03 KDX220R
Discussion in 'Other Motorcycles' started by Simmy, Oct 26, 2020.
  1. Simmy
    I stepped my 15yo up to a full size dirt bike and had him do most of the maintenance it needed.
    front wheel bearings
    front brake pads
    bled both front and back brakes
    new fork oil
    topped up the coolant
    replaced a stripped mount for the LH bark buster
    replaced Chinese footpegs with OEM and 1 new return spring
    replaced gear box oil
    air filter clean and oil
    secured loose tail light
    new chain & sprockets
    new front chain guide and sprocket cover
    now its ready to rip.
    Over the winter the suspension linkage and steering stem should be re-lubed.
    I've read the OEM piston is a grenade waiting to go off, I suspect it was already done since it came with a used head gasket.
    Not a Yamaha but it will be running 2-stroke Yamalube I have an abundance still on hand.
    Franz likes this.
    Kawak makes darned good bikes overall. Definitely keep an eye on the piston. Since the stocker tends to crack, teach your kid about what a soft seize feels like. It'll be about the same (sudden "softness" in power delivery).
  3. Simmy
    I need to teach myself - soft seize, never heard the term before.
    It's a 2-stroke term. When the piston melts just a little due to lack of lubrication along the skirt, or overheating which gives the same effect.
    Although... I can't remember exactly how the KD piston cracks....if it's radially along the wrist pin the failure will be.....more than obvious.
  5. Simmy
    I just finished my annual father and son camping/riding trip.
    We settled on a 35 km loop through the forest and did this 3 times each day, 3 days in a row.
    On the 1st day we lost the kicker for the KDX, I retraced the loop and found it about 10 kms from the camp laying in the trail, huge relief.
    Felt like finding a needle in a haystack.
    We saw a moose running our same trail, my son couldn't believe how huge they are.
    This one was without horns, not sure if it was a bull or a cow but it ran away.
    I've encountered one on a street bike and it stood its ground and looked like it was setting to charge until my riding partner came along.
    He's 16 and I'm 60 so he's egging me to do one more lap, keeps me young.
    no Yamahas but we did burn Yamalube in the Kawasaki
    jayrodoh and Rooster53 like this.
  6. lostboy
    lostboy Well-Known Member
    Tillsonburg, Ontario, Canada
    Good times. Memories for a lifetime . Where did you camp ? It looks like neat place.
  7. Simmy
    A trailer park on Lake St Peter, they keep just a few sites open for tents, really lucky to get a spot. Super clean campground with great beach.
  8. Timbox
    I would think the moose would have growing horns by now. I know our deer and Elk do down here in Wisconsin. No matter what it was, they are so cool, huge and majestic. 60 and still on the dirt bikes, good for you! Those are great bikes too.
  9. Simmy
    Thanks @Timbox I can't praise my KTM enough.
    2005 EXC525 I bought new.
    Shortly after the electric start ate itself and shredded the pinion gear leaving nasty shards in the motor.
    It has 2 SS mesh screens and 2 paper oil filters plus the typical magnetic drain plug so over the course of several oil changes I got it all out.
    I installed 2006 parts and all is good, 2005 was obviously a weak point for this.
    What's not to like about a 240 lb (dry weight) bike with about 50 hp on tap!
    Take your bad-ass 450 moto crosser and add another 60 cc's just for giggles. (they're actually 510).
    I have 3 sets of wheels for it - mud, gravel and supermotard.
    Timbox likes this.
  10. lostboy
    It's cool that the trailer park let you ride bikes on the property. Most parks make you push your bike to your site even street bikes.
  11. Simmy
    Teaching my kid more wrenching skills.
    On our last trail ride the KDX fouled the spark plug but I noticed it wasn't soot but remnants of coolant.
    I thought maybe it was just the head gasket leaking but didn't see any evidence of that when I pulled the head.
    I saw some melting of the piston crown so decided to change the piston.
    Big chunks of the skirt are broken off and you can actually see bits stuck in the conn rod.
    Need to continue stripping the entire bottom end to get all the shrapnel out and inspect the cases.
    I suspect damage to the cases down by the water pump, coolant was getting into the motor somewhere.
  12. Simmy
    To strip the bottom end I had to wait for some case splitters and a flywheel puller. That took 5 weeks.
    What I found was not good. When the piston skirt broke off it went around the crank, breaking the RH case near the bottom of the stroke.
    The LH case shows some damage there to.
    I'm not sure if I want to try repairing these cases or get some used ones off eBay.
    Last night there were 2 sets of 220 cases but a whole bunch of 200 cases.
    I don't think there is any difference in the 2 bottom ends so the 200 will work.
    I don't understand why we had coolant in the combustion as this broken piece just opens the crank cavity to a dead space,
    the bike is still able to run like this.
    At this stage I can rebuild the motor with used cases, probably going to be $1500 or the other option is to just part it out.
    I have a new piston already, it will need the crank rebuilt, new bearings, oil seals, gaskets etc.
    I could slap it back together with a new piston and JB Weld but I'm too ethical to sell it like that.
    case splitters are necessary. Do not attempt to split vertical cases without them.
    Works real slick pulling the cases off the crank bearing.
    I also have another tool to draw the crank back into the cases.
    below you can see the piece broken off.
    It opens up the crank to the dead space below so the motor still runs but it increases the crank volume, this would lessen the pressure pushing the next charge up through the transfer ports.
    Minimutly likes this.
  13. Simmy
    My local bike/machine shop says no problem fixing this case.
    I'll be dropping it off with the crank shaft and get a new conn rod and main bearings installed.
    jayrodoh likes this.
  14. Simmy
    the shop weld repaired the cases, ground them to fit each other and coated them with an epoxy.
    He said if there are any cracks still there the epoxy just helps seal them up and stops them propagating, he knows his stuff.
    That was $157 and he charged $99 to rebuild and true the crank.
    New Pro-X rod, crank bearings, oil seals, gaskets, piston and rings.
  15. Huntchuks
    Huntchuks Well-Known Member
    East Rochester, NY
    Looks nice. I used to weld case/cover cracks for a co-worker who worked on Harley's at home. Not much fun.
  16. Simmy
    I just found out my new crank installer does not have an adapter to fit the threads on one end of the crankshaft. I ordered the actual nut from Kawasaki and I’ll need to grind it down to fit the tool. Another 2 week delay. 16M x 1.0 is a real fine thread, the local fastener warehouse has nothing like that.
  17. Simmy
    My ambition for today is assemble the rest of the KDX motor. Clear the work bench for XJ motors.;)
    I took it apart 5 months ago and all I have is the exploded parts printed out, wish me luck
    See the 1” pipe nipple in the picture, I discovered it’s the perfect dimension for tapping new Kawasaki water pump seals in.
    It was $2.69.
  18. Simmy
    Didn’t quite make it.
    Bottom is together, shifts and the kick lever works. 6DB32E33-9EF0-46CB-92AE-1EFE9B4E47C9.jpeg
  19. Simmy
    KDX motor is finally complete.
    I never did a complete disassemble of a 2-stroke before so I had to buy the tools for separating and reassembling vertically split crank cases. Also bought a flywheel holding wrench which I finally made use of.
    Shouldn’t be much more than another evening to get the bike back together.
    My son will do that with dad’s supervision.
    I bought another tool chest and organized all my tools just like I should have done years ago.
    It’s a pleasure working in the garage again.
    Timbox likes this.
  20. Timbox
    Satisfying work, well done.
  21. Simmy
    I thought I was nearing completion with this thing.
    Put the coolant in and it started dripping out the bottom of the water pump housing.
    There's an air space between the coolant and the gear box oil.
    This has a drain hole.
    If it drips coolant the water seal is leaking, if it drips oil the oil seal is leaking.
    I've just re-ordered another water seal and oil seal from Kawasaki.
    The oil pump bearing needs to come out to change both seals.
    I renewed the bearing last time but not this time.
    I wish I had bought a KTM after all this trouble.
    I likely would have been rebuilding a used KTM also, but then I'd have a KTM.
  22. Simmy
    Gave the KDX 4 jabs on the kicker and it came to life.
    Great relief after looking at it spread across my workbench since October.
    Pulled the swingarm back out and in process of replacing all the bearings in the suspension/linkage.
    I better have a reliable rider after all this trouble and expense.
    Timbox likes this.
  23. Simmy
    This bike does not want to leave my workbench
    I rode up and down my city street a few times, runs beautifully except the shifter.
    There’s no problem shifting 1st N 2nd but the lever doesn’t return to position to go to 3rd.
    I can find all gears when sitting on the stand so the gearbox is good. Unfortunately just getting to the springs in the shifter requires a lot of work.
  24. Simmy
    I finally got around to pulling this KDX apart so I can get ready to do some trail riding again with my son.
    I stupidly installed this spring in backwards so it didn't stay put on the 1st ride up and down my street.
    here it is installed properly. I thought I was going to have to remove the clutch basket.
    A few choice words and wooden chopsticks I managed to get it in place.
    The bike is finally fixed.
    I have to fix a non-charging condition on my KTM then I can start playing with my big-bore XJ Turbo motor.
    Timbox likes this.
  25. Simmy
    Restoration of my KDX got out of hand.
    UFO in Italy had a sale on new bodywork so I ordered a full set and a graphics kit.
    This is my spare bike, available for either son to ride.
    Now I'll be pissed off when they crash it, stupid.
    Fuller56 likes this.
