Petcock positioning
Discussion in 'XJ Technical Chat' started by sam042955, May 9, 2018.
  1. sam042955
    sam042955 Member
    Maryland, USA
    OK. Here's the photo of the petcock on my 83 XJ750. (It's different than the one on my 82. My 82 doesn't have any PRI, and the positioning of the petcock is logical. The "On" is down, and I turn the petcock clockwise to get to the reserve.) The arrow on the petcock on the 83 is pointing down, to "On", and it's turned as far clockwise as it will go. So I have to turn it counterclockwise to get to the reserve. This does not make sense to me, because the long tube for the reserve has to be up when the petcock is set to "On", and the only way to make it come down is to turn the petcock clockwise, not counterclockwise. What am I missing?
  2. chacal
    The arrow on the end of the selector lever should point to the faceplate POSITION indicator word. If the arrow is not pointing to the proper word, the selector lever handle has been installed improperly, and thus, the POSITION that the handle is pointing towards is not going to be the operation (mode) that the petcock is actually performing.
    sam042955 likes this.
  3. sam042955
    sam042955 Member
    Maryland, USA
    So I should trust logic (and physics) and have the lever's arrow pointing to "RES" (which is, in fact, actually "On") for normal riding, then turn the lever clockwise in order to engage the "RES" tank, if needed, even though it will then be pointing to "On".
  4. chacal
    Ha-ha! No, I think the proper solution would be to determine why it is acting in reverse of what it should, and solve the fundamental issue..........either the selector lever is installed in the improper position, of the in-tank filter unit is reversed, having the "reserve" straw or section located where "ON" should be, and vice-versa. The lever may be installed/operating as designed, but if the input (the filter) positions are reversed........
  5. sam042955
    sam042955 Member
    Maryland, USA
    Well yeah...there's that.
  6. XJ550H
    thats how the petcock on my 82 750 looks and works. when on you turn past prime to reserve to work. ccw
    I will look on my 83 to see if it is the same
  7. sam042955
    sam042955 Member
    Maryland, USA
    So you're saying you turn yours counterclockwise to get to the reserve tank (from "On", up past the PRI, to Res)? On my 82 it's the exact opposite.
  8. XJ550H
    Let my go confirm but yes
  9. XJ550H
    confirmed
    both 82 and 83 750 maxim point down for on then turn ccw to 9:00 for reserve then ccw to 12:00 to reserve.
    makes sense to me to go through reserve first to fill carbs as I am rolling down the road, instant gas to carbs then to reserve.
    I can hear and feel the death shudder just before i have to turn petcock.
    also the way your wrist works this also makes perfect sense as it would be hard to turn clock wise while riding from on to reservs
  10. XJ550H
    i think your clockwise petcock was from a bike that had petcock on right side i also suspect that it is not a vacuum petcock. does it have an off position. and a vacuum hose
    if by long tube you mean tubes in tank maybe they are on the wrong tube
  11. sam042955
    sam042955 Member
    Maryland, USA
    I'm trying to conceptualize how that would work with the straws and I can't wrap my head around it. It would seem that the lever would have to be turned clockwise in order to get the longer reserve straw situated deep into part of the tank furthest away from the gas cap. But I guess counterclockwise could accomplish that as well, lifting the regular straw up and out of the way while positioning the reserve straw deep into the reserve area of the tank.
  12. XJ550H
    the straws do not move but again your petcock could be ment for a right side tank.
    think of how hard it is to turn petcock clock wise while reaching down riding it also scares me to be releasing the throttle to do this
  13. XJ550H
    think of an ignition key in your car right side and clockwise if it were on the left side of the coloum you would have to turn it ccw to start car with out discomfort to the wrist
  14. sam042955
    sam042955 Member
    Maryland, USA
    The straws don't move?
    (I know on my Magna it's pretty easy to reach down, roll the petcock forward in a clockwise fashion, and engage the reserve. It's much easier to turn. The petcock on my 83 is very stiff and difficult to turn.)
  15. cruiserlover
    cruiserlover Active Member
    denton texas
    len,you are a genius.My petcock looks like this one, I never questioned ccw for prime, mine is correct I assume.i am just curious.My specialty is critical care medicine. I have done it for 42 years.I am an expert.Were you a factory trained motorcycle mechanic, selftaught, and why did you focus on the xj bikes? I am sure glad you did, for selfish reasons.
  16. bensalf
    bensalf Well-Known Member
    yorkshire ,england
    yes the lever turns counterclockwise from "on" at the bottom, through "pri" to "res" at the top. maybe the rubber selector inside the tap has been flipped over , or in the wrong position
  17. sam042955
    sam042955 Member
    Maryland, USA
    Maybe it's backwards on my 82. On my 83 it does turn counterclockwise, and the petcock looks original. The one on my 82 does not.
  18. XJ550H
    is your 82 petcock vacuum operated?
    does it have 2 hoses?
    if it only has on and reserve and is not vacuum operated there is no need to have a prime position because the fuel will flow when turned to on.
    got a photo of the 82 petcock?
  19. XJ550H
    now for the yamaha curve ball. on 550 and 650
    petcock is on when lever is in down 6:00 position
    turn clockwise from on to 9:00 and it is on reserve
    turn counter clockwise from on to 3: position it is on prime
    the position of the petcock allows me to reach it with just index finger and pull it up to reserve.
  20. sam042955
    sam042955 Member
    Maryland, USA
    I'll grab a photo of the 82 tomorrow and post it.
  21. sam042955
    sam042955 Member
    Maryland, USA
    Here's the 82's petcock. It would appear there is no vacuum connection. 82 petcock 01-Arrow.jpg 82 petcock 02.jpg
  22. XJ550H
    that is an aftermarket manual petcock you can see the arrow on the handle pointing to off. looks like it rotates ccw to on and cw to reserve from the off position.
    no prime because on would serve the same purpose as on
    the cutout part on the disc handle is mounted to tells me it turns in both directions from the off position
    in the first photo it is turned to on
    when tank is full gas should flow out the fuel line in on or reserve position.
    remember to turn it off when bike is not running
    make sure all the vacuum ports are capped on the intake manifolds
    in your second photo you can see the cap and clamp check all the manifold boots
  23. XJ550H
  24. sam042955
    sam042955 Member
    Maryland, USA
    I always leave the petcock on the 82 in the "Off" position when the bike is not running. Now, however, since the bike is off the road/a parts bike, I'll drain the gas tank and empty the carbs.
  25. sam042955
    sam042955 Member
    Maryland, USA
    LOL. Yeah. I don't know why I thought the straws turned with the petcock. (Well, the reason is I don't know that much about how motorcycles work.)
  26. XJ550H
    now you know and will learn much more on this site
  27. XJ550H
    fog the gas tank so it will not rust inside
  28. sam042955
    sam042955 Member
    Maryland, USA
    Sadly...the gas tank is rusted. That's one of the reasons I got this 83 XJ750. Now that I can actually take it off the bike I might try to find someone who can fix it. I always felt it was a ticking time bomb.
  29. XJ550H
  30. sam042955
    sam042955 Member
    Maryland, USA
    Absolutely. (The strange thing is that I never felt any "buzziness" on the 82. It had those ugly rectangular handlebars that were non-standard and wouldn't accept normal accessories. The 83 has normal 7/8" handlebars. I'm wondering if those ugly rectangular handlebars did a better job isolating vibrations than the normal bars.)
  31. sam042955
    sam042955 Member
    Maryland, USA
    Cool. Thanks. I will definitely check those threads out.
    (Tumbling in a dryer? Now THAT I have to see!!)
  32. XJ550H
    yup put a bag of fish tank gravel or other media in the tank seal all holes put in trash bag pack foam or pillows all around tank set drier to no heat and you have a giant rock tumbler.
    just wait untill your wife ,girlfriend , mother ect are away.
  33. sam042955
    sam042955 Member
    Maryland, USA
    I'll be damned! I can't wait to tell my buddy about this technique. (He's a big Magna Man and has re-painted several Magna tanks.)
  34. sam042955
    sam042955 Member
    Maryland, USA
