  1. Wintersdark
    Wintersdark Well-Known Member
    Calgary, Alberta, Canada
    Can't say I've any issue with vibration on mine at 5k (thus cruising around 120kph) but I've no idea if that's just personal opinion or not. Always found my 750 was surprisingly smooth - the benefits of an inline 4.
    If there's got room, maybe try a slightly larger rear tire? That'll get you more speed per rpm by changing the ratio.
    As far as I know, there's no easy way to change the final drive gearing, but others are more likely to know better.
  2. Jasonh
    Jasonh '81 XJ750 Seca
    Toronto, Ontario
    Thanks for your comment. I thought about a larger tire, but affects would be minimal AND just got new rubber. I'm actually getting aching/numbness in my hands and thinking it's in part due to vibration. I'll comment back once I get my new grips installed.
  3. XJ550H
    there was a post about the vibration there is something you can put inside the bars to reduce it Just do not remember what.
    this thread
    XJ and quite frankly, cycle noob.....
    the quote
    another therad
    1982 Seca Turbo 650 Handlebar Grips
    the quote
  4. dkavanagh
    Rochester, NY
    I got some grips like that at my local dealer. They're "Royal Enfield" branded. I think they were 12-15 bucks:
  5. Wordman
    Wordman Member
    Harriman, TN
    Talked to the current owner of the XJ550 Seca I hope to buy. I plan on heading out to get it later this week (it's about 5 hours from me). Pics once I pick it up.
    Oh, by the way, I'm Bill and I'm new here. LOL
    Stumplifter and waldreps like this.
  6. Tim O
    Tim O Active Member
    Charlottesville, VA
    Welcome!
    Bought my bike as "inexpensive, easy to operate, learner bike"... after 4 mos. now I don't think I will ever sell it. Good performance and classic bike looks... hope you enjoy yours as much too!!
  7. dowski68
    dowski68 Well-Known Member
    Medford, Oregon
    Welcome to all things explained for the XJ series motorcycle with pictures.
  8. dowski68
    Medford, Oregon
    Got the other set of front brake pads today- think I will go home and see if I can get them done tonight.
    Good times ahead-:D
  9. Jasonh
    Toronto, Ontario
    I've ordered grips and going to do the butyl injection tonight. (sounds medical) Thanks for the feedback. If I can cruise at 110 without vibration issues getting into my hands, that eliminates my need to #findanotherride for long distance.
    Cheers,
  10. Andy555
    Andy555 Active Member
    Slovenia
    Friends one question,i see one bike yamaja xs 1100 year 79 ,i need to knoe if is allmoste the same like xj650 i have in mind rear wheel ,shims,...tnx
  11. dowski68
    Medford, Oregon
    I was expecting that the front brakes were going to be the original as you can see from the first pic they are replacements. :)
    the second pic is of the new going in.
    The third shows why one needs to do periodic maintenance. As I can tell by the wearing of the brake pads that the left font is not working properly.
    I for see a caliper rebuild for both sides very soon.
    I did however clean the calipers and various other pieces followed by some brake lube grease were applicable.
    Yeah it only took 15 minutes from start to finish.
  12. cruzin
    cruzin Active Member
    Michigan
    I checked the valve clearance. I just got the bike running this weekend . A week or so ago I changed 7 shims and so Ive started it quite a few times an d I wanted to see if it was still where it needs to be. Its close, a bit sloppy on one of the exhaust I could slide a .009 in it but with lots of drag on it. I need to get my manual on this computer so I can find out how to do the cam chain tension check/set and the timing.
  13. dowski68
    Medford, Oregon
    Couldn't stand the high pitched squeal from the rear brake so I took the brakes off and look what I found.
    IMG_0142[1].JPG IMG_0143[1].JPG Pics are of the front and back side of the shoes. Tried to use 220 grit to sand off the glaze but I think it is going to have to be turned on a brake lathe. Now the question is where, being as auto centers lathes are not big enough I am looking into truck stops to see If they can do it.
    Yeah fun times and yes I ordered new rear shoes already and will be here by Monday the 12th.
    Besides it is supposed to rain for the next two or three days.
    Is it me or when ever I take something apart I find myself spending more time cleaning up that area then I do doing the repair?:rolleyes:
  14. Wintersdark
    I so often get distracted that way ... Hey, I should paint this while I have it off the bike... Oh, theres a bunch of old grease and grit over there...
    I never wash my bike, but it's weirdly always clean.
    dowski68 likes this.
  15. Polock
  16. Timbox
    Fixed one horn (other one still not working) fixed the clutch safety swx in the headlight and did a little taping of some electrical wires.
  17. dowski68
    Medford, Oregon
    Funny that you mention this as I have a couple of them. Didn't give them much thought cause I thought I may make the drum out of round.
    I did find a Semi truck repair shop that has a lathe that will handle the entire rim and tire. They are doing the turning today, price unknown ?
    I will keep that in mind the next time I have to do this. Which I am hoping is like never.
    I noticed a few rims on E-bay are like the front rim in design and they are 4lbs lighter then what I have now. The shipping was more then the price of the new rim LOL. :eek:
  18. chacal
    Let us know how it works (or doesn't!)............
  19. Simmy
    Simmy Well-Known Member
    Waterloo Ontario Canada
    That would be the XJ700N rear wheel.
  20. Franz
    Franz Well-Known Member
    Scotland UK.
    Went for a run on my XJ 900f today. Bike ran perfectly which is very satisfying because I had one hell of a job sorting out the electrics. Great bikes the XJ's are.
  21. dowski68
    Medford, Oregon
    can anybody tell me what these tears are? This tire has only 1500 miles on it as with the front yet I noticed these on the rear.
    Cold tear
    Hot tear
  22. dowski68
    Medford, Oregon
    As for the turning of the rear drum. I took a drill attachment with 80 grit and just went around and around till the glaze was gone. 10 minutes.
    The shop said they could do it although they would have to remove the bearings.
    I told them that I bring it back later on after I get a bearing removal tool and new rear bearings. I was thinking about when I had them replaced and that was 15000 miles ago.
    So I will try again later when I get the proper tools and as I said new bearing.
    Unless I get a xj700N rear rim which probably would need new bearings anyway just be safe.
    That article about the true cost of maintenance rings like a church bell in my head every time I do maintenance. LOL
    regardless I love my bike and wouldn't trade for anything. :p
  23. Timbox
    Is this the only place on tire that has a spot like that? Have you been running over those painted white lines while hard on the throttle? I would guess it is normal wear if only in one spot. These is no cupping on the tire?
  24. Jasonh
    Toronto, Ontario
    New grips came in today !!! Installing tonight and pumping the bars with caulking. Tough to find a specific butyl Rubber caulk. Looks like rain gutter caulking is as close as I can find.
  25. dowski68
    Medford, Oregon
    no those marks go all the way around the tire both sides same area of tire- no cupping.
    The first 10 or 15 minutes is just normal riding letting the tires warm up a bit. Avg. temp when I go to work 45+ F. Usually only hard on the throttle, by this I mean from a stop light to 10,000 rpms through 4th gear by then I am well above the posted speed limit then I shift and let her get down to posted and this is at about 445 am going to work on a smooth road. Tire pressure is 32psi front and back.
  26. TheCrazyGnat
    Central PA
    Went over the bike tightening bolts, lubing cables, and topping off fluids in preparation for a trip up to New York for the carb clinic!
    Stumplifter and dowski68 like this.
  27. dowski68
    Medford, Oregon
    Took my bike out for a 20 minute ride so far and the brakes do not squeal anymore. :)
    Now it is raining sprinkling off and on, thank goodness my wife reminded me that I am not sugar and I will not melt.
    Stumplifter likes this.
  28. Wintersdark
    Gorgeous sunny day - days after storms are always awesome days - so took a ride out to the local bike shop and ordered a complete engine gasket kit. I'll finally be able to do my valves(been afraid to pop the valve cover until I had a new valve cover gasket on hand), and it'll get my largely disassembled Seca engine together so I can do some compression testing on it too. Good times ahead!
    Dadoseven and dowski68 like this.
  29. Wordman
    Wordman Member
    Harriman, TN
    Took it off the trailer (brought it home last night).
  30. XJ550H
    beautiful Seca.
  31. Dadoseven
    Dadoseven Active Member
    Omaha
    Very nice!
  32. Wintersdark
    Checked and adjusted tire pressure, always a tremendous PITA. I wish I had a compressor that didn't screw onto the valve.
  33. dowski68
    Medford, Oregon
    Beautiful looking bike you have there!
    A trailer is no place to keep such a prize specimen. Get out and RIDE
  34. Curt Henry
    Curt Henry New Member
    Minnetonka Minnesota
    Yesterday in 95' air temperature with a heat index of around 100' F. I rode the 83 XJ650R Seca on an Advanced Riders Course. The bike rode like a dream, not over heating, braking well, and I did not drop the bike in the tight low and high speed maneuvers. I drank over 3 liters of water without revealing myself, shirt was soaked when I got home,
  35. Timbox
    Great for you on the advanced course, I love those classes and try to take one about every three to five yrs.
  36. Wordman
    Wordman Member
    Harriman, TN
    Tires and a good check over first. And then... :D
  37. Wintersdark
    Oh! I'd been puzzling at why I never have vibration in my handlebars without anything like this, then I remembered: I added rubber washers from home Depot. They were just $0.80 each, bought half a dozen, put two under my risers and one under the tree.
    Depending on how your handlebars are attached, it's likely worth doing.
    https://www.homedepot.ca/en/home/p.716-rubber-washer-1od-116thk.1000147912.html
    Those where the ones I think. Readily available at hardware stores.
  38. Jasonh
    Toronto, Ontario
    Thank you. I'm going to try that as well. New grips helped a lot already, but the washers should reduce high frequency buzz.
  39. Tim O
    Tim O Active Member
    Charlottesville, VA
    Had to drop my bike off for a rear tire on Friday... threads popping through the tread (Or lack thereof)
  40. cgutz
    cgutz Well-Known Member
    SE South Dakota
    Yowser, glad you are getting it replaced.
    I found a nail in a perfectly good tire while cleaning, adjusting the chain, but tire had not yet lost pressure. Thank God for chain drive so I found it in the garage rather than at 65mph!
  41. JeffK
    JeffK Well-Known Member
    Just North of Annapolis MD
    Rode the turbo 30 miles very early Sunday morning. I wanted to ride further but my left knee was screaming for relief! I'm 6 ft tall and while this bike perfectly fits my 5'-4" girlfriend, it's too cramped for me but it's a blast to ride when the boost needle is swinging past 15PSI!!
    jeff
  42. Wintersdark
    Sadness! Got out this evening for the nightly ride to work, and after starting was greeted by angry OIL indicator. Shut her down, popped up onto the center stand and sure enough, practically no oil. This is curious as it doesn't burn oil or leak...
    Well, didn't leak.
    I didn't have time to find exactly where it's leaking from - it's left side for sure, appears to be from the left side transmission cover, as the bottom half of the engine on that side is just soaked in oil.
    Upside is, on Thursday I ordered a complete engine gasket kit, so as long as this is just a (severely) failed gasket I should be up and running again soon.
  43. Tim O
    Tim O Active Member
    Charlottesville, VA
    My Bike's Ready!!! :cool::p:cool:
  44. cgutz
    SE South Dakota
    I took mine home at lunch and drove the car back because they were predicting rain. Now it cleared off completely.
    If I had ridden my cycle, it probably would have poured cats and dogs!
    Tim O likes this.
  45. XJ550H
    oil drain plug can leak replace the crush washer. oil filter housing can leak use a smear of black rtv to seal it apply it let set up and torque it down to proper setting.
    oil sensor can leak it has an o ring.
    for those with a mechanical tach the part in the head can leak replace the 2 orings.
    shifter seal, out put shaft seal. list goes on
    then it could be the valve guide seals too
  46. XJ550H
    rain suit comes in handy.:rolleyes: does not work well for falling cats and dogso_O
  47. cgutz
    SE South Dakota
    I'm not worried about me getting wet, I don't want to have to wash and polish my shiny bike! o_O:eek::rolleyes:
    XJ550H likes this.
  48. Paul Howells
    Paul Howells Active Member
    Victoria, BC
    That's why I don't shine my bike.
  49. dowski68
    Medford, Oregon
    being as I replaced my front brakes I realized that the left caliper is not working.
    Decided to take it apart in the hopes that it just needs a good cleaning.
    Currently unable to get the pressure cups to pop out, any suggestions?
    I do have them soaking in PB cleaner currently.
  50. Andy555
    Slovenia
    Hy i have a problem with my valve cover gasket,few months back i change it and till now i make with bike 35 km and yesterday i start the bike and live it for running becouse i like to set carbs and after a few minuts one of half moon of the valve cover gasket came out that soo much that start to leake oil out,and idea?
    When ji reasemble the gasket few months back i was doing like say and show in one thread here.
