  1. Dan Gardner
    Minneapolis, MN
    Luckily, I do have a heated garage - I mean I turn on the heat to work. Can't afford to heat it all the time.
  2. Brhatweed
    Brhatweed Well-Known Member
    Mora MN
    That's Minneapolis... I'm near Mora where it's gonna get even colder.
  3. chacal
    Heat wave on Monday!
    Too bad those aren't them there ferrin' Celsius temps, that would keep you so much warmer.
    Pro-tip:
    Fahrenheit (sounds German, doesn't it? Pronounce with a real guttural "oomph" if you wish...) is named after the German-Dutch physicist Daniel Fahrenheit (1724) who developed it primarily for use in industrial and climate purposes. A single degree F is about the lowest perceivable difference in temperature that a human can detect accurately.
    Centigrade (now posing as "Celsius") was developed by the Swedish astronomer Anders Celsius in 1742 (about 20 years after the Fahrenheit scale was developed), and if the word reminds you of the metric system (i.e. centimeters), well that's because it divides the measurements into a more "human"-relatable scale ---- a hundred evenly-spaced units since freezing (0* C) and boiling water (100* C) are easier to remember and relate to.
    Prior to these measurement scales, there was no standard for temperatures, and the only measurement which devices could tell you was whether the current temperature was hotter or colder than a previously measured temperature. Most relied on the expansion characteristics or air and/or water (or both, since they both expand or contract in volume as things get hotter or colder) and thus a relative level of "hottness" or "coolness" was possible, but no universal "actual temperatures" existed....although, as long as the exact same instrument was being used by a person, then they could develop their own private "scale" of measurement......think of an old-style glass thermometer (the ones filled with mercury that you would stick under your tongue, or shove straight up your ******** for even better accuracy....) but without any defined measurement scale engraved into it: "Well, look, the measurement is way down thar', better bring the cows into the barn tonight".....
    Fuller56 likes this.
  4. ScottFree
    ScottFree Active Member
    Northern Ill-Annoy
    'Snot exactly tropical here in the Windy City either:
    My garage is not heated. When I added 15 feet to the end as a separate "motorcycle shop" thirty years ago, I thought about insulating and heating the addition... but the budget was a bit tight and we'd had a string of warm-ish winters, so I figured it wasn't worth the expense. Oops...
    I brew beer (well, not right now--I do it on the porch and the hoses would freeze up in minutes today), and that history of ºF and ºC got me to thinking about how brewers made beer (a very temperature sensitive process) before thermometers. I suspect it's got to do with each brewery having two reliable temperatures: their ground water, which should be consistent year round, and boiling. So, while you might have no idea about the numbers, after some trial and error a brewer would find that if he mixed this many gallons of boiling water with this many gallons of ground water, let it sit for a half hour, then put a third of it into a pot and boiled it for twenty minutes before stirring it all together and letting it sit for another half hour... he'd end up with a good beer.
    Anyway, back to Yamahas... carbs are still in cold storage in the garage. I was looking at some photos I took when cleaning/rebuilding them a couple years ago, and realize I probably need to re-set the float levels. I had a photo in which the fuel level in the plastic tube looked right... until I realized the camera was tilted a bit. When I straightened the photo and drew a line from the base of the carb body, I found that I probably set them high:
    Level with the carb body bottom rather than 3mm below. Oh well, another project for if/when it ever warms up.
    Meanwhile, to give myself something to do during a cold snap that looks like it will end sometime around July, I brought the seat inside for further surgery. I found a sheet of black vinyl on Amazon, sold as a generic motorcycle seat cover, that's big enough to cover the whole seat and the "booster cushion" I made to lift the rider portion up to the same level as the passenger portion. I think I'm going to see if I can just staple this vinyl over everything else, so that if I (or some future owner of this bike) want to lower the rider seat back to stock level, they can.
    I also kinda suspect that's not necessary. If and when I try to sell this bike, I'm just going to have to accept that Maxim 650s are a dime a dozen in the used market. I look on FB Marketplace and see a dozen XJs being offered between $750 and $1500 for every KZ650... and the Kaw's seller is asking upwards of $4000. Kinda funny, because when I dug up the old Cycle World review of the Maxim, it said the Yamaha was the better bike--lighter, faster, better equipped (cast/tubeless wheels, shaft drive) than the KZ. Go figure.
    Brhatweed likes this.
  5. Brhatweed
    Mora MN
    This morning just before sunrise, car did not want to start... forgot how Norwegian the driver can be about such things and it eventually fired.
  6. Will@CCC
    Will@CCC Member
    USA
    reverse engineered the engine bracket for my XJ550 project this morning. Now to see it the sheet metal guys will quote it or if I'm going to make some excessively fancy brackets tomorrow.
  7. Dave in Ireland
    Ireland
    Kwaks are the Nikons of the bike world.
    Sure, well built and reliable, but always attract extra money.
  8. Will@CCC
    Will@CCC Member
    USA
    My assistant talked me into doing some engine brackets in aluminum to practice contour machining and because I don’t have any home machined parts on the outside of my bike I eventually coincided the point.
    So I present to everyone the most excessively fancy over machined version of an XJ 650 engine bracket.
  9. Fuller56
    Fuller56 Well-Known Member
    I think that is a very pretty engine mount.
    Will@CCC and Brhatweed like this.
  10. Brhatweed
    Mora MN
    That is some nice CNC work. Great job!
    Will@CCC likes this.
  11. Will@CCC
    Will@CCC Member
    USA
    My 8:30 appointment canceled so have some pics of the brackets installed. I'm glad to have the old ones off but now I feel like I need to buy/make some new hardware and finally clean up the outside of the engine.
    Here's the previous owners modification I was replacing so there is some context as to why I decided to replace the engine mounts on both my bikes.
  12. mavericka70
    mavericka70 New Member
    arkansas
    As someone who is a CNC programmer by trade, nice work!
  13. Rayzerman
    Rayzerman Member
    Ontario Canada
    You know, now you gotta shine up those engine cases, lol. Nice work!;):)o_O
  14. Dave in Ireland
    Ireland
    Was the PO John Steinbeck, by any chance?
    Grapes of Wrath expressed in the medium of welding.
    Uxbridge Brule likes this.
  15. Fuller56
    Now you are on a slippery slope. A couple of pretty parts making other parts appear shabby in comparison. Next you will be disassembling the whole bike and making it pretty like @Simmy's or @Mezzmo's.
    Brhatweed and chacal like this.
  16. Will@CCC
    Will@CCC Member
    USA
    Unfortunate news I’m going to have to put the XJ550 project on the back burner for a bit. Finally made a new m12 adapter so I could give a proper compression tester and got 120, 90, 90, 150. Digging into the motor it’s a bad valve and rings on 2 just bad valves on 3.
    It shouldn’t be that bad a fix but with this being a build for my friend I’m likely going to see if the bikes posed for sale in Columbus are still around and just do a temporary engine swap. That way he can ride this season while I work on getting the training and tools to do a professional engine rebuild in house.
  17. Uxbridge Brule
    Uxbridge Brule Active Member
    Uxbridge Ont
    As a welder that weld makes me cry a little every time I see it
    Brhatweed and ksigurdsen like this.
  18. Brhatweed
    Mora MN
    Yeah those are a bit rough. Good news is that's what keeps us in business.
  19. Brhatweed
    Mora MN
    So... watching the weather and if we hit the 50F mark the SECA goes for a ride.
  20. Fuller56
    Yesterday was predicted to be 64, actually hit 70. Clear and dry out and the Most Awesome Wife was excited to be washing the windows and not have me under foot while doing so. That meant Sweetness to '80 Maxim 650 got some exercise. We rode about 80 miles east of Cary to the far side of Seymour Johnson Air Force Base where an old road ends just outside their perimeter fence. It is a well known spot to watch F15's and KC10 (I think) air tankers take off and land. Close enough that you really FEEL the Sound of Freedom as they laun upload_2026-2-11_7-2-58.jpeg ch. A good ride there and back and an awesome experience no matter how often or how many times I go there.
  21. Brhatweed
    Mora MN
    We're all USAF. Brother, both nephews, I started out with CAP.
  22. Brhatweed
    Mora MN
    Okay so Sunday the 15th and we're over 50F and I'm doing a preflight check of my bike... oil, battery, fresh 100LL in the tank and stuck front brakes! Gave the lever a good squeeze to make sure things were working, they came on well but never let go so now it's time to pull them apart again. Replaced the seals around this time in 2024 using what I thought were quality pieces from K & L but they have swollen up in the bores and have a death grip on the pistons. Fluid came from a fresh bottle of Valvoline DOT 3 which I'm also using in my Imapla and never had a problem with it and the only non-stock items are the stainless brake lines I bought from Chacal and those were flushed with brake parts cleaner and allowed to dry in the hot sun before they were installed.
    So now it's teardown time again and everything comes off the bike, might be a really good time to finish my top-mount master conversion once my meager tax return arrives. Gotta say those stainless lines are the cat's pajamas!
    Will post my findings when I get things off and apart.
  23. FJ111200
    FJ111200 Active Member
    Crewe, Cheshire, England
    Today i fired up my FJ1200 after the winter lay-up. The starter clutch took a while to bite but got there after a few prods of the button.
    Also fired up my CX500. The others will have to wait.
  24. Brhatweed
    Mora MN
    So an update on mine. Pulled the calipers apart and found the seals had swollen up from who knows what but no moisture or corrosion, a quick fffftt with the air gun and some spray of chlorinated brake cleaner everything was Zestfully clean. A quick stop at Larson Cycle here in town scored the correct Yamaha caliper seals for $25.99/side plus an oil filter and two hours later another hundred miles rolled on the odometer. Oh yeah really nice to be in the saddle again if only for a short while, next week it's back to February reality and March has been known to be a real doozy.
    Snowbird SECA
  25. ScottFree
    Northern Ill-Annoy
    What I did not do to my Yamaha this week: make any progress. Sigh.
    Monday was a beautiful day, 65º and sunny with a light breeze, and of course the best part of the afternoon was consumed by a visit to the doctor. But, with another 65-and-sunny prediction for Wednesday, I thought I'd maybe get the Maxim back together for a ride. Back in November, after the #1 carb overflowed, I pulled the rack and removed a shaving of fuel line rubber that was holding the float valve open. While I had them off, I lowered the fuel level a couple mm in both, as photos of the wet level check I did a couple years ago revealed I had set it a bit too high. Before putting the carbs back on, I did another wet level check... or attempted to, but while the #1 carb was now just fine (and at the correct level), #2 was now overflowing. Nuts! I opened it up and looked for another piece of foreign material that might be keeping the float valve from closing, but no luck. At that point I decided to put the carbs back on the shelf and spend the rest of the afternoon replacing the chain on my Himalayan.
    Yesterday was chillier and gray and gloomy, so rather than take either of my operational motorcycles for a ride, I decided to break the rack apart and clean everything in the fuel delivery system. I had do dig out my old manual impact driver (bought to get the points cover off of my very first bike in 1976) to get some of the screws out, but it did come all the way apart. I inspected #2 and of course could not find any signs of debris in the fuel path. I also held it up and checked that the little stop on the tang assembly does keep the float from dropping far enough to let the needle get cockeyed or fall out. So for the moment I'm at a bit of a loss as to why this carb is now overflowing.
    Another thing I noticed was that the #1 carb has a really weak throttle return spring (or some binding on the throttle shaft), as once the rack is separated the spring is not strong enough to close the butterfly fully. The #2 and #4 carbs have slightly stronger springs and do snap shut. The #3 carb has a very strong spring that I assume is the "master" for the entire rack. The carb-to-carb throttle linkages mean that the #1 carb's throttle will close when the others do... but I wonder if the spring is there because the linkage has a tiny bit of play. If so, it might explain the bike's annoying behavior at stoplights: it drops to a nice idle, and then, after about twenty seconds, starts slowing down a tiny bit more every few seconds, until after about a minute it stalls unless I blip the throttle. It seems to me that if there is a tiny bit of play in the linkage and the #1 carb's return spring is weak, this might be the cause: bike drops down to idle, linkage pushes the #1 carb's throttle almost closed, it idles nicely at that point (when I synched the carbs), but then the weak spring and vibration close the throttle that last bit. Now the bike's running on three cylinders and dies... Hmm... And I had been looking for vacuum leaks and fiddling with mixture adjustments.
    Well, maybe that's a possibility. I squirted a little WD-40 into the area around the throttle shaft. Should probably try some carb cleaner. If I am lucky there is just a tiny bit of gum in there that will dissolve and allow the spring to do its job. If I am not lucky, I may have to replace the spring, though I see nothing broken or damaged in it.
    And I still have to figure out why #2 is overflowing.
  26. Brhatweed
    Mora MN
    Yeah everything revolves around the #3 carb regarding the throttle settings and balance and the factory manual says this is the starting point. I'd say the #1 throttle shaft is hanging up for whatever reason, never seen a spring go so weak it can't do anything. Seal swell up or somehow got distorted?
    As far as the #2 leakdown sometimes its nothing more than a dusting of sediment on the tip or seat that can seep fuel and overflow the bowl, been there myself.
  27. Olewildbill
    Olewildbill New Member
    Columbia,MO
    Signs of Life! Was told it ran.. but didn't really care.. wanted a project.. but got confirmation today! Screwdriver to the solenoid and she fired right up! Ran for about 5 seconds and died.. But it ran!
    Tried firing it up about 5 more times with no luck before the battery was gassed.. is that normal? Or should i be looking at getting a new battery.. it looks fairly new but there's zero markings on to know for sure..
  28. Brhatweed
    Mora MN
    New battery might be in order. I'm running one of those Walmart jobs and it's been going for three years with nothing but periodic water.
  29. Rayzerman
    Rayzerman Member
    Ontario Canada
    In vintage Honda restorations, the guys found that taking a Dremel to polish up the tabs on the floats was necessary..... as well as polishing up the brass pins for the float pivots. Might cure a sticky float.
    StorminNorman and Brhatweed like this.
  30. ScottFree
    Northern Ill-Annoy
    Hmm... there is a bit of a burnished spot on the tab. I will give it a bit of polishing.
    Another thing I noticed is that the metal-tipped needles are slightly shorter than the rubber-tipped ones that came on the bike. I am starting to wonder if this means they drop a little further down in the seat bore when the carbs are empty. There is a tab on the float that limits how far down the float can drop (well below the level it should ever encounter while running). I am thinking about bending that a little so that the float doesn't drop as far when the carb is empty, for the possibility that if the needle drops too far in the seat it can get cockeyed and not properly center itself in the seat opening. Somebody on another thread remarked about this happening to him.
    As for the #1 carb with the wimpy spring and/or slight binding on the throttle shafts... I tried to get the throttle butterfly screws out. No surprise that after 46 years they will not budge. I decided not to waste my time and stopped (the alternative being to wreck the heads, despite my JIS drivers, and then stop). Instead, I tightened the spring slightly, by moving its attachment point:
    About a quarter turn tighter, which (given the spring makes eight turns around the throttle shaft) increases the preload on the spring by about 3 percent. It is enough to assure that the butterfly closes all the way even if it's moved only a tiny amount off fully closed. It is definitely a bit more resistance than the spring on the #4 carburetor, but much, much less than the big spring on the #3 carb. I think it will fix any throttle-not-closing issues.
    Now back to the leaks on #2... I hope that maybe raising the empty-bowl position a bit and polishing the float tang fixes it. I still need to get some caps or plugs so that I can wet-test the carb individually rather than putting the whole rack back together.
  31. Brhatweed
    Mora MN
    So I went and eyeballed my carbs and the spring is already on the spot you have marked as "new" so apparently it was wrong to begin with. Maybe Chacal or Hogfiddles could confirm this?
  32. ScottFree
    Northern Ill-Annoy
    Well, if it was wrong to begin with, all four were wrong to begin with because they all have their springs in the spot I marked as "original." I looked at the other carbs, and while they all do close completely with the springs in the "original" position, they are pretty wimpy about it. Carb #4 in particular just barely closes all the way if it's opened a crack. I am thinking about moving the springs on #2 and #4 to match what I did to #1. I don't see any need to change the spring location on #3, as that spring's strong enough to be re-used as part of a garage door opener.
    We are back in the deep freeze here, so I haven't had much desire to go out to the garage and fiddle with carbs, but my plan is to polish the float tangs a bit and then fiddle with the tabs on the floats that limit how far down they can go. I've had two occasions where carbs overflowed after having been completely emptied, and I wonder if something binds or sticks when the float is all the way down. I am thinking about measuring the length of the needle's tapered section and setting the tab on the float so it can only drop one or two mm below that point.
  33. Brhatweed
    Mora MN
    I'm thinkin' all four were wrong, previous owner? I mean it could be the spring is bad as anything is possible so I'm not going to discount your findings. Honestly when it comes to something like this I'd be inclined to replace everything with known good or new parts just to be on the safe side, I'm not far from 57 years old and really don't need that kind of excitement.
    Last summer I came across a 20-something dude who actually knew what a SECA was and we got to talking, he had mentioned something about an aftermarket or kit type TCI that was programmable and not overly expensive, does anyone know what this might be?
  34. chacal
    If the carbs were broken apart from the rack, and then re-assembled without a "flat plate" (alignment plate) to hold the carb bodies in perfect alignment with each other while screwing the rack brackets onto the carb bodies, you can (will) get a mis-alignment between the throttle shafts that can prevent them from closing properly.....
    Carb Rack Assembly Alignment Plate:
    j177) Aftermarket carb rack ALIGNMENT PLATE. When you break the individual carbs out of the rack, one of the crucial re-assembly procedures is to make sure that all the carb bodies are in "perfect" alignment with each within the rack. This is critical, as mis-alignment of one carb body to another will result in different throttle valve opening positions between differing (adjacent) carbs that no amount of synch screw adjusting will ever remedy.
    As you start installing the screws into the individual carb bodies (mounting them into the upper and lower carb rack bracket bars), the carb bodies will try to twist and "walk" from each other due to the torsional forces being applied to the screws and the precise alignment of the screw mounting holes.
    Yamaha specifies the use of a flat piece of plate glass to perform this procedure.....the idea being, if you set the carb throats down against a perfectly flat surface, you can apply downward pressure onto the carb bodies to insure that the throats stay perfectly flat against the glass plate during re-assembly and tightening of the rack bracket screws, insuring accurate carb body alignments within the assembled rack.
    This 1/2" thick flat plate serves this purpose, and also has a relief slot cut into the center of it to allow clearance for the throttle cable bracket linkage or the idle speed screw head, so that those items do not interfere with the re-assembly procedure (an inconvenient issue to deal with when using plate glass). Non-slip foot pads prevents the plate from trying to slide around while you're fiddling with the screws and the carb rack. Works for all XJ-series carbs.
    HCP20990 Aftermarket carb rack re-assembly ALIGNMENT PLATE.
    ksigurdsen, Huntchuks and Brhatweed like this.
  35. SecaMaverick
    SecaMaverick Active Member
    Northeast Ohio
    Yes, it was me with the (un)fortunate experience of figuring out after years that the floats hung too low when the bowls were dry, and had to bend the tangs to keep the floats from dropping so far. Nary a leaky carb since then.
    Regarding the throttle spring locations, some riders consider the weaker spring location as a "mod," to reduce throttle-hand fatigue. I know on my FJR forum, it's often mentioned as a mod for that reason. Some FJRs have a notoriously stiff spring tension, which begins to hurt your throttle hand after awhile if not equipped with a throttle lock or cruise control. But it's really important for the butterflies to close as they're supposed to, so everything in moderation!
  36. Dave in Ireland
    Ireland
    https://www.ignitech.cz/en/
  37. Fuller56
    Thanks @Dave in Ireland. Interesting info. Not so much for my XJ's but Gus the Moto Guzzi. He is using his original points ignition. He wore a Dyna for awhile but when it died I put the points back in and he has been fine for at least 15 years. Not likely I would modify him again but it nice to have an affordable option.
  38. Wolverine68
    Wolverine68 New Member
    Edmonton Alberta
    [​IMG] I cleaned the carbs up on my Maxim X a few days ago. Got it running today and it sounds pretty good. BCAF012B-EA2C-463F-9C2F-66C76AFECB85.jpeg
    RideAlong420 and Brhatweed like this.
  39. Fuller56
    Wolverine68 likes this.
  40. ScottFree
    Northern Ill-Annoy
    Yeah, I read that before I broke the rack apart the first time (two years ago). I have a glass plate just for that purpose, and will use it again when I reassemble these carbs. The failure-to-close on the #1 carb is in isolation, when it's off the rack, so it does seem to just be an issue of friction and/or weak spring.
    Yep, that was you!
    On the XJ, the main throttle return spring is on the #3 carb and is reasonably stiff but not stiff enough to make me want a throttle lock. The springs on the other three carbs are pretty weak. #1 has a bit of drag on the throttle shaft, which the spring seems unable to overcome. #4 is right on the edge. I am probably going to tighten the springs on all carbs except #3, just to be sure.
    Forecast for late next week and next weekend is up around 60º and rainy. Sounds like perfect weather to do carb work in the garage--finally!
  41. Wolverine68
    Edmonton Alberta
    I has individual K&N filters on it
  42. Brhatweed
    Mora MN
    Yeah that will keep you busy.
    Put some more miles on the SECA today... what a miserable ride that turned out to be. Everything was great shortly before noon but the coldfront blew thru and kicked up the northwest winds to 30+ on the gusts, I'm moving like 70 MPH against the wind at full throttle passing nothing and getting shoved hard to the right. Yeah March needs to come & go rapidly.
  43. Wolverine68
    Edmonton Alberta
    Just curious why you would say that. Are the K&N filters problematic?
  44. Brhatweed
    Mora MN
    Pod filters are some of the biggest pains when it comes to tuning out the flat spots they create on these. There's an extensive write-up regarding the use of pod filters is the tech section, https://www.xjbikes.com/forums/threads/xj-parts-catalog-section-c-fuel-system.44642/ then scroll down to "WHAT ABOUT RE-JETTING FOR PODS, ETC?"
    I was about to switch over to pods on my 750 seca but read the tech section from top to bottom and decided against it, sure glad I did.
  45. StorminNorman
    StorminNorman Member
    Virginia
    Slowly progressing through a handlebar switch. Took off the buckhorns, and went with a set of Renthal highs because I really wanted to keep the Vetter fairing and wanted to lean a bit more forward. Had to install a set of risers that pushed the new bars up and back towards the seat so the MC wouldn't hit the windshield in a turn. I've already got a fairing-less bike, CB750F, and wanted to keep the character of the XJ as it was when I bought it from the original owner. Picked up a new MC since OEM was still leaking even after a rebuild. Picked up a shorter clutch and choke cable for a Seca. Debating a shorter throttle cable, but it seems to work fine now. Going to go to a single brake line from the new MC to the caliper. Ordered a HEL line, so hopefully can put that on later this week. Need to reassess my mirror situation on the left side as the OEM one is on the inside and the new MC has the mount on the outside. Put a set of new Pro Grips on as well. My CB750F is a sharp sharp ride, but dang, with the new handlebars, I'm loving the look of the XJ. It's like a new bike. 20260228_170238.jpg 20260228_170251.jpg
  46. Fuller56
    Those Vetter Quicksilver fairings are the perfect size for the XJ's. Not too heavy, not too big, but lots of weather protection. I put one on a 750 Maxim a few years ago and it was "just right". If your XJ frame has the threaded lug on the steering head it is easy enough to fabricate a brace to the center of the bottom of the fairing body to further stabilize it. The original fairing mounts are not real rugged being mostly sheet metal.
  47. Fuller56
    A nice day out, warm, not raining, and the parts from Len are at hand. The XJ650RJ got some love. New foot pegs rubbers as the old ones were 90% worn through. New intake manifolds and vacuum caps leading to a Colortune session and sync'ing. Nicely purring now and ready for some serious miles.
    Simmy likes this.
  48. FJ111200
    Started to put my XJR1200 back to standard.
    I had put an FZR1000RU EXUP USD set of front forks on my XJR but never really got on with it so i bought another set of standard XJR forks. The original XJR forks are on my FJ1200 and it handles really well and so didn't want to mess with it so got some more XJR forks.
    USD forks seem to be over-rated to me and can be a pig to work on so result all round. I'll post a picture when it's complete.
  49. Olewildbill
    Columbia,MO
    Found this lil nugget of joy. Ain't s'posed to be like that..
    StorminNorman likes this.
  50. Brhatweed
    Mora MN
    Not everyone is a REAL Yamaha owner.
    Rayzerman and Olewildbill like this.
