YICS Badge
Discussion in 'XJ 3D Printing & STL Files' started by BigTex, Jun 29, 2022.
  1. BigTex
    BigTex Member
    Northern Colorado
    Interesting project. CAD file is near perfect, but you need a really tight printer to get that small of detail. Probably best to buy them from Chacal, but if anyone has a good printer (and good model painting skills) here are the files.
    Attempt number 2. Getting there with the printing. And apparently my once godlike plastic modeling skills have deteriorated along with my eyesight. Can do better, but on the other hand, this is not a big bucks restoration and these are down at ankle height.
  2. k-moe
    That really looks like it would print well in resin.
  3. BigTex
    BigTex Member
    Northern Colorado
    Very likely true, sure would like access to one of those.
  4. 50gary
    50gary Active Member
    Saginaw, Mi. USA
    Funny, I bought an additional (in case I screwed up) cam cover and TIG welded over the cast YICS then remilled the top flat and the grooves to make is smooth without the YICS logo.
    Black powdercoat and done. I did similar to the engine side covers and left the Yamaha. I like the clean look.
    Cheers, 50gary
    chacal and Simmy like this.
  5. Simmy
    Simmy Well-Known Member
    Waterloo Ontario Canada
    Plastering YICS everywhere was the biggest faux pas Yamaha ever committed.
  6. k-moe
    Marketing sells machines.
  7. Zoot_Suit
    Zoot_Suit Active Member
    Detroit, Mi
    On mine it's only on the valve cover and the side covers.
