4H7-21721 XJ650 Maxim Right Side Cover
Discussion in 'XJ 3D Printing & STL Files' started by Dan Gardner, Apr 19, 2026.
  1. Dan Gardner
    Minneapolis, MN
    This is a reverse engineered right side cover for the XJ650 Maxim.
    Here it is rendered in red:
    4H7-21721-C_2026-Apr-19_08-00-38PM-000_CustomizedView22965773443.jpg 4H7-21721-C_2026-Apr-19_08-04-21PM-000_CustomizedView9456172582.jpg 4H7-21721-C_2026-Apr-19_08-05-39PM-000_CustomizedView4708470730.jpg
    Here is a prototype that I printed in three parts in order to get it to print on my printer. At this stage I have just glued it together and hit it with a little 80 grit. Next will need just a little body work on the joints, then prime, prep, paint. This is just PLA at this point:
    This design features beefed up tab bases and accommodation for an M3x40mm screw to be inserted to give the peg piece more structure. You don't need the screw, but you can strengthen the peg if you want. Just adding the extra print structure for the hole itself seems to strengthen the peg quite a bit.
    Due to the nature of this part, it can be tricky to print. You will need to figure out the best way to do it based on what material you use, your printer, where you want layer lines, etc. etc. etc. You know the drill.
    RideAlong420 and Fuller56 like this.
  2. Xj650bobber
    Xj650bobber New Member
    Slc
    just started printing this for my bobber build. any chance you have a file for the left side cover panel?
  3. Dan Gardner
    Minneapolis, MN
    No, not yet. The left sides are usually cheap and plentiful on eBay, so not as much of a priority.
    I want to get the left side done, but would like to upgrade scanner hardware first.
  4. Dan Gardner
    Minneapolis, MN
    Here's a photo of the reinforcement screw installed. Blends in nicely:
    Huntchuks likes this.
  5. Dan Gardner
    Minneapolis, MN
    @Xj650bobber - just curious to hear how the print turned out
  6. Dan Gardner
    Minneapolis, MN
    I had one "professionally" printed by Xometry in ASA material. The print quality is pretty terrible. They apparently didn't use supports, and it looks pretty bad. Gave it a little flex and it snapped. Your mileage may very, but I would not recommend, which is too bad.
    I currently have the prototype that I printed in PLA and another copy that I printed in PTEG that I'm going to work on painting. Both of those copies are very strong compared to the one I got from Xometry.
  7. co.dirtbiker
    co.dirtbiker Active Member
    Colorado, USA
    Use caution with the PLA if you think you may ever park in the sun. I printed some prototype parts in PLA a couple times. A half hour in the sun and they looked like potato chips. :confused:
    I've had better luck with PETG.
  8. Dan Gardner
    Minneapolis, MN
    Primer/surfacer:
    co.dirtbiker likes this.
  9. Dan Gardner
    Minneapolis, MN
    First two prototypes finished in jet black done
  10. chacal
    Boy those are slick!
  11. Dan Gardner
    Minneapolis, MN
    Thanks @chacal. They turned out pretty nice. I wanted to answer the question: “How much work does it take to get from 3D print to high quality finish?” And the answer is “A lot”.
    To be fair, refinishing a used side cover and achieving a high quality finish takes a lot of work too - the printed nature of these things just adds an extra wrinkle
  12. co.dirtbiker
    Colorado, USA
    Very impressive.
