  1. dowski68
    dowski68 Well-Known Member
    Medford, Oregon
    All right 90 miles put on her. Just did an oil change and when I inspected the magnetic oil plug nothing on it :)
    Gazed at the oil pan containing the old oil and no sign of glittering metal pieces-Even Better.
    In retrospect the first oil change I my own opinion should be done with in 200 hundred miles. To remove all those small particles caused by the break in. Then again at 500 hundred just to make sure you got everything out of the engine.
    Here is a picture of the saddle bags I am thinking about buying for 75.00 any thoughts good bad ?
  2. dowski68
    Medford, Oregon
    This is just me in the middle of the outer hills enjoying the complete piece and quite.
    Dadoseven and Stumplifter like this.
  3. Wintersdark
    Wintersdark Well-Known Member
    Calgary, Alberta, Canada
    Hauled a 750 motor into my basement for some TLC. God damn those things are heavy. I'm too old for that stuff, and require medicinal beer to cover up the really sore back. One more to go downstairs tomorrow >.<
    I really wish I had a garage.
    dirtmax and Stumplifter like this.
  4. dowski68
    Medford, Oregon
    Maybe some block and tackle will work for you, like the ones they use for sailing ships. The more wheels the less physical force required ?
    Or a young kid around the neighborhood for an easy 20 bucks.
    Of course you can still have the medicinal beer measure.:)
    Stumplifter and Wintersdark like this.
  5. Ian Vanore
    Ian Vanore Member
    Philadelphia, PA
    dirtmax, Stumplifter, Timbox and 2 others like this.
  6. Wintersdark
    I was thinking of some kind of block and tackle setup, as I need to bring another motor down there once I get it out of the frame, and I'll need to bring the first back up once it's had it's TLC. However, I'm in a rental townhouse with an unfinished basement, I've no idea how I would set something like that up (no straight drop down available, just an extremely rickety 2x12 staircase).
    Heh... Turns out a 300 pound guy carrying a full motor is putting what may be too much load on 2x12's. There were some really alarming noises carrying it down. Maybe rig up some kind of sled. Hmm.
  7. dowski68
    Medford, Oregon
    sled sounds like a great idea. Plywood and a good rope should do the trick.
  8. dowski68
    Medford, Oregon
    Very nice work you have done there!
    Ian Vanore likes this.
  9. Dadoseven
    Dadoseven Active Member
    Omaha
    Reinstalled forks today after receiving dust seals. Thought I was just missing a pinch bolt on the triple tree bracket and had a replacement. Found out the original was sheared off inside. Tried an extractor without success. Now trying to soak in alum to dissolve it out. Arrgh. Another delay in getting things put back together.
  10. hogfiddles
    Take her out for dinner, and tell her it was paid for by some of the parts you sold off the bike.........how do you think I can keep 40+ bikes around!?!?!lol
    More bikes - more dinner dates;)
  11. dowski68
    Medford, Oregon
    You must have a large barn for that many bikes.
  12. hogfiddles
    No.... I have squirreled away around here, friends garages, etc.....
    Wintersdark likes this.
  13. hogfiddles
    Makes it harder for her to keep track of, too
    dowski68 and Wintersdark like this.
  14. Andy555
    Andy555 Active Member
    Slovenia
    Time 00:23 here,and i after work,have some relaxing-
    Putting my carbs together.
    TheCrazyGnat and Stumplifter like this.
  15. Andy555
    Slovenia
    Stumplifter i see that you are on net,pls help
  16. Andy555
    Slovenia
    Floats are not all in the same position,and i dont get that tread where is all spoken abouth,any help now is posible that i finish that,tnx
  17. dowski68
    Medford, Oregon
  18. dkavanagh
    Rochester, NY
    Are the floats upside down?
  19. Ian Vanore
    Ian Vanore Member
    Philadelphia, PA
    Those are some damn clean carbs. How?
    Andy555 likes this.
  20. dowski68
    Medford, Oregon
    Your possibly right, I didn't even notice that. LOL
  21. Stumplifter
    Stumplifter Well-Known Member
    near Irma, WI
    Sorry Andy . . . I get up early, grab a coffee surf here a bit and then out the door for work. Then jump back on during breaks and lunch.
    There is a thread for doing a 'dry set' of float levels ( http://xjbikes.com/forums/threads/setting-hsc32-float-heights-dry.9998/ )
    First make sure your floats are in the correct orientation - then the dry set will get you close to all 4 being the same.
    You must verify with a wet check.
    Andy555 likes this.
  22. dowski68
    Medford, Oregon
    Got these in the mail today. Pretty good idea I know what I will be doing this Thursday morning. :):D
  23. Andy555
    Slovenia
    That pics was yust to se if they are a littel the same.
  24. Andy555
    Slovenia
    Thx
  25. Andy555
    Slovenia
    I clean it in 2 hours but i was must to take it all apart,and my cleaner soap didnt make the magic wich i did like ,must to found something else here.
  26. Andy555
    Slovenia
    Ok carbs was yesterday settet and ready to go back on bike.im proud of my work ok im not like your church but they are ok for me.
    Now i need some sugestions how to set mixture screws,i know that is posible with gauges or ear.ok i dont have gauges i need to buy it-i understand.
    Any homemade mechanic here? Sugestions pls,how to make set with ear or is some trick that is possible to set it DSC_0532.JPG
  27. Stumplifter
    near Irma, WI
    Andy555 likes this.
  28. Andy555
    Slovenia
    Tnx stump
  29. Cliffy B
    Cliffy B Member
    Fort Eustis, VA
    20170531_191909.jpg went for a little ride and realized I haven't shared a picture of my bike yet.
    Lightcs1776, Andy555, chacal and 3 others like this.
  30. Timbox
    Like your color scheme.
  31. Cliffy B
    Cliffy B Member
    Fort Eustis, VA
    Thanks, my favorite color is orange and flat black just goes very well with it.
  32. Wintersdark
    That's so sexy. Thanks for confirming for me - my Seca frame is currently naked and I've been trying g to decide whether to paint it something bright, or black, and this is definitely a huge +1 for painting it bright. Damn, that's sexy. Nice ride!
  33. Cliffy B
    Cliffy B Member
    Fort Eustis, VA
    Thanks winter, but it is actually a maxim just with a seca tank. I wanted orange on it but not too much. I figured the frame would be good. I love it and am glad others like it too. I will be creating a build thread under the modifications soon so everyone can see the process and I can put into writing what I have done. Thanks for the compliments everyone.
    dirtmax likes this.
  34. dowski68
    Medford, Oregon
    Very nice to see that color scheme !
    Great job
  35. Cliffy B
    Cliffy B Member
    Fort Eustis, VA
    Thanks dowski.
  36. dowski68
    Medford, Oregon
    You get your son a toolbox of his own yet?
    I am telling you it does wonders in keeping them occupied.
  37. Justin Hardy
    Justin Hardy New Member
    Manitoba
    Cliffs very nice. I'm slowly doing everything black, engine, pipes and all. I love that orange!
    A week ago I did fuel lines, carb cleaned, fork oil replacement, lubed all cables, axle shaft, cleaned air box, installed new intake boots, new ujoint boot for shaft, greased levers and throttle plus choke, oil change, mid drive oil change , timing chain adjust and clutch adjustment.
    Yesterday I did yics install, synched, colortuned!
  38. Cliffy B
    Cliffy B Member
    Fort Eustis, VA
    Not yet dowski, his mom is still hesitant about letting him handle tools for very long. But he does try to use them on his toys when he grabs them. Thanks Justin, I just prefer the blackout look over all the chrome.
  39. Wintersdark
    I'm with you here. I actually prefer raw aluminum to a sea of chrome, though I'm a black+accent guy myself overall.
    IMHO, chrome/polished aluminum is fine as an accent, but it's a "less is more" sort of thing.
  40. Cliffy B
    Cliffy B Member
    Fort Eustis, VA
    Yep.
  41. dowski68
    Medford, Oregon
    thought my wife had misplaced the other set of front brake pads when I realized that I only ordered one set LOL. Ordered another set looks like Monday or Tuesday for the front brake replacement.
    On another note I was at school when I was just looking at this chopper and realized that there drive belt was split in two. So I took a pick of what you don't want to happen or ride around on.
    Not trying to offend anyone just thought this was very odd. Either they have no money or this just happened to them
    Stumplifter likes this.
  42. Wintersdark
    did they even know? Lots of people don't really inspect their bike often/ever, after all.
  43. dowski68
    Medford, Oregon
    I left him or her a sticky note referring to the belt drive.
  44. dowski68
    Medford, Oregon
    Was just enjoying the evening ride when I happened to look at my odometer and this is what I seen.
    Well I made back with no incidents wait
    there was this young women who decided to change lanes at the last moment basically cutting me off.
    Oh that normal everyday riding stuff.
    Well I am good.
    Everybody keep the tires on the ground - LOL Enjoy your weekend cause mine just ended and my week is starting tomorrow.
  45. hogfiddles
    >are the floats -side down
    NO, the are oriented correctly
    >Mixture screws -
    turn them all the way in til they softly seat. Then turn each one back out 2.5 turns. That is your baseline starting point to fine-tune them.
    Dave
    Andy555 likes this.
  46. Andy555
    Slovenia
    >Mixture screws -
    turn them all the way in til they softly seat. Then turn each one back out 2.5 turns. That is your baseline starting point to fine-tune them.<
    This is realy usefull,tnx
    This goes in my book.
  47. hogfiddles
    Brought this "assemblage" home--- (not the Lumina)
  48. hogfiddles
    I expect to turn the two 1100's into one complete bike. I"ll probably just part out the SecaII. It's turned into a nightmare just to get.......first, the guy thatI bought it from didn't disclose the SALVAGE status of the title til after it was loaded and on the way...."Oh, Yeah, by the way--I forgot to tell you-----" after having assured me several times before, that it was a clear title. Grrr. Then a good frame that I bought ('title is good') turns out that the auction company stamped it in the buyer's spot......so another hassle. I may just give up on this one...... And part it.
  49. Jasonh
    Jasonh '81 XJ750 Seca
    Toronto, Ontario
    Had a great Saturday ride around part of Southern Ontario. BTW - On my XJ750 I'm consistently getting 50mpg and I ride pretty hard.
    Now that we are riding more distance and I'm getting on highways more, I find the bike cruises well at 100-110 kmh (4000rpm at 100kmh) but over that, too much engine noise/vibration. I've ordered new (larger) grips to reduce transmitted vibration to my hands. Any other experience or suggestions ? The bike runs well and I don't think there's any "abnormal" vibration, just the high rpm. I've got new tires and original grips.
    I changed to clubman bars so that may be transmitting more vibration. Any polymer bar isolators out there ?
    A 6th gear would be perfect.
    Anyone every change gearing on the shaft drive ? 1st would end up a little high for starting off, but I could live with that.
  50. Wintersdark
    Ah, the classic "Sure, the title is clear" line =/
    Been down that road more than once.
    Sadly, here in Alberta, you can't register a vehicle in your name until AFTER you ensure it. There is no title (just VIN status)... So if you're not insuring it immediately (say, because it's a project) you remain blissfully unaware of such things until it's way too late. Good times.
