Maxim x caliper swap
Discussion in 'XJ Modifications' started by Paul Dodd, Aug 9, 2020.
  1. Paul Dodd
    Paul Dodd New Member
    Dunztable
    Hi all I've got a 85 xj750 maxim x , got her running well and looking good:) 1 problem is the brakes , their pants ! Had the same problem with a fzx and xv 750's does anyone know any other calipers that will bolt straight on ? I put fzr400 rr sp calipers on the fzx and with no other changes the brakes went from hopeless to excellent , hoping for same result on the xj cheers Paul
    have you upgraded to ss brake lines?
  3. 50gary
    50gary Active Member
    Saginaw, Mi. USA
    If FZR 600 calipers fit that means R6/R1 will fit. I put some R6 calipers (non radial) on an FZR600 with S/S lines (Galfer, DOT approved is my choice) make sure you match the Master cylinder as well.
    Cheers, 50gary
  4. k-moe
    +1 to both.
    Braided lines make a huge difference. I have not updated to the blue-dot calipers, but it's on my to-do list.
    Yamaha was very good about gradually updating critial assemblies without changing mounting dimensions very often.
