  1. Dan Gardner
    Minneapolis, MN
    Luckily, I do have a heated garage - I mean I turn on the heat to work. Can't afford to heat it all the time.
  2. Brhatweed
    Brhatweed Well-Known Member
    Mora MN
    That's Minneapolis... I'm near Mora where it's gonna get even colder.
  3. chacal
    Heat wave on Monday!
    Too bad those aren't them there ferrin' Celsius temps, that would keep you so much warmer.
    Pro-tip:
    Fahrenheit (sounds German, doesn't it? Pronounce with a real guttural "oomph" if you wish...) is named after the German-Dutch physicist Daniel Fahrenheit (1724) who developed it primarily for use in industrial and climate purposes. A single degree F is about the lowest perceivable difference in temperature that a human can detect accurately.
    Centigrade (now posing as "Celsius") was developed by the Swedish astronomer Anders Celsius in 1742 (about 20 years after the Fahrenheit scale was developed), and if the word reminds you of the metric system (i.e. centimeters), well that's because it divides the measurements into a more "human"-relatable scale ---- a hundred evenly-spaced units since freezing (0* C) and boiling water (100* C) are easier to remember and relate to.
    Prior to these measurement scales, there was no standard for temperatures, and the only measurement which devices could tell you was whether the current temperature was hotter or colder than a previously measured temperature. Most relied on the expansion characteristics or air and/or water (or both, since they both expand or contract in volume as things get hotter or colder) and thus a relative level of "hottness" or "coolness" was possible, but no universal "actual temperatures" existed....although, as long as the exact same instrument was being used by a person, then they could develop their own private "scale" of measurement......think of an old-style glass thermometer (the ones filled with mercury that you would stick under your tongue, or shove straight up your ******** for even better accuracy....) but without any defined measurement scale engraved into it: "Well, look, the measurement is way down thar', better bring the cows into the barn tonight".....
    Fuller56 likes this.
  4. ScottFree
    ScottFree Active Member
    Northern Ill-Annoy
    'Snot exactly tropical here in the Windy City either:
    My garage is not heated. When I added 15 feet to the end as a separate "motorcycle shop" thirty years ago, I thought about insulating and heating the addition... but the budget was a bit tight and we'd had a string of warm-ish winters, so I figured it wasn't worth the expense. Oops...
    I brew beer (well, not right now--I do it on the porch and the hoses would freeze up in minutes today), and that history of ºF and ºC got me to thinking about how brewers made beer (a very temperature sensitive process) before thermometers. I suspect it's got to do with each brewery having two reliable temperatures: their ground water, which should be consistent year round, and boiling. So, while you might have no idea about the numbers, after some trial and error a brewer would find that if he mixed this many gallons of boiling water with this many gallons of ground water, let it sit for a half hour, then put a third of it into a pot and boiled it for twenty minutes before stirring it all together and letting it sit for another half hour... he'd end up with a good beer.
    Anyway, back to Yamahas... carbs are still in cold storage in the garage. I was looking at some photos I took when cleaning/rebuilding them a couple years ago, and realize I probably need to re-set the float levels. I had a photo in which the fuel level in the plastic tube looked right... until I realized the camera was tilted a bit. When I straightened the photo and drew a line from the base of the carb body, I found that I probably set them high:
    Level with the carb body bottom rather than 3mm below. Oh well, another project for if/when it ever warms up.
    Meanwhile, to give myself something to do during a cold snap that looks like it will end sometime around July, I brought the seat inside for further surgery. I found a sheet of black vinyl on Amazon, sold as a generic motorcycle seat cover, that's big enough to cover the whole seat and the "booster cushion" I made to lift the rider portion up to the same level as the passenger portion. I think I'm going to see if I can just staple this vinyl over everything else, so that if I (or some future owner of this bike) want to lower the rider seat back to stock level, they can.
    I also kinda suspect that's not necessary. If and when I try to sell this bike, I'm just going to have to accept that Maxim 650s are a dime a dozen in the used market. I look on FB Marketplace and see a dozen XJs being offered between $750 and $1500 for every KZ650... and the Kaw's seller is asking upwards of $4000. Kinda funny, because when I dug up the old Cycle World review of the Maxim, it said the Yamaha was the better bike--lighter, faster, better equipped (cast/tubeless wheels, shaft drive) than the KZ. Go figure.
    Brhatweed likes this.
  5. Brhatweed
    Mora MN
    This morning just before sunrise, car did not want to start... forgot how Norwegian the driver can be about such things and it eventually fired.
  6. Will@CCC
    Will@CCC New Member
    USA
    reverse engineered the engine bracket for my XJ550 project this morning. Now to see it the sheet metal guys will quote it or if I'm going to make some excessively fancy brackets tomorrow.
    Dan Gardner and Brhatweed like this.
  7. Dave in Ireland
    Ireland
    Kwaks are the Nikons of the bike world.
    Sure, well built and reliable, but always attract extra money.
  8. Will@CCC
    Will@CCC New Member
    USA
    My assistant talked me into doing some engine brackets in aluminum to practice contour machining and because I don’t have any home machined parts on the outside of my bike I eventually coincided the point.
    So I present to everyone the most excessively fancy over machined version of an XJ 650 engine bracket.
  9. Fuller56
    Fuller56 Well-Known Member
    I think that is a very pretty engine mount.
    Will@CCC and Brhatweed like this.
  10. Brhatweed
    Mora MN
    That is some nice CNC work. Great job!
    Will@CCC likes this.
  11. Will@CCC
    Will@CCC New Member
    USA
    My 8:30 appointment canceled so have some pics of the brackets installed. I'm glad to have the old ones off but now I feel like I need to buy/make some new hardware and finally clean up the outside of the engine.
    Here's the previous owners modification I was replacing so there is some context as to why I decided to replace the engine mounts on both my bikes.
  12. mavericka70
    mavericka70 New Member
    arkansas
    As someone who is a CNC programmer by trade, nice work!
  13. Rayzerman
    Rayzerman New Member
    Ontario Canada
    You know, now you gotta shine up those engine cases, lol. Nice work!;):)o_O
  14. Dave in Ireland
    Ireland
    Was the PO John Steinbeck, by any chance?
    Grapes of Wrath expressed in the medium of welding.
    Uxbridge Brule likes this.
  15. Fuller56
    Now you are on a slippery slope. A couple of pretty parts making other parts appear shabby in comparison. Next you will be disassembling the whole bike and making it pretty like @Simmy's or @Mezzmo's.
    Brhatweed and chacal like this.
  16. Will@CCC
    Will@CCC New Member
    USA
    Unfortunate news I’m going to have to put the XJ550 project on the back burner for a bit. Finally made a new m12 adapter so I could give a proper compression tester and got 120, 90, 90, 150. Digging into the motor it’s a bad valve and rings on 2 just bad valves on 3.
    It shouldn’t be that bad a fix but with this being a build for my friend I’m likely going to see if the bikes posed for sale in Columbus are still around and just do a temporary engine swap. That way he can ride this season while I work on getting the training and tools to do a professional engine rebuild in house.
  17. Uxbridge Brule
    Uxbridge Brule Active Member
    Uxbridge Ont
    As a welder that weld makes me cry a little every time I see it
    Brhatweed and ksigurdsen like this.
  18. Brhatweed
    Mora MN
    Yeah those are a bit rough. Good news is that's what keeps us in business.
  19. Brhatweed
    Mora MN
    So... watching the weather and if we hit the 50F mark the SECA goes for a ride.
  20. Fuller56
    Yesterday was predicted to be 64, actually hit 70. Clear and dry out and the Most Awesome Wife was excited to be washing the windows and not have me under foot while doing so. That meant Sweetness to '80 Maxim 650 got some exercise. We rode about 80 miles east of Cary to the far side of Seymour Johnson Air Force Base where an old road ends just outside their perimeter fence. It is a well known spot to watch F15's and KC10 (I think) air tankers take off and land. Close enough that you really FEEL the Sound of Freedom as they laun upload_2026-2-11_7-2-58.jpeg ch. A good ride there and back and an awesome experience no matter how often or how many times I go there.
  21. Brhatweed
    Mora MN
    We're all USAF. Brother, both nephews, I started out with CAP.
  22. Brhatweed
    Mora MN
    Okay so Sunday the 15th and we're over 50F and I'm doing a preflight check of my bike... oil, battery, fresh 100LL in the tank and stuck front brakes! Gave the lever a good squeeze to make sure things were working, they came on well but never let go so now it's time to pull them apart again. Replaced the seals around this time in 2024 using what I thought were quality pieces from K & L but they have swollen up in the bores and have a death grip on the pistons. Fluid came from a fresh bottle of Valvoline DOT 3 which I'm also using in my Imapla and never had a problem with it and the only non-stock items are the stainless brake lines I bought from Chacal and those were flushed with brake parts cleaner and allowed to dry in the hot sun before they were installed.
    So now it's teardown time again and everything comes off the bike, might be a really good time to finish my top-mount master conversion once my meager tax return arrives. Gotta say those stainless lines are the cat's pajamas!
    Will post my findings when I get things off and apart.
