Steering Head bearing replacement - 1982 Maxim
Discussion in 'XJ DIY How-To Videos' started by turpentyne, Sep 13, 2018.
  1. turpentyne
    turpentyne Active Member
    Desert SW
    Ok... here's my effort at replacing the steering head bearing on an XJ750J.
    Hopefully it helps... and hopefully it's not too frightening! :)
    Lodewijk likes this.
  2. Eddie Swedlund
    Eddie Swedlund New Member
    Austin
    Dildo holder... got me good.
  3. Franz
    Franz Well-Known Member
    Scotland UK.
    According to the Haynes manual for the 900f it is necessary to tighten the adjuster nut to the pre-load torque setting specified at the beginning of the chapter which is 50Nm, then slacken the nut off completely and tighten it again to the normal setting 3Nm. Has anyone done this when replacing the bearings?
