‘86 XJ700 - Primary coil exchange wiring
Discussion in 'XJ Technical Chat' started by lechski91, May 19, 2024.
  1. lechski91
    lechski91 New Member
    Netherlands
    Hi all!
    I have a quick question regarding a replacement of an 1986 XJ700 primary coil (cylinders 1 &4).
    I received a “universal” coil from the bike shop (the left one in the first photo). I measured it and it is within specs for my XJ700. It has to be installed rotated by 90 degrees, has a slight difference in the distance between screws but I made it work.
    However, when I look at the -/+ wires on the new coil, the wires seems switched compared to the old coil (see photo 1). When looking at the diagram (photo 2) I am almost sure that R/W(red and white) cable is the + and O(orange) cable is the -.
    Question: If I connect R/W to the plus (right connection on the new coil) and O cable to the minus (left connection) will that be correct?
    Thanks in advance for an answer!
    Photo 1:
    Photo 2:
  2. Rooster53
    That will be fine for wiring
    In your last thread you mentioned it was a combination of battery and ignition coil causing a spark issue, but didn't mention what was wrong with the original coil - that could be helpful in getting things properly diagnosed
    Timbox likes this.
  3. lechski91
    Netherlands
    Hi Rooster53!
    The coil was significantly out of specs - the secondary resistance was around 2M Ohms.
    I have changed the battery and connected the new coil according to the above explanation. Works well, ignites without any issues.
    Thanks again!
    Rooster53 likes this.
