16 inch front rim swap
Discussion in 'XJ Technical Chat' started by charles Byrd, Oct 1, 2017.
  1. charles Byrd
    charles Byrd New Member
    Usa
    I have noticed on alot of the xj650 maxim cafe builds use same size rims on front and rear , which look to be 16 inch. What front rim is used to match the rear rim? Is it a rear rim that has been modified? Thanks
    there is a mod for rear to be put on front but the guy selling the kit has not been here in quite a while. I think you will find the rims are from a newer yamaha.
  3. charles Byrd
    Usa
    Do you have pictures of this mod?. I have access to cnc aswell as other fabricating tools i just would like to see previous persons work to get a feel . Hell maybe ill produce the kit again.
  4. XJ550H
  5. charles Byrd
    Usa
    Thank you i have emailed him . I might have to start from scratch though.
  6. hogfiddles
    As I recall, He stopped doing them..... Too expensive, and not enough orders
  7. k-moe
    There's also the little handling issues that come from having the same width tire front and rear.
  8. hogfiddles
    I've never tried it.... personally I don't even like that kind of look so it's never been a desire to try it
  9. charles Byrd
    Usa
    Im trying to determine if i should just put a 17 on front then ... now that i look at it most people run a 17 in front or both 17 from what it looks like. I was able to get ahold of him he is doing a batch but wont ship till mid nov n they are 195 shipped to lower 48 . Is the xj750 17 a direct fit for both rear and front.
  10. Simmy
    17’s were never original equipment on the XJs, the Seca 2 used them later.
    Skylark adapted a 17 rear on his shadow warrior project I think, I’m thinking he used an Xj900 Diversion wheel.
    If you get hubs from the spoked wheel Virago you can lace custom wheels to whatever you choose.
  11. k-moe
    The operative word being, if.
  12. k-moe
    Most people run the stock rims actually, even on cafe' builds.
    XJ 650/750 fronts are always 19" rims. Rears are either 16" (Maxim), or 18" (Seca).
  13. hogfiddles
    And.....making sure you get the correct virago spoked rim
