Wanted 80-84 xj650 seca tank
Discussion in 'For Sale, Trade/Swap, Wanted' started by XJ650SECATAY, Feb 9, 2020.
  1. XJ650SECATAY
    XJ650SECATAY Member
    Salt Lake City
    Looking for an 80-84 xj650 seca tank with no holes and preferably clean inside.
    Part number:
    4K0-24110-01-01
    OR
    4K0-24110-01-02
  3. XJ650SECATAY
    XJ650SECATAY Member
    Salt Lake City
    I don't care what color it is. Unfortunately (and understandably) I run into the same problem on all of the OEM websites saying that the tank is unavailable. My tank had holes in it from the previous owner dropping it and then screwing screws into it to try and pull the dent out. I was able to get the holes welded and sealed the tank with red kote. The red kote will be fine for now, but I am anticipating running into future issues with the red kote chipping away. I know I should'nt have taken the shortcut with sealing it and I should've getten professionally sealed in the first place, but I guess those are the kinds of lessons you have to learn.
    I will continue to check ebay :)
  4. Bob Salter
    Bob Salter New Member
    toronto
  5. XJ550H
    there is one for sale in this forum
    XJ650 Tank
  6. Stephen Downey
    Stephen Downey Member
    Ohio
    So if I understand, you have a 650 seca tank now, it just has some holes so you'd like to replace. If I am correct and you would like to sell your seca tank with the holes please lmk, I feel like I could fix it at work im specifically looking for a 550 or 650 seca tank also. Be safe, thanks
  7. hogfiddles
    Stephen— you DO know that the 55or and 650r tanks are different, right? But scroll down to my 550r/650r section.
  8. Stephen Downey
    Ohio
    Yes I do, I just like them both I like the 550 the best I have access to anything I need to modify anything but, yes the 550 is my favorite, the 650 I like very much and neither tanks in seca style can I find
  9. XJ550H
    Search across the ocean you must.
    the 650 and 550 over there are seca tanks
  10. XJ550H
  11. Stephen Downey
    Ohio
    Thank you for the link:) I miss my xj. Anxious for it to be done
  12. tygor
    tygor Member
    Rock Hill South Carolina
    Are the 1983 SECA XJ750RK tanks the same? I have one parts bike and one running bike (starter clutch slips). I could sell the parts bike tank.
  13. XJ550H
    no not the same as a 650 seca tank
  14. Wayne A Allen
    Wayne A Allen New Member
    Albion, NY
  15. MikeOxlong
    MikeOxlong New Member
    Michigan
    So will a 650 4k0 tank bolt right on an XJ650 maxim American bike?
  16. hogfiddles
    MikeOxlong likes this.
  17. MrSeca
    MrSeca Active Member
    Oakland, CA
    I have one that I'd give to you for $10 + shippig but it has holes. They're tiny.
