Basic YICS question
Discussion in 'XJ Technical Chat' started by peganit2, May 26, 2014.
  1. peganit2
    peganit2 Member
    Davison Mi
    How can you tell by looking at an engine if it has YICS? I mean aside from the obvious "YICS" markings on the side plate. (My side plates sure don't look like they belonged to this engine model.)
  2. k-moe
    YICS engines have a bolt at the rear of the head, below the head gasket. You can also see the YICS passages cast into the back of the head.
  3. peganit2
    peganit2 Member
    Davison Mi
    That's EXACTLY what I needed.
    Thanks again K-moe.
  4. bigfitz52
    Except the bolt you have labeled "oil pressure plug" isn't.
    I'm pretty sure that's the retainer bolt for the bottom cam chain guide mount.
    "YICS" is also cast into the valve cover. If the valve cover just says "Yamaha" it's not a YICS motor. (The valve covers aren't interchangeable.)
  5. k-moe
    That pic was borrowed from the XS11 forum, and is of an XJ1100. The XS11 uses that hole for the oil pressure sending unit. That plug (and the oil pipe next to it) does not exist on the XJ650/750.
    http://www.xs11.com/forum/showthread.php?t=36652
  6. Bargomer
    Bargomer Member
    Southern California
    That's one sexy valve cover!
  7. Polock
    that softsoap is good stuff
  8. ColoradoDan
    ColoradoDan Active Member
    Longmont, CO
    priceless :lol:
    I get those sponges at costco, 18 pack for like 8 bucks
  9. peganit2
    peganit2 Member
    Davison Mi
    That is real perty cam cover for sure!! Hope my NON YICS :( cover turns out as well.
    For some reason it had a "YICS" engine side cover on it. :? I suspect crash repair.
    The YICS cover didn't fit quite right BTW.
  10. bigfitz52
