'03 Jeep Wrangler TDI (ALH) conversion. @ K-Moes' request
Discussion in 'Hangout Lounge' started by Nastn8, Mar 19, 2017.
  1. Nastn8
    Nastn8 Member
    This project was brought to Wetdog's Auto (where I work) last summer. It has been an ongoing since, filling the time between our other customers general repair, and now, my Seca project. intercooler mock tag blocked.jpg
  2. Nastn8
    Nastn8 Member
    As I get the pictures organized, I will post.
  3. Nastn8
    Nastn8 Member
    Bellhouse adapter modified.jpg Bellhouse adapter modified.jpg Bellhouse adapter installed.jpg
    This swap was based on Cody Built's adapter plates, but required a few modifications, as their kit is for the newer, common rail PD 1.9 TDI. We used an ALH TDI from a 2000 Jetta. The Jeep had a blown 2.4l 4 cylinder engine, and the donor Jetta had a wasted automatic trans. We like to recycle at Wetdog's.
  4. Nastn8
    Nastn8 Member
    First things first. New timing belt and water pump for the TDI.
  5. Nastn8
    Nastn8 Member
    2.4 input shaft vs 4.0.jpg 2.4 input vs 4.0 close.jpg 2.4 vs 4.0 bell house.jpg 2.4 vs 4.0 clutch.jpg
    The 2.4l wranglers were fitted with baby transmissions on the U.S. market. So we procured a 4.0l NV3500 and put a heavy duty clutch in.
  6. Nastn8
    Nastn8 Member
    Nice R&D at Cody Built. Flywheel fits perfectly.
  7. Nastn8
    Nastn8 Member
    Clutch mounted.... Shop embarrassingly filthy...
  8. Nastn8
    Nastn8 Member
    notching bell for starter.jpg notching bell for starter2.jpg starter cone1.jpg starter cone2.jpg starter cone3.jpg
    "sculpting" room for the new starter position....
  9. Nastn8
    Nastn8 Member
    pass mount base prepped to cut.jpg pass mount base prepped to cut2.jpg pass mount base cut.jpg pass mount base area cleaned2.jpg
    Cutting passenger side mount base from frame, in order to relocate it farther forward to make room for turbo/manifold.
  10. Nastn8
    Nastn8 Member
    Passenger side mount base relocated.
  11. Nastn8
    Nastn8 Member
    pass mount bracket cardboard mock.jpg passenger mount bracket challenge.jpg pass mount bracket challenge2.jpg
    Mocking up the beginnings of the passenger side mount bracket...
  12. Nastn8
    Nastn8 Member
    I decided it was best to pass both pipes through the bracket. That would send things in the proper direction. This presented challenges....
  13. Nastn8
    Nastn8 Member
    pass mount bracket weld1.jpg pass mount bracket weld1.jpg pass mount bracket weld2.jpg pass mount bracket weld1.jpg pass mount bracket weld2.jpg pass mount bracket reinforcement added.jpg
    With reinforcements, 1/4" plate is incredibly strong.
  14. Nastn8
    Nastn8 Member
    I regret the duplicates. Perhaps I should take a course on posting threads!!:oops:
  15. Nastn8
    Nastn8 Member
    The drivers side offered very little room. A ton of massaging here....refitting, grinding... And thats just the base plate.
  16. Nastn8
    Nastn8 Member
    drivers mount bracket.jpg drivers mount bracket1.jpg drivers mount bracket3.jpg drivers mount bracket4.jpg
    ...But eventually this is what it wound up being. Stout. In the top picture you can see I drilled a hole.... I decided to pass the oil pressure switch connector through here. It was almost touching the mount bracket. And I don't like wires touching anything but their conduit. Prudish wires are good.
  17. Nastn8
    Nastn8 Member
    I pulled the radiator and condenser out of the way and began mounting the intercooler......
  18. Nastn8
    Nastn8 Member
    Note the difference in thickness of the grille slats. I had to hand trim each one. I masked them and used a reciprocating pneumatic saw with a broad 24tpi blade. Then sanded smooth with 400 grit, then touched up with paint mixed for us by our friends at Beste Automotive. Thanks Keith for the perfect match!
  19. Nastn8
    Nastn8 Member
    drivers side boost pipe pass through.jpg pass side boost pipe pass through.jpg pass side boost pipe pass through2.jpg
    Having fixed the positions of the engine and intercooler, it was time to make paths for boost plumbing, and start tig welding boost pipes...
  20. Nastn8
    Nastn8 Member
    I really cut my teeth tig welding on this project. I suppose I threw my self, deliberately, under this bus. I always wanted to learn. So I read and read. Ultimately, it's trial by fire. One of the more challenging things I've set out to learn. But fun!
  21. Nastn8
    Nastn8 Member
    Boost pipes fabbed up. I had to make my own cones. I used an old trick with masking tape get the reductions. I plan to use a more accurate method when making the exhaust for my Seca.
  22. Nastn8
    Nastn8 Member
    More to come..... I am so inefficient at a posting, mostly due to the fact that I need to come up with a completely new way of capturing and organizing images. It's time for a camera that uses an sd card..... And its time for me to find a way to have view-able thumbnails in my folders so i can search the pictures by image rather than file number or name....Still open to suggestions.
  23. Nastn8
    Nastn8 Member
    Oh....and FYI.... if anyone needs to use a 3.5" hole saw on sheet metal, especially that isn't a flat plane, brace yourself well.... In cutting those pass-through holes in the core support (where the boost pipes loop in and out of the fender wells), my DeWalt drill took me for a few very jerky rides. I still wonder if this wasn't a contributing factor in blowing out my back. Meantime, I'll keep eating bacon cheeseburgers until I'm more firmly anchored.
  24. Nastn8
    Nastn8 Member
  25. MattiThundrrr
    MattiThundrrr Not a guru
    America's friendly hat
    That shouldn't help with the anchoring.
    Nastn8 likes this.
  26. k-moe
    As I get conferences over, and myself organized, I will comment.
