Active Member
    Sedro woolley wa
    received more parts in the mail for both seca's put them away and rode my red seca 125 miles down the old country roads here . Winter is for working on bikes . Summer for riding !!! glad i have 2 bikes so i can work on one ride the other
  21. Stumplifter
    Stumplifter Well-Known Member
    near Irma, WI
    Put on a set of Progressive Suspension shocks and springs.
    This went a lot easier than I thought - I don't own a 'spring compression' tool,
    But sometimes I can be a pretty creative shade tree mechanic. :)
  22. xjdaver
    xjdaver Member
    Medford, Wisconsin
    Put the engine back in the frame. Good times! Still a long way to go.
  23. moellear
    moellear Member
    Lima, Ohio
    replaced tachometer oil seals, replaced foot shift rubber pad, and replaced rusty front brake screw all on the 550. plan to ride another 300 miles on my extended weekend starting tomorrow evening!
  24. PilotSmack
    PilotSmack Active Member
    Calgary, Canada
    New brake pedal finally arrived, so I cleaned up the spindle splines and attached the new pedal, and adjusted the rear brakes. Fun times!!
  25. maverickbr77
    maverickbr77 Member
    Lowville, New York
    rebuilt clutch and starter motor.
  26. slackard
    slackard Active Member
    Earth, Terran System
    removed more rat's nest wiring around the tail light. PO had upgraded to a glue-in LED tail light but left a shiton of electrical tape and nonsense, all hanging well below the fender and looking like poop.
    solved today with some nice male/female crimp-on connectors in place of black tape and rats nest...
    seriously.. some people's kids, i tell you what!
  27. xjdaver
    xjdaver Member
    Medford, Wisconsin
    Torqued engine mounts to spec. Torqued front axle and pinch bolts to spec. Installd rear brake linkage and swing arm. Made a parts list...
  28. z32800
    z32800 Member
    Fitted my newly chromed Carby lids, just the XJ750 Decals to go now on the side covers and she's finished.
  29. xjdaver
    xjdaver Member
    Medford, Wisconsin
    Did a figurative forehead smack when I realized I installed the engine before installing the airbox. Removed the 2 right intake manifolds and managed to squeeze the box through. Luckily I have 4 manifold gaskets in stock. Installed new oil filter and O-rings. Ordered more parts and tools.
  30. xjdaver
    xjdaver Member
    Medford, Wisconsin
    Reconnected all the wires I disconnected to remove engine. More forehead slapping: Realized I didn't put oil in the filter housing to prime the pump on start-up (the manual says so anyway). Cleaned the underside of the gas tank. I'm really looking forward to the performance enhancement of that last one.
  31. Thrasher
    Thrasher Member
    Went for a nice ride today, to stretch the Seca's legs.
  32. 82NewToMe
    82NewToMe Member
    Replaced fork seals and dust seals.
  33. z32800
    z32800 Member
    Took it for a ride; summer is on its way to NZ
  34. DaveT174
    DaveT174 Member
    Onslow, IA
    They're coated in finger prints and the lighting in my basement really sucks . They look a lot better in the sun, not quite chrome but pretty close.
    Sometimes I think I could use a girlfriend 8O
  35. sektorgaz
    sektorgaz Member
    Western MA, United States
    Yeah, you might be right! :)
    Looks great. What method did you use to buff them out like that? Polishing wheel and elbow grease?
  36. fullysika
    fullysika New Member
    australia
    Broke the thred off the no2 cylinder sparkplug on my 85 xj900 :oops:
    looks like its time to do a top end revamp
  37. ElkHavenSeca
    Sedro woolley wa
    Sorry fully , thats a bad break
  38. DaveT174
    DaveT174 Member
    Onslow, IA
    Sektorgaz, I used a dremel with soft felt buffing wheels and three different compounds. I've been working on them a little bit each night after work. It's one of those projects you can do while relaxing in front of the TV.
  39. sektorgaz
    sektorgaz Member
    Look into a helicoil or marine-tex gray epoxy and re-tap.
  40. PilotSmack
    Calgary, Canada
    Still waiting for the guys to finish paving the driveway, so I just ran her in the garage for a bit, lubed the chain and checked the oil level. Been the longest 2 weeks of my life!
  41. bobcat5540
    bobcat5540 Member
    New placement of Speedometer, wanted to keep the front clean. I haven't rode tested it yet but adequately visible from seat.
  42. xjdaver
    xjdaver Member
    Medford, Wisconsin
    I rode it for the first time in over 2 years. Over the previous few months:
    Split the cases and fixed a shifting problem (long story)
    Replaced the forks
    New brake pads and shoes
    Bled brake lines
    New allballs headset
    Upgrade to needle bearings in the swing arm
    New shocks
    New chain
    New plugs
    New air filter
    Adjusted valves
    touched-up frame paint
    Replaced fuel line, filter and valve
    Cleaned carbs
    Synced carbs - morgan cabtune
    Set mixture - colortune
    synced carbs again
    It was a great ride!
  43. z32800
    z32800 Member
    Inspired by DaveT174; polished my carbs with a Dremel which look a lot better with the new paint job. Look out the rest of the oxidised alloy!
  44. pickax
    pickax Member
    Kennewick WA
    wax on....wax off. Looks deep black in most lighting; but when the sun hits just right - POP goes the blue pearl. October 6th and still warm and sunny; off to ride
  45. FtUp
    FtUp Well-Known Member
    pacific northwest
    just installed my new rear brake shoes and did a little more tuning. now it jumps to life with a snap of the throttle, no hesitation at all!
    CN
  46. randomchad
    Massanutten VA
    I installed new master cylinder while I slowly rebuild my stock one and installed new brake lines too. It was easier than the troubling posts ive read about how long they take to bleed. Maybe it was because of the different master cylinder, either way not a bad or time consuming job.
  47. k-moe
    I did the final (temporary, I plan on a full re-paint next winter)) paint on the front fender, following the repair of a minor crack at the leading edge. I picked the fender up off of the bench to carry it over to the bike for re-instillation, and saw.........another crack along the trailing edge [​IMG]
    The PO had craftily hidden both cracks with body puddy, and hidden the puddy under some very nice paint. :roll:
  48. z32800
    z32800 Member
    Took it out of the garage and gave it a polish; getting it ready for the upcoming track day.
  49. 750E-II_29Rbloke
    South Cheshire, UK
    Bought a 31A replacement frame (yesterday evening)
    If the rain stops I'll be stripping it into big chunks later, front end, back end etc & bringing the bits indoors so they can be stripped/cleaned/refurbished as required ready for the re-incarnation...
  50. jmilliken
    jmilliken Well-Known Member
    Dillsburg, PA
    Glad to hear 750E!
