Polishing Your Aluminum Parts
Discussion in 'XJ DIY How-To Videos' started by XJOE550, Nov 24, 2014.
  1. XJOE550
    XJOE550 Active Member
    Inverness, FL
    Here a set of four clips I did on polishing aluminum. Hope it will give some encouragement to anybody out there thinking about adding some bling to their XJ.
    DarbyC, jsmith800, Rusty81 and 4 others like this.
  2. Ted
    Ted Member
    Sioux Falls, SD
    Holy Christ - I need a buffing wheel STAT! :)
    Nice work man.
  3. XJOE550
    Inverness, FL
    Finished the forks the other day.
    Mark A. Miller, DarbyC, Nikos and 4 others like this.
  4. FtUp
    FtUp Well-Known Member
    pacific northwest
    those look awesome! much better than the ratty old black finished ones.
    CN
    Nikos likes this.
  5. DarinAdkins
    DarinAdkins Member
    Dallas,TX
    Awesome bro this vid helped me a lot
  6. Skwerly
    Skwerly Member
    Yucaipa, CA
    Heck yea, good work!
  7. Polock
    What's your plans for the bolts that go back in all those shiny parts?
  8. XJOE550
    Inverness, FL
    Usually, I try to polish them, but some start rusting again after time. I guess any anti-rust coating is compromised by that point. I prefer purchasing stainless steel versions from Fastenal. I could get SS from Ace but the cost runs two to three times as much from them. On the larger bolts, the cost difference can really add up.
  9. Polock
    i do Mcmaster-Carr for SS bolts. Caswell's has "plug-n-plate" kits i used on some of the big stuff, you can use it after the part is on the bike
    dirtmax and FtUp like this.
  10. cutlass79500
    lawrenceville georgia
    Good job people do not realize how easy it is with a bench buffer. You even have the same harbor freight one that i do. They are tough. I recently bought the big 3/4 hp model. I use both since your not suppose to use different compounds on the same bonnet. Mothers works good. I like the shine on purple metal polish its seems brighter. And i use the buffer with a new pad to take it off its a liquid but i use mothers first. As long as you keep them out of the rain and wipe the aluminum off after washing you can get away with a quick hand polish once a year or so. Here is a before and after with a few coats of metal polish 001 (9).JPG
    dirtmax, Chance and XJOE550 like this.
  11. XJOE550
    Inverness, FL
    Wow, I just looked this product up. Not cheap. But I agree with you on the Mother's polish, It actually does take a tad of the shine away after I finish buffing. But, I always like to finish off with the Mother's since it has a wax that will add longevity to the shine. Not sure what kind of wax it contains, but I know that silicone type waxes will dull the shine on aluminum. Normally, I only have to hit a piece with Mother's once a year after the initial buffing. But thanks for the tip, I may give Purple metal polish a try. One thing I may mention, with the proper cutting and polishing compounds, I have seen people bypass the sanding process and solely use the buffing wheel with just as good results. I imagine they can do this as long as there are no scratches/imprefections in the part.
    Toomanybikes likes this.
  12. cutlass79500
    Chance and Kris Taylor like this.
  13. XJOE550
    Inverness, FL
    Nice! Do you know if it helps remove bluing from a header?
  14. Skwerly
    Skwerly Member
    Yucaipa, CA
    wooooow, that's insane!
  15. cutlass79500
    I don't know i can check this weekend . I like it a lot i should be their rep lol i use it after white ruge when i am buffing also it protects metal really good. But everyone is different this works well for me everyone has their favorites. Works great on stainless also this header is 18 years old with 22k miles 005.jpg
    Chance likes this.
  16. Tim morris
    Tim morris Active Member
    Hopatcong NJ 07843
    Love it thanks
  17. Chance
    Chance Member
    Rockland, Ontario, Canada
    Beautiful pieces I will remember to try this. like the zing it gives.
  18. Tomq
    Tomq Member
    New Zealand
    These look great, I was going to paint my covers but I just bought an old bench polisher so I can do this. How did you get into the little niggly bits, eg around the bolts etc, with the polisher or was there a bit of hand polishing involved too?
    Cheers!
  19. GoCrazy
    GoCrazy Member
    Poland
    Do you spray the covers with clear coat to project it from alu oxidation?
  20. XJ550H
    you can use a dremel to get the the hard to get spots.
    you can clear coat or wax
    DarbyC likes this.
  21. XJ550H
  22. XJOE550
    Inverness, FL
    IMHO, I wouldn't want to use clear coat. Too easy to maintain using a polisher/wax, like Mothers Aluminum Polish every 6 months or so by had. Main point to be aware of is not to use a silicon based wax. It will dull the newly buffed shine. Best to use a bees wax based wax. I think that is what the Mother's Aluminum polish contains along with the polishing component. The Mothers is the final step I use soley for its wax properties, since the part will already have the mirror shine after buffing. The Mothers polish/wax step will dull it just a tad. But hardly noticable. When doing a maintenance application every 6 months or so, you can always hit it wit a drill buffer after having done the hand polish/wax appliction. Keeps the look show quailty.
    DarbyC likes this.
  23. GoCrazy
    GoCrazy Member
    Poland
    That's a handy tip. I used to wash my rims with a common dish washing detergent once a week to keep it from oxidation. To maintain a glass shine I had to buff it once a month.
  24. Briefs1969
    Briefs1969 New Member
    Ireland
    XJOE550 and Franz like this.
  25. Briefs1969
    Ireland
    Thanks for the. But I am in trouble again I need air box boots or rubber a I am having no joy
  26. jsmith800
    jsmith800 New Member
    US
    great job XJOE550!
  27. dominicapavlova
    dominicapavlova New Member
    Norfolk UK
  28. dominicapavlova
    Norfolk UK
    Mothers ali polish works a treat.
