Compression Test XJ650
Discussion in 'XJ DIY How-To Videos' started by taptapindustries, May 19, 2017.
  1. taptapindustries
    taptapindustries Member
    maroubra
  2. taptapindustries
    maroubra
    compression test on my XJ650. hope this helps people out there and or at least entertains. :)
  3. XJ550H
    you would want to disconnect the TCI before starting your compression test.
  4. a100man
    a100man Well-Known Member
    Bedford, UK
    Why is that?
  5. Rooster53
    North, FL
    To protect the coils. Yamaha suggests grounding the spark plugs, but it is easier in most cases just to disconnect the TCI. If the spark plugs are not grounded or the TCI disconnected the voltage in the secondary of the ignition coil that normally builds to a predetermined level set by the spark plug gap will build to a higher level. As the voltage in the secondary builds above the design, it will arc across the wire enamel insulation of the secondary and find its way to ground resulting in damage to the coil.
  6. a100man
    Bedford, UK
    Makes sense - thanks.
  7. Wintersdark
    Wintersdark Well-Known Member
    Calgary, Alberta, Canada
    The entire electrical system is off - it's just an engine on my bench, and one in an otherwise stripped frame. So, no problem there!
  8. Wintersdark
    Thanks, good sir, that was exactly what i needed to see :)
  9. Wintersdark
    Quick question: the motors I need to test have neither carbs nor exhaust attached. I'd assume this shouldn't be a problem (you want wide open to test, hence wide open throttle, no?) But as neither intake nor exhaust are connected, just wanted to confirm that won't skew results.
  10. XJ550H
    test it as it is , it may give you better numbers then when assembled but it will still give you some insight as to the condition of the motor
    Wintersdark likes this.
