Simmy's Naked Turbo Project
Discussion in 'XJ Modifications' started by Simmy, Feb 25, 2017.
  1. Simmy
    Simmy Well-Known Member
    Waterloo Ontario Canada
    Just looking at this closer now I don't even have the heating element hooked up.
    AEM state the minimum Power/IO connections required to operate the gauge are switched 12V (5A fuse) and ground, the Red and Black wires, so that's all I hooked up.
    The wiring schematic shows the heater element Brown + and White - 0-5V and optional??
    Is yours an AEM gauge? Perhaps I should follow your advice, I could just put a 2 prong plug on it and plug it into the pig tail for my battery charger/electric vest once the motor is running.
  2. Dave in Ireland
    Ireland
    14point7.com
  3. Simmy
    OK I had it wired correctly.
    I had to buy a 5A fuse, once I turn on the key the unit begins heating the element in the sensor.
    Takes about 10 seconds to complete heating (20 on the scale) then you can push the starter button.
    Bezos just dropped off the valve shim I needed so working on buttoning up the valve cover.
    The sensor is supposed to have 18" from the head, I mounted them too close, hopefully still reads ok.
    Dave in Ireland likes this.
  4. Simmy
    OK I set the valves, set all carbs at 2-1/4 turns on the mixture screws then balanced them with the mercury stick.
    I left it idling at a very steady 2,000 rpm.
    At this idle the FPR stayed between 13.0 and 14.0
    I had to stop thinking that it was 13.0 parts air to 1 part fuel
    Instead just think of it as oxygen (bigger number) more is leaner, (smaller number) less oxygen - richer.
    According to what I read this is pretty much what you want to see at idle.
    Under turbo boost best to stay between 11.5 and 12.0.
    11.5 is target and anything over 12 becomes dangerous
    Nothing left but to put the tank on and go for a rip!
    Should be fun to see where the stock Yamaha main jets read, very cool tool!
    Then do it again with cylinder 2.
    The stoichiometric ratio is 14.7:1 (or lambda 1) which means 1 part fuel needs 14.7 parts air to fully combust
    Fuller56 likes this.
  5. Simmy
    Today I finally took the bike out to test the FAR gauge.
    I wasn't out long because it was really cold, the spitting rain didn't help either.
    Between hypothermia, traffic, grabbing turbo boost while looking at the gauge I did learn a lot.
    Just before the boost comes on, say at 5,000 rpm the F/A ratio dips down under 11 then when you ride the boost it starts leaning out but still under 12:1.
    When accelerating under 5k the readings stay around 13, 13.5.
    Closing the throttle any amount anytime leans the reading out immediately.
    I really need a warm day and a deserted highway.
    If I put my phone in a pocket aimed right it should keep recording it, that way I can just concentrate on riding the bike.
  6. Simmy
    I rode the Turbo last weekend and it seemed to fall off power significantly when I got home.
    The boost felt way down.
    I thought maybe my imagination so I rode it this weekend and yes definitely a problem.
    Registered about 4psi of boost so I started looking over all the vac hoses making sure nothing popped off.
    Paid particular attention to the hose going to the boost gauge as that is basically aquarium tubing.
    Found nothing out of place so started inspecting the exhaust connections to be certain I wasn't loosing pressure there.
    I did find the gasket at the inlet to the turbo unit looking like it's 1/2 blown out.
    It looks too suspect not to replace so no riding this one for a bit.
    Time to look at the sidecar.
    I struggled with a fuel leak at the bottom of the OEM petcock.
    As a quick fix I ordered a Chinese petcock but the bike is starving for fuel.
    Might even be the vac line, needs a closer look.
    Hoping this gasket was my problem.
    Sidney was in position to for a good look and she agrees, might just be my issue.
  7. Simmy
    I've ridden this bike just 1,800 kms depending how far off my ODO is.
    I can't be certain if I have an FZ600 or XJ650 speedo gear box.
    Might be the same not sure but I have a 16" wheel in place of 19"
    I actually just started feeling comfortable with the handling, it does feel different,
    much quicker steering twitchy even but still feels very stable at speed.
  8. Simmy
    and much to my horror, the RH sidecover has a broken tab.
    Amongst my spares I had another broken in the same place so common break
    Not sure whether to try gluing a piece from the silver cover or just mold the tab missing with epoxy
    This red one is almost cracked in half that's why I didn't select it for painting
  9. hogfiddles
    Typical for that cover…..
