  1. Jetfixer
    So wife went to her mother's had day to myself :D Pulled exhaust and back wheel , polished lip and painted rim and repainted brake backing plate . Put new exhaust gaskets and reinstalled , reassembled rear wheel back brakes are so much better .
    dowski68 and cgutz like this.
  2. Craig B
    Craig B Active Member
    Ontario, Canada
    Installed a new AGM battery. Tired of replacing the old led acid batteries every two years.
    Fired her up and drove to work today.
    Jetfixer and Chitwood like this.
  3. fastenova
    fastenova Member Premium Member
    Redmond, OR
    Picked up cylinders and head from machine shop. Cylinders are bored out to .5mm over, honed, and checked for flatness (good). Head has freshly ground and lapped valve seats, new valve stem seals, and was checked for flatness (good). Now just need to check ring end gap, then when I find time I can reassemble and check valve clearances and adjust as needed. Hoping to find time this weekend but have a lot of other things going on... Then break it in and ride!
    Oh, and the cost was $60 less than originally quoted, so that makes me very happy!
    Franz, Jetfixer and Chitwood like this.
  4. fastenova
    Redmond, OR
    No post for two days!? I guess I'd better post again.
    Last night I reinstalled cams on my head (not installed on bike) to check valve clearances, and VERY carefully rotated cams individually so as not to bend valves. Ordered 6 shims and one replacement locating dowel pin as the machine shop got it quite out of round when they removed for cleaning. I checked ring gap and they all look great. So, now I wait for parts... While Len is lightning quick, it's never quite fast enough! I wish that USPS had a 4-hour delivery option from Len to XJ-enthusiasts. Amazon Prime has spoiled me.
    Also installed electronic flasher and LEDs for the turn signals, MUCH brighter which makes me feel better about being seen.
  5. XJ550H
    please post what type and brand flasher you used
  6. Minimutly
    Minimutly Well-Known Member
    West Wales, uk
    Finally got around to building up my xj600 rack, previously I had ultrasonic cleaned them and turned down the "flanges" to fit the 650 manifolds. Now I want to wet set the floats, fit the rack to tune basic settings. Fully expect to need to change main and idle jets, maybe even adjust the main jet height, or investigate adjusting needle height. I'm guessing either will need shimming.
  7. fastenova
    Redmond, OR
    I got both the bulbs and the flasher unit from superbrightleds.com. I've been a customer of theirs for many years and always found their products to be of higher quality than Amazon or eBay cheap junk.
    The flasher got zip tied onto the same place the OEM flasher holder goes over. The terminals were removed from their plastic housing and inserted directly in to the stock spade connectors - red to brown, black to brown/white.
    LED bulbs are 1156-NW27-T
    Flasher is LF1-S-FLAT
    Natural white bulbs are more yellow than stock incandescents, if you want the more orange look, go with the amber bulbs.
    This is much brighter than OEM, which makes me think I will be a little more visible on the road.
    XJ550H likes this.
  8. Plug
    Plug Active Member
    Missouri
    Got caught out in a severe thunderstorm 10 miles from home. Pea size hail, 60 mph wind and no place to stop.
  9. Jetfixer
    So I bought the hard bags a couple of months ago , raining and it is cold out went ahead and mounted them. I have to fabricate a bracket for the turn signals ran out of time so will have to finish sometime this week. I need to sand the bags down they have some scratches and they are red does not match the yellow on the bike , think I will paint them black .
  10. chacal
    I see a red door and I want to paint it black............
    Nice wheels on the import.
  11. Jetfixer
    Finished fabricating turn signal bracket and mounting hard bags . Went for a nice ride bike ran fantastic ride over 50 miles the smell of cut grass and flowers were strong scents . Got a long straight country road opened throttle bike pulled so good . :D
  12. XJ550H
    rode mine to work this morning . on the way home I thought my hair was tickling ny nose, when i looked at my nose I had a Yellow Jacket sitting on my nose going for a ride with me.:eek:
    Jetfixer likes this.
  13. Bluegray57
    Bluegray57 Active Member
    US
    Took receipt of the Road rage engine guards and fuse box upgrade kit from XJ4Ever. Went through the documentation and verified all parts present and accounted for. Scheduled the work with the shop (me) for early next week. I did fondle the bike just a bit as well.
  14. XJ550H
    bike gotta pay the bill some how:rolleyes:
    dowski68 and Bluegray57 like this.
  15. dowski68
    dowski68 Well-Known Member
    Medford, Oregon
    loaded bike up for trip to shop. Having front forks rebuilt.;)
    Insurance called and said I should have check by next week.
    Tomorrow going to get parts bike :D
    An 1985xj700x from california-missing rear shock and carbs should be a good deal hopefully
    fastenova likes this.
  16. Jetfixer
    Finally did it rode 390 miles bike ran great hit 85.for awhile . The starter clutch even cooperated , all was good till I had flashbacks to Wrath of Kahn moment i had my face shield up and a bug went into my ear ...thought of Checkov getting bug in his ear ...pulled over ripped helmet off for some type of critter . I think I slaughtered a large population of nats got so bad had to clean face shield several times . Was a great day another reason I love a shaft drive bike ...no lubing of chain and needing to adjust .I mounted hard bags and really dig them just need to repaint them .
    dowski68 and Tim O like this.
  17. fastenova
    Redmond, OR
    After a few weeks of having the bike apart, finally got it all reassembled and fired up. Despite not having tuned or synced the carbs, I took it for a short ride and HOLY fast... There was really something wrong before. I kept it under 50% throttle and 5500 RPM and it is way faster than I've ever experienced.
    So excited to finish the break in process, colortune and sync, and get to ride a bit more aggressively to see this motor's full potential.
    Thanks to everyone for all the great info, and @chacal for the quality parts and fantastic service! Going to be a good, long weekend...
    Paul Howells, Jetfixer and chacal like this.
  18. dowski68
    Medford, Oregon
    Went to get parts bike and half of it was missing :eek:.
    Still got the parts that I needed though, kinda disappointed however I not upset or anything.
    Now I just waiting for the forks to be done and on the road again. :D
  19. dowski68
    Medford, Oregon
    So this morning I took out the ne to me front fender and started to clean the surface rust of the underside and decided since I have a some time before I get my bike back I am going to repaint the fender. As the current color is blue I need to repaint to black.
    also have been thinking about changing the front levers to the adjustable type as I have somewhat short fingers and I find it hard to cover the front brake. Just thoughts I ponder while gazing upon my bike unless it is at the shop. ;)
  20. Minimutly
    West Wales, uk
    Got the hitachis for the seca 650 back together, drop test nicely, set the synch to the edge of the first hole. I didn't go full church, need something to do another day (actually I just need to get this one running to see if it's worth pursuing as a complete bike). Need to wet set them, then back on.
  21. hogfiddles
    Ummm--- got another trophy
  22. k-moe
    I fitted the correct oil cooler for my baby.
    As it turns out the Turbo oil cooler will kiss the front fender when you have to suddenly stop for a jaywalking deer. Other than that issue it worked fine.
    jayrodoh, Nuch, Franz and 1 other person like this.
  23. Minimutly
    West Wales, uk
    Managed to remove the four seized float drain screws from the seca's hitachis - introduced them to Mr blobby the tig torch. Went a bit further and added sizeable lumps on the ends (in stainless), need to machine them to size and cut a slot, good to go.
    k-moe and hogfiddles like this.
  24. Nuch
    Nuch Well-Known Member
    Suffolk County, NY
    Interested in sharing a picture?
    (of the cooler... not the deer.)
  25. Tim O
    Tim O Active Member
    Charlottesville, VA
    You never know it might be a very attractive deer
  26. MattiThundrrr
    MattiThundrrr Not a guru
    America's friendly hat
    Oh dear
  27. k-moe
    The deer feels sad now.
    The cooler is just the factory one that the rest of the world got.
    Nuch likes this.
  28. chacal
    ^ That is actually the correct "rest of the world" XJ550-650-750 short oil cooler (5 rows of fins)..........the Turbo coolers have 7 or 8 rows of fins, much taller, and won't fit anything but a Turbo frame properly w/o a LOT of monkeying around.
  29. k-moe
    My monkeys are experts, they just didn't think about emergency stops. The silly things don't ride. They won't even clean the bugs off for me.
    MattiThundrrr likes this.
  30. XJ550H
    but they will pick them off each other...
    hogfiddles likes this.
  31. Tim O
    Tim O Active Member
    Charlottesville, VA
    So.... much..... riding.....
    Was supposed to get a bunch of rain this afternoon but it never came. Put about 120 miles on the old girl.
    Went for a run to the bike shop and lunch...
    Then after mowing the lawn and clearing some brush, got back on the bike and didn't return until just now at 9PM.
  32. SpearChucker
    SpearChucker Active Member
    Prince George, BC, Canada
    Damn that's a beautiful bike!
    Franz and hogfiddles like this.
  33. SpearChucker
    Tim if you leave your helmet like that around here it goes for a walk. Nice day on a nice bike.
  34. SpearChucker
    So the plan is to replace the ignition switch and clean a sticky starter button. I'll let you know how it goes.
  35. hogfiddles
    How did my 750r get into VA?
  36. SQLGuy
    SQLGuy Well-Known Member
    Attempted to try BPR7EIX plugs. The local Advance Auto Parts said they had four. The guy brought a box of four to the counter and rang up four. I looked in the box. There were three. No other store had any.
  37. k-moe
    Triples are popular now. I think you have found a cheap way to make one.
    SpearChucker and hogfiddles like this.
  38. hogfiddles
    Great sale! Get three for the price of four!!
  39. Franz
    Franz Well-Known Member
    Scotland UK.
    Chitwood likes this.
  40. dowski68
    Medford, Oregon
    Started to clean up the parts that I need to change for my accident. Handle bars and front fender. Currently the fender is blue while the rest of my xj700x is black. Gives me something to do while I waiting for the front forks are getting serviced.
    hopefully back on the road by the end of next week. Hopefully
  41. Minimutly
    West Wales, uk
    Just finished, wet set floats tomorrow
  42. SQLGuy
    Well, the old plugs (which aren't very old) did just fine for a ride up to Denver to see Alan Parsons. About 125 miles round trip. Plenty of close-in parking for motorcycles in half-spots left next to people that can't properly park a car.
  43. MN-Maxims
    MN-Maxims St. Paul Minnesota
    Saint Paul, MN
    Fork seals on the 81 XJ650H , onto the brakes next!
    Tim O likes this.
  44. Tim O
    Tim O Active Member
    Charlottesville, VA
    Had an intake valve that was a little wide (.16). Got it changed out (.11)
    Read the plugs and put 1/8 turn closed on the one that looked a little rich. Then did a good resync and tried to get really accurate with it.
    Oh my :D:D… she lept out of the neighborhood like a just branded gazelle...
  45. SQLGuy
    Got the fourth BPR7EIX and swapped out the plugs. Noticed that #2 is a bit leaner than the other three, which all look really good. I'll have to think about how to approach that. I don't have trimming for individual cylinders... just for 1/4 and 2/3. It could, I guess, be valve lash out of spec on that cylinder, or a partially clogged injector, I guess. I did have all the injectors cleaned and tested before I installed them, though. I have been thinking that I'd like to switch to some smaller injectors, to allow for better resolution on the fuel delivery. This might be a good opportunity for that.
  46. Minimutly
    West Wales, uk
    Wet set both sets of carbs earlier - the hitachis off the seca were close enough from dry setting, the mikunis on the other hand were miles low (like 20mm low), three times i tweeked them.
    Checked the clutch operation on the seca - it's not releasing. Cover off next job, need gasket first.
  47. hogfiddles
    20mm low? Is that even possible?
  48. k-moe
    You would have done better to leave it at .16. The clearances close up over time, and that one is now at the minimum allowable clearance to still be considered in spec.
  49. XJ550H
    at least he will have the replacement shim on hand
  50. Tim O
    Tim O Active Member
    Charlottesville, VA
