  1. Craig B
    Craig B Active Member
    Ontario, Canada
    On the topic of penetrating fluids:
    Love this guys channel.
    I use kroil, pb blaster and something called fluid film it is used for undercoating and disolves rust quickly
  3. StahlMaster
    StahlMaster Active Member
    Southgate, Michigan
    I've use Kroil. A large can will last me a few years. You really don't need much of this stuff to do the job.
    D
  4. StahlMaster
    Southgate, Michigan
    Here is the carb bank BEFORE cleaning.
  5. 78dave
    78dave New Member
    Columbia, MO
    Took the time to pull the carbs and replace the throttle shaft seals. No big deal and the old seals were definitely leaking and old. No issues. I re-synched and color-tuned the carbs and and took it for a spin. Felt great - Hope is helps with starting. I uploaded a picture which was typical of each carb throttle shaft. As a side note I had rebuilt these in February and once off I could re-tighten the float bowl bolts that seem to loosen over time.
    Jetfixer likes this.
  6. LarryMc
    LarryMc Active Member
    Lakewood, WA
    Got these rebuilt: 20181216_131811.jpg 20181216_131753.jpg 20181216_131739.jpg 20181216_131718.jpg
    Vapor blasted, boiled out and ultrasonicly cleaned. Polished venturis & slide runs. Added a throttle control screw assembly off a 1994 FZR750.
    New:
    • JBM diaphrams
    • Emulsion tubes
    • Main jets
    • Idle jets
    • Fuel needle & seats
    • Hex style drain plugs & barbed drain nipples
    • Hex style mounting, bowl, & hat hardware
    • Shaft seals, shims & butterfly hardware
    • Aluminum fuel tee
    • Fuel pipe orings
    • Enrichment plungers, springs & seals
    • Tygon fuel line, 90 degree filter w/ EFI style clamps
  7. chacal
    Interesting: that FZR750 idle speed screw extender.............
    Franz and Jetfixer like this.
  8. Colin 85 700
    Colin 85 700 Active Member
    Thunder Bay, ON
    Dude, i really like the idle screw cable unit! Thats mint!
    Reminds me if something off an ATV :)
  9. Colin 85 700
    Thunder Bay, ON
    Did the bracket fit the carb? Or did you twist it like that?
  10. LarryMc
    Lakewood, WA
    That bracket is a duplicate idle speed screw bracket from a junk set of BS28 carbs. Yes, I twisted/bent it. The screw extender came from ebay with no means of attaching it so I improvised.
    I'm sure it's from a later year Yamaha that had Mikunis. I'm doubtful it was off a FZR750 because they ran Keihin carbs mostly and the carbs were covered by a fake gas tank plenum. Who knows?
    I knew the screw threads were the same so I snagged it for $12.00. I have trouble accessing the idle speed screw in its usual location plus it gets pretty toasty there also.
    Works great for me.
  11. turpentyne
    turpentyne Active Member
    Desert SW
    NO! I don't like that idle screw at all! ... because I put my carbs back on a couple weeks ago, and now I wanna do that!
    Tim O and Jetfixer like this.
  12. LarryMc
    Lakewood, WA
    Pull them off the bike and install one. There are at least a dozen on ebay right now for sale. I just looked, seriously.
    Pulling and reinstalling the carbs gets easier each time you do it, once you figure which way works best for you. You got this....
  13. 78dave
    78dave New Member
    Columbia, MO
    New throttle shaft seals did not help with hard starting when cold.
  14. LarryMc
    Lakewood, WA
    Check your valve adjustment, make sure your getting good spark, is your battery charged up completely and if it's really really cold where you live these bikes can be real twats until they are warmed up.
  15. 78dave
    78dave New Member
    Columbia, MO
    I will say I think I did get an improvement when the choke is off. Mine has never run for any duration with full choke. But now when I use the choke a few times then go without it I notice a longer very slow run as it is trying to warm up and I can lightly dial in some throttle. Yes cold here.
  16. LarryMc
    Lakewood, WA
    Sounds like you might have a vacuum leak or a screwy enrichment plunger. Something along those lines. The first thing to do is check your spark plug color and that will tell you a bunch of info. Without seeing the plugs, I'll venture a guess that your bike is a little on the lean side from what you've told us. Pull the plugs, get a new set and fiddle a bit with your mixture ratios or Colortune. If you don't have a Colortune, get one.
    My finicky cold start issue went to starts with no or little choke after I bought a Colortune. Also I was surprised how much the mixture screw settings varied between each other.
  17. Abaton6
    Abaton6 New Member
    Hartland, Vt.
    \What does Rick charge for the carb rebuild?
  18. LarryMc
    Lakewood, WA
    Got some ME time today and got everything 99% put back together.
    chacal, kosel and Franz like this.
  19. xHondaHack
    Orange CT
    Larry, that looks awesome! Saw your other thread where you got some ride time on it.
    Wish I had more time to document all the stuff I've done or plan on doing.
    In the meantime, here's a snap shot of the parts bike build after my 20 mile shake down run today:
    I do have the "5 Valve" carb and airbox trim pieces. I'll be installing those after the final jetting when the weather gets warmer.
    One of these days I'll do a build thread with close ups and details on all the mods and improvements.
    Tony
    rocs82650 and Jetfixer like this.
  20. LarryMc
    Lakewood, WA
    Thank you.
    Your ride is undoubtedly very nice. Great work on keeping it up.
    Let us in on what work you have done.
    Its always interesting to see what others are doing to there bikes XJs or not.
  21. LarryMc
    Lakewood, WA
  22. Joeoeo
    Joeoeo New Member
    NC
    Rainy day here so I spent it doing what was sorely needed...
  23. Tim O
    Tim O Active Member
    Charlottesville, VA
    I have the same one... warning, I had to tuck it farther up under the tank as the seat was pushing hard on the top of it even with the plastic plate removed from the seat.
    Joeoeo likes this.
  24. Joeoeo
    Joeoeo New Member
    NC
    hmm ill keep an eye on it. seemed like there was enough clearance to not have issues, ive heard of people also using seat spacers to lift the seat a few mm
  25. LarryMc
    Lakewood, WA
    * Update *
    Regarding the extended throttle adjustment knob installed during my carb overhaul:
    The mounting point off the carb bowl screw didn't work out. It also created a conflict when reinstalling the carbs.
    With the same mounting bracket flatten out and a larger diameter hole, the upper starter mounting bolt was replaced with a slightly longer one and the knob fits there nicely. Pulling and installing the carbs is not an issue with this mounting point. Just let it hang until the carbs are secured then install the bolt back on the starter. The idle is easily tweaked here, if needed.
  26. Jetfixer
    Just came home 50 degrees, started bike up , been sitting for a few weeks . I WANT to ride , but have bike tucked on side wall just right to get my truck in garage...must resist now if we get no real snow for rest of winter:D
    Chitwood likes this.
  27. Chitwood
    Chitwood Well-Known Member
    Fort Atkinson, Wisconsin
    Hit 45 here today...if it wasnt for all the salt on the roads I would have pulled it off the breezeway and went for a rip
  28. Franz
    Franz Well-Known Member
    Scotland UK.
    Yes l don't mind the cold but the road salt is bad. Hopefully winter will be mild time will tell.
  29. turpentyne
    Desert SW
    nothing's better than going out a week later thinking you need to fine-tune one lean carb, only to find out... this time it runs purrrrrfectly. huh!?
    As soon as them last couple brake parts show up, I can button 'er up and go for a spin around the block to see what she does!
  30. Praxeus
    Praxeus Member
    British Columbia
    Today I installed a blade-style fuse box and relocated it to beneath a side panel so I don’t have to wiggle wires getting at my air filter. The plastic housing adds extra weather proofing I hope.
    SpearChucker and Joeoeo like this.
  31. turpentyne
    Desert SW
    Nice... I didn't think to put mine there, I assumed there wouldn't be enough clearance for the plastic side covers and never bothered to check. Everything fits ok?
    Praxeus likes this.
  32. Praxeus
    Praxeus Member
    British Columbia
    The side cover snaps shut alright. It’s a little far from the battery and I didn’t have exactly matching wire so I’m sure it with be a PO discussion topic on this forum in the year 2062!
  33. Praxeus
    Praxeus Member
    British Columbia
    I don’t know your setup and I’m sure it’s fine, but I would never put a fuse box under the gas tank in case it ever sparks. I guess I’m just to cautious.
  34. turpentyne
    Desert SW
    Mine is mounted pretty much where the original was, I have four pieces of thick hose cut to fit onto the frame and bump the seat up a little higher.
  35. Praxeus
    Praxeus Member
    British Columbia
    That’s a pretty neat trick. Probably adds some extra cushioning as well. The whole reason I did it apart from improving the reliability of the panel was to get at the air filter cover more easily. Then it dawned on me just a few weeks ago: there’s a plenum or opening behind the air box on the xj650 that I could totally be using for starter fluid (which I shouldn’t need EVERY time since using Len’s nifty drill bit on those buried starter jets) instead of removing the cover each time. I know spraying directly into the venturi is better, but maybe I’ve been doing it wrong. Do you guys just spray it down that opening? It’s how we learn, folks lol
  36. Tim O
    Tim O Active Member
    Charlottesville, VA
    This weekend did a new rear tire, oil change, and spin on filter conversion.
    Took a ride and no leaks or wobbles yet :)
    Jetfixer, Franz and SpearChucker like this.
  37. Richard Elbon
    Richard Elbon Active Member
    LaCenter Washington
    Got this 750 Seca running today for the first time since the 80s. Cleaned carbs and refilled fluids,it was put away dry around 86,I got it recently and went through it cleaning carbs and adjusting everything.Gas on waited 30 seconds for the float bowls to fill and cranked and started instantly like it was never shut off years ago. Tomorrow will be a test ride around the local area. Currently has 14,994 miles.
    Joeoeo, Tim O, Jetfixer and 1 other person like this.
  38. Richard Elbon
    LaCenter Washington
    Got up this morning and pouring down rain so today will be detailing day in my shop,tomorrow looks good.
  39. Praxeus
    Praxeus Member
    British Columbia
    Yesterday I installed an all-new clutch and I installed a spin-on adapter kit with chrome filter from Len. Great bit of kit!
    Jetfixer, SpearChucker and Tim O like this.
  40. Polock
    i thought they all filtered chrome :confused:
  41. Tim O
    Tim O Active Member
    Charlottesville, VA
    ugh...
    Praxeus likes this.
  42. Pizzaman
    Pizzaman Member
    north Seattle
    Just got done fixing the faceplate on the speedometer. Broke in half. Super glue and a glue gun will hopefully work for awhile. Replaced tach bulb while I had it apart.
    Thanks Hogfiddles for the thread on taking the unit apart. It was a big help.
    Praxeus likes this.
  43. Praxeus
    Praxeus Member
    British Columbia
    Just started playing with wiring a new LH control and my Acewell gauge today. The SuperBrightLeds are awesome. Not wired right but I’m liking what I see so far!
  44. Praxeus
    Praxeus Member
    British Columbia
    Actually, they gefilte fish.
  45. Polock
    if i knew what that meant i might be upset, but ignorance is bliss :)
  46. Moparmaniacca
    Moparmaniacca New Member
    Saskatchewan
    Carbs cleaned and valve shims checked. Checked compression while I had the carbs off, 147-146-147-147 cold. I would suspect it would go up a bit when the engine is warm. Third set of spark plugs. The plug fouling I was having was being caused by the old spark plug boots. Put on some new NGK boots (I had already trimmed the wires back 1/4") and now she fires up instantly, even in the frigid cold we have here atm. Just need a carb sync tool and also set the idle mixture screws and she'll be ready to go... in a couple of months when the streets are bare.
    Still need to try and pull the dent out of the right side of the tank. The rear pegs are missing, but I noticed that a piece where the left peg attaches is actually broken off (circled in red). Something else to find, I guess.
    Tim O, Franz and chacal like this.
  47. dowski68
    dowski68 Well-Known Member
    Medford, Oregon
    Been having trouble with the vacuum petcock, after disassembly realized that the fuel petcock is toast! :(
    Contacted CHACAL, AKA Len and ordered the manual version.
    I went with the manual version as I basically got sick and tired of repairing the vacuum fuel cock. 3 times in 5 years
    While I had the tank off I cleaned the inside the best that I could.
    Three days from order to arrival :D
    Writing a paper for school and then I am off to rip around on my 1986 XJ700 X!:p
  48. Richard Elbon
    LaCenter Washington
    Rode my 83GS 1100E to my favorite paint supply store and picked up the original color gray metallic for my Seca. Got 5 good coats on the tank,tomorrow will be clear coat. Then cut and buff.
  49. Jetfixer
    Stared at my Seca ,dreamed about 70 degree weather , riding winding back roads enjoying the sunlight , the smell of fresh cut grass ....and then realized it is -23 degrees out with -50 wind chill...went back in the house and read the forum at least I can read about something motorcycle related.
    Franz and Chitwood like this.
  50. dowski68
    Medford, Oregon
    Took myself out on my Xj700 X yesterday for about an hour had a good ol' time, ;) looking forward to doing it again in about an hour!
    Fuel Cock as referred to in the manual performed as exceptionally well, do need to mention that I have not gotten used to turning the valve on and off and as a result, I was riding and emptied the carb bowls of fuel LOL! Turn the fuel on dork at least I remembered to turn it off so not to flood the carbs or have fuel leaking into the crankcase. Should get a sticker to put on the tank to remind me LMAO
    Ride safe the roads are covered with sand and grime. :)
