XJ750J Refurb
Discussion in 'XJ Technical Chat' started by turpentyne, Jul 5, 2018.
  1. XJ550H
    keep an eye on the rtv it will break down after some time in contact with gas
  2. turpentyne
    turpentyne Active Member
    Desert SW
    Oh! Bummer. It said it resists oil and petroleum products, so I assumed it was ok. Maybe a little dumb on my part!
  3. turpentyne
    Desert SW
    Took my first stab at using the carbtune. The carbs went through a complete break-down and church-cleaned. The mixture screws set right at 2 1/2 turns. First I put the color tune on there, I got blue, but with some white pops and the idle was hanging like a banshee, higher with each turn. Basically, acting like it was lean... or maybe just wayyy out of synch.
    So I dropped the main idle screw to about 1200 rpm, and tried out the carbtune. When I got everything dialed in, it definitely seems to have gotten rid of (most of) the hanging idle, but I was surprised how low the steel bars were. I would've expected higher. Where should they be?
    Here's what I've got right now. thoughts on what you hear?
  4. XJ550H
    idle rpm is 1050
    your bars are equal and rise equaly thats always good
  5. turpentyne
    Desert SW
    oh! A little lower than I'm setting it. ok.. I'll adjust. I just came back in from fiddling with it. This time the bars were a little higher, around the 12-mark, so that's more like I expected.
    Unfortunately, any more fiddling will have to wait. Time to help someone put an outdoor fire pit thing together.
  6. turpentyne
    Desert SW
    Seems the bike is dialed in, more or less, but I'm curious about opinions on the start-up.
    The last three weekends I've started it up, to do a little more fine tuning, but I notice after a week, I have to spray a little starter fluid down the airbox the first couple times. Choke's wide open, and from what I understand I shouldn't often need that. I'm in icy-cold Phoenix, where it's a whopping 63 degrees here in the dead of winter. (18 C to the rest of the world).
    I'm running off a little fuel container with a simple on-off switch, at the moment - not the tank with its vacuum petcock. I wouldn't think that had anything to do with it.
    Thoughts?
    (ps. the carbs were taken to church for a 100% teardown and rebuild with new jets and whatnot.)
