41Y low budget caferacer
Discussion in 'XJ Modifications' started by xj750y, Oct 12, 2019.
  1. xj750y
    xj750y Member
    Nl
    Been busy on this bike for a couple of months now. Hardest part was to fit the tank but it worked out.
    Still a lot of work to do.
    Will upload more detailed pictures today.
  2. xj750y
    xj750y Member
    Nl
    This is how I bought the bike
  3. xj750y
    xj750y Member
    Nl
    Talking about the tank, it was quite a challenge to make it fit.
    1st step: remove the old brackets and weld in new ones
    2nd step: relocate fuel petcock. In the old situation the petcock hit the frame.
    IMG_20190826_180229554.jpg IMG_20190826_195642279.jpg IMG_20190826_205051607.jpg
    3rd step: make it flow with the lines of the bike (i welded in an end-plate on the backside)
    IMG_20190915_122947173.jpg IMG_20190915_122949546.jpg IMG_20190915_170234899.jpg
    Then I painted the whole thing with rattle cans and finished it off with 2k clear coat
  4. xj750y
    xj750y Member
    Nl
    Some more detailed pictures
    selection of my favourite tools
    welded on subframe + seat pan
    ugly crown plate
    removing all unnecessary metal
    result: flat crown plate
    revised front fork and shortened it by 7cm
    Bix likes this.
  5. jayrodoh
    jayrodoh YimYam Premium Member
    Cleveland
    Looks great! Nice attention to detail.
  6. Bix
    Bix Member
    Victoria BC
    looks like a beauty!
  7. 50gary
    50gary Member
    Saginaw, Mi. USA
    I like those wheels
    Cheers, 50gary
  8. xj750y
    xj750y Member
    Nl
    Working on the speedo + painted exhaust
    Bix likes this.
  9. xj750y
    xj750y Member
    Nl
    Sorry for not posting in 100% chronologic order.
    Rebuilt + tuned carburators:
    Made some plates to cover up the space between the subframe and seat:
    Painted the gas tank with rattle cans (€32,- paint job, included 2k clear coat from rattle can)
    Dave in Ireland likes this.
  10. a100man
    a100man Well-Known Member
    Bedford, UK
    Hi, nice job. so far so good. So what was the 'new' tank from - clearly not the original yamaha!
  11. xj750y
    xj750y Member
    Nl
    It's a modified Benelli Mojave tank.
  12. xj750y
    xj750y Member
    Nl
    So I finished the 'exterior' today.
    Now I'm busy with the wire loom etc.
    chacal likes this.
  13. Simmy
    That looks about as light as you can make a 900.
    How does it run, did you buy a commercial jet kit or trial and error?
    Oops just read back a post, not wired yet. Never mind.
  14. xj750y
    xj750y Member
    Nl
    Correct, I am busy with the wiring at the moment!
    The bikes feels 100kg lighter. There is not a lot of room to shave off more weight indeed.
  15. xj750y
    xj750y Member
    Nl
  16. xj750y
    xj750y Member
    Nl
    About the Jets: from experience i enlarged the mains with 10% and the slows with 8%.
  17. PavelK313
    PavelK313 Active Member
    Fairfield CA
    Are you planning on venting rectifier or is it staying completely sealed under the seat? I initially planned on putting mine under the seat as well but then changed my mind due to it needing air flow for cooling.
  18. xj750y
    xj750y Member
    Nl
    Please tell me where the air flow is coming from on the stock location.. :)
  19. PavelK313
    Fairfield CA
    I don’t remember if stock bike had air channeled into stock location but I know for a fact that it wasn’t sealed unlike your set up of electrical area. Btw, I mounded everything except rectifier under the seat as well.
  20. xj750y
    xj750y Member
    Nl
    Maybe ill put a computer fan on top of it
