XJ 550 with GSXR750 front end
Discussion in 'XJ Modifications' started by Reed7742, Mar 19, 2016.
  1. Reed7742
    Reed7742 Member
    Mission Ks
    Hey All,
    Just figured that I'd post a few pics of my 550 with a gsxr front end on it. I found a complete front end, including triple, forks, wheel, brakes, and clipons for $180, so I figured, why the hell not. It was a pretty easy swap. I ended up going with a 04 636 clutch cable and it fits almost perfectly. The only part that I needed to buy were All Balls bearings for it.
    Dustin Trent, Franz, Jetfixer and 4 others like this.
  2. specialk
    specialk Active Member
    Ontario
    That's Fantastic! I'm definitely going to considering doing something like that to my xj550 as well. How does it handle/stop in comparison to the stock configuration? What year gixxer was it off of?
  3. k-moe
    Nice swap. I like that it just needed cables and headstock bearings to work.
  4. chacal
    Moar details, please!
  5. hogfiddles
    I'm sorry.... I'm just not seeing what's supposed to be so cool about a terribly mismatched from end.
    Brent NZ likes this.
  6. k-moe
    Fully adjustable forks. Compression, rebound, and spring preload, all without taking the forks apart. Perfect for club level racing.
    Reed7742 likes this.
  7. a100man
    a100man Well-Known Member
    Bedford, UK
    plus newer and likely more servicable parts, better brakes etc.. and it's fun.
  8. Jared
    Jared New Member
    Anoka, MN
    Im looking to do the same swap what was involved other that the obvious of buying forks and wheel and whatnot? Did you have to press your stem into the gsxr triple trees?
  9. Reed7742
    Reed7742 Member
    Mission Ks
    Hey,
    Sorry for the late reply. I posted this, got busy, and forgot about it lol. I THINK that it's from an '04 special edition. I was originally looking for a 98-99, as that is a pretty common swap, but I found this one super cheap and decided to jump on it. It handles fantastic. I can push corners a lot more aggressively than I could with the old setup. That being said, I really needed a new tire, so the increase in handling could be because of the new meaty rubber up front.
    The GSXR stem worked just fine. That's why I decided to jump on it. I did have to have the old GSXR bottom bearing pulled and the new All Balls needles pressed on, but that was like $20 at a local shop.
    With the new dual brakes, I can stand it on its nose. It is MUCH better than the stock setup.
  10. specialk
    Ontario
    Thanks for the response, it sounds like a worthwhile upgrade for the future. I'd probably try and put some clip on risers if I were to go this route though because the clip ons in your picture look really low
  11. a100man
    Bedford, UK
    So, something like this is a common swap for an XJ550 - I never knew that. Hmm that one's not too far from me...
  12. Reed7742
    Reed7742 Member
    Mission Ks
    It isn't horrible to ride, but I haven't had a chance to put any real miles on it. Everything has been <100 miles or so. I've thought about going with some aftermarket clipons that have a little bit of a riser on them, but 50mm clip ons are almost expensive as the whole swap was lol. I have rearsets sitting in my garage now, but I don't have the tools to machine a new bracket because I didn't like the position when they were on the passenger peg mounts. That would improve the actual riding position a lot and I'm not sure that I'll need risers if I can stretch out just a little bit.
    I'm not sure about that one. My forks are inverted, so it's different from those.
    http://www.allballsracing.com/index.php/forkconversion
    That is a fantastic tool to use to try and find a compatible swap. The main reason that I went with the one that I did was that the stem is the right length. Cognito Moto has some parts that can be used as well, and they'll machine you a stem/triples for whatever application that you might need.
  13. Reed7742
    Reed7742 Member
    Mission Ks
    One thing I should mention. The speedo sensor was moved from the front hub to a transmission on the year that the donor forks were from. I've been using a phone mount and GPS speedo and it seems to be working. If anyone knows of an inexpensive GPS speedo, please point me in that direction.
  14. a100man
    Bedford, UK
    Precisely this. Even if you swap stems to get the 'correct' length you can still be screwed by the thickness of the yokes/trees - ask me how I know ?
  15. chacal
    How do you know this? :)
  16. a100man
    Bedford, UK
    Well, I'm pleased you asked ;). Fitting a GS500 with a DR650 front end I figured stem swap would be the fix. BUT lower yoke/tree on DR650 is much thicker and as a result you get less stem protruding up into the headstock. The solution will be to disassemble what I have again then ream/mill/turn a recess/rebate into the bottom DR650 yoke/tree to 'raise up' the stem...
    But that means begging another go on a press and getting a machining favour sorted. Hence I'm back on the XJ...
  17. Reece
    Reece New Member
    Wollongong nsw australia
    Thats sweet looking ride you have there and in the process of doing the same with my xj900 with a zx6 front end but i would like to find somehow to keep the stock wheel.
  18. pygmy_goat_
    pygmy_goat_ Member
    Exeter, NH
    What are the rear shocks? Sorry if you've already answered that elsewhere.
  19. Reed7742
    Reed7742 Member
    Mission Ks
    They're eBay specials that I had a guy rebuild before I threw on. I would reckoned getting them rebuilt before throwing them on. They seem to work really well though.
  20. SlowSilver
    SlowSilver New Member
    Well this looks a little familiar, stumbled upon this today and decided to pull the trigger!
    jayrodoh likes this.
  21. 50gary
    50gary Active Member
    Saginaw, Mi. USA
    I think he meant Tapered roller bearings. Not, "All Balls needles pressed on, .." post #9
    I wonder what the ground clearance is? Higher, or likely lower? Also the wheelbase and rake will be different.
    Cheers, 50gary
  22. PavelK313
    PavelK313 Active Member
    Fairfield CA
    Nice USD conversion! Stock brakes on XJ are horrible so this is huge improvement.
  23. kerriskandiesinc
    NY
    Did you have to brace the standard XJ frame, or does it seem to cope with the added stresses??
    How is the rear...I see you have 'gas/remote reservoir rear shocks...??
  24. PavelK313
    Fairfield CA
    no need to brace anything. USD feels amazing on XJ
    kerriskandiesinc likes this.
  25. Cwjleaker
    Cwjleaker New Member
    France
    Bike looking well nice mate! Just had a question concerning your rear shocks, which ones are you running?
    Cheers!
  26. 50gary
    Saginaw, Mi. USA
    Modern cartridge forks actually work, I'm not being snide here, old damper rod forks are prehistoric by comparison, the modern wheel is lighter, the brakes are way more effective
    I would change the fork oil and brake pads during the install and stainless steel brake lines. Now match the rear wheel with a 17" (I'd look at the SV650 Suz.) the same spoke pattern as the front and go to matched radial tires. Done.
    Most all benefits of a modern bike with the character and simplicity of the vintage bike.
    Cheers, 50gary
  27. Dustin Trent
    Dustin Trent New Member
    Concord, North Carolina
  28. Dustin Trent
    Yo could you start a conversation with me I also have an xj550 and looking to do something similar to what you've done with yours if you don't mind helping out a little bit?
  29. Dustin Trent
    It looks great...
  30. 50gary
    Saginaw, Mi. USA
    My front end matches the rear end perfectly, it's the same wheel (Yamaha R1) as the front with a XJ hub for the shaft drive. Avatar pic. modern disc brake too.
    Cheers, 50gary
  31. 50gary
    Saginaw, Mi. USA
  32. Huntchuks
    Huntchuks Well-Known Member
    East Rochester, NY
    Nice Saturn V rocket nozzles look at the exhaust.
    Franz and chacal like this.
  33. 50gary
    Saginaw, Mi. USA
    Thanks, that was the inspiration, Saturn 5, Apollo 11. I'm thinking of making another set with the tips about
    1.5" longer so I can slash cut them at about 30* angle. Deadly.
    Cheers, 50gary
    Hambone2514 and Huntchuks like this.
  34. Kole Lester
    Kole Lester New Member
    PA, USA
    "Now match the rear wheel with a 17" (I'd look at the SV650 Suz.) the same spoke pattern as the front and go to matched radial tires. Done." Cheers, 50gary
    Do you have any more light to shed on this? I just finished my own fork swap, and want to swap the rear wheel for an SV650 one. Axle size is the same, but wheel offset and chain alignment are going to be an issue. Any info helps!
  35. Dustin Trent
    Hey man, love the bike. Do the forks need to be a certain year or type I would like to do this to mine I just completely rebuilt her, did a rectifier swap, new battery, new carb boots, and now looking to do some upgrades along with gas shocks and this fork conversion but I need a little help. Can I get a little more info on exactly which forks will fit and what is necessary?
