41Y low budget caferacer
Discussion in 'XJ Modifications' started by xj750y, Oct 12, 2019.
  1. xj750y
    xj750y Member
    Nl
    Been busy on this bike for a couple of months now. Hardest part was to fit the tank but it worked out.
    Still a lot of work to do.
    Will upload more detailed pictures today.
  2. xj750y
    xj750y Member
    Nl
    This is how I bought the bike
  3. xj750y
    xj750y Member
    Nl
    Talking about the tank, it was quite a challenge to make it fit.
    1st step: remove the old brackets and weld in new ones
    2nd step: relocate fuel petcock. In the old situation the petcock hit the frame.
    IMG_20190826_180229554.jpg IMG_20190826_195642279.jpg IMG_20190826_205051607.jpg
    3rd step: make it flow with the lines of the bike (i welded in an end-plate on the backside)
    IMG_20190915_122947173.jpg IMG_20190915_122949546.jpg IMG_20190915_170234899.jpg
    Then I painted the whole thing with rattle cans and finished it off with 2k clear coat
  4. xj750y
    xj750y Member
    Nl
    Some more detailed pictures
    selection of my favourite tools
    welded on subframe + seat pan
    ugly crown plate
    removing all unnecessary metal
    result: flat crown plate
    revised front fork and shortened it by 7cm
    Bix likes this.
  5. jayrodoh
    jayrodoh YimYam
    Cleveland
    Looks great! Nice attention to detail.
  6. Bix
    Bix Member
    Victoria BC
    looks like a beauty!
  7. 50gary
    50gary Active Member
    Saginaw, Mi. USA
    I like those wheels
    Cheers, 50gary
  8. xj750y
    xj750y Member
    Nl
    Working on the speedo + painted exhaust
    Bix likes this.
  9. xj750y
    xj750y Member
    Nl
    Sorry for not posting in 100% chronologic order.
    Rebuilt + tuned carburators:
    Made some plates to cover up the space between the subframe and seat:
    Painted the gas tank with rattle cans (€32,- paint job, included 2k clear coat from rattle can)
    Dave in Ireland likes this.
  10. a100man
    a100man Well-Known Member
    Bedford, UK
    Hi, nice job. so far so good. So what was the 'new' tank from - clearly not the original yamaha!
  11. xj750y
    xj750y Member
    Nl
    It's a modified Benelli Mojave tank.
  12. xj750y
    xj750y Member
    Nl
    So I finished the 'exterior' today.
    Now I'm busy with the wire loom etc.
    chacal likes this.
  13. Simmy
    Simmy Well-Known Member
    Waterloo Ontario Canada
    That looks about as light as you can make a 900.
    How does it run, did you buy a commercial jet kit or trial and error?
    Oops just read back a post, not wired yet. Never mind.
  14. xj750y
    xj750y Member
    Nl
    Correct, I am busy with the wiring at the moment!
    The bikes feels 100kg lighter. There is not a lot of room to shave off more weight indeed.
  15. xj750y
    xj750y Member
    Nl
  16. xj750y
    xj750y Member
    Nl
    About the Jets: from experience i enlarged the mains with 10% and the slows with 8%.
  17. PavelK313
    PavelK313 Active Member
    Fairfield CA
    Are you planning on venting rectifier or is it staying completely sealed under the seat? I initially planned on putting mine under the seat as well but then changed my mind due to it needing air flow for cooling.
  18. xj750y
    xj750y Member
    Nl
    Please tell me where the air flow is coming from on the stock location.. :)
  19. PavelK313
    Fairfield CA
    I don’t remember if stock bike had air channeled into stock location but I know for a fact that it wasn’t sealed unlike your set up of electrical area. Btw, I mounded everything except rectifier under the seat as well.
  20. xj750y
    xj750y Member
    Nl
    Maybe ill put a computer fan on top of it
  21. a100man
    Bedford, UK
    Don't make the brakes too sharp - you could lose and important part of your 'old chap' on that tank seam..
  22. dkavanagh
    Rochester, NY
    I was going to comment on that as well! My thought was the seat should have a front lip as well (my FZR has one to pad the tank).
  23. xj750y
    xj750y Member
    Nl
    Update.. installed the 'exhausts' and finished the wiring.
  24. Timbox
    Looks great, this going to be a rider or for a show bike? Looking forward to how it rides and handles.
  25. xj750y
    xj750y Member
    Nl
    I like the building more than the riding however in the summer I drive often near the city (going for an ice cream etc.) . I rarely make long trips. Dont think a long trip would be a pleasure on this thing anyway lol..
    Timbox likes this.
  26. a100man
    Bedford, UK
    Whereabouts in NL are you?
  27. xj750y
    xj750y Member
    Nl
    I'm from the south.
    Finished the brakes yesterday. Installed the 19RCS brake pump and custom HEL brake lines.
    Should mention the build passed the 'low budget' stage a bit..
  28. xj750y
    xj750y Member
    Nl
    Adjusted the valves and finished the wiring harness.. And yes.. I did figgle in the brake light wires inside the main loom.
  29. xj750y
    xj750y Member
    Nl
    It's alive!
  30. dkavanagh
    Rochester, NY
    How did you like the fit and finish of the Hel lines? Looking for a set for my FZR1000 and that name has come up.
  31. xj750y
    xj750y Member
    Nl
    It's superb. You can twist the banjo fittings in any direction so you can always mount it tentionless. Highly recommended.
  32. a100man
    Bedford, UK
    South NL eh? Must be near the Belgium border with those Leffe bottles in the background! I hoped you cracked a couple when it started. My company HQ is Eindhoven so been visiting for 30 odd years now.
  33. xj750y
    xj750y Member
    Nl
    Haha good pair of eyes!
    10min from the border (30 from Eindhoven) so yes we like a good leffe (or other Belgium beers).
  34. xj750y
    xj750y Member
    Nl
    So I drove about 10km yesterday. It is super fast because it is so light but the idle is not good. It stalls after a while. I suspect a vacuum leak (I did replace the intake gaskets and covered them in gasket-improver). Maybe it is because the carbs are from a different bike and not synced yet..
  35. xj750y
    xj750y Member
    Nl
    It is more or less finished. Only have to fix some minor issues.
    Franz likes this.
  36. xj750y
    xj750y Member
    Nl
    So today I finished the project completely.
    Of course running pods is not ideal but it drives pretty well for having those pod filters. The fun thing about this project is that it is super lightweight. It is super fast and handles super good.
  37. a100man
    Bedford, UK
    Looks nice.. although I'm not a fan of the side-mount number plates.. Did you weigh it? Would be interesting to know how many Kgs (lbs) you managed to trim off.
