For Sale 1978 XS1100 Mikuni Carbs
Discussion in 'For Sale, Trade/Swap, Wanted' started by Novascotiamark, Aug 12, 2024.
  1. Novascotiamark
    Novascotiamark Member Premium Member
    Nova Scotia, Canada
    1978 XS1100 Mikuni carbs. They are probably better suited for parts. One set is assembled. It had the mixture screws stuck in the carb bodies. I drilled them out but couldn't get the idle circuit to work well after that. I think a couple of the floats are mismatched as well as some of the jets and needle seats. The slides, butterflies, chokes and mixture screws are freely moving but as I said the mixture screw passage in the carb bodies has been altered. The other set is partially disassembled, may be missing some parts but the carb bodies, bowls, slides and diaphragm caps are there. This set also has the mixture screw tips stuck in the carb bodies. I didn't attempt to remove them so the tips are still stuck in the carb bodies. I'll attach a couple pictures. $50 CAD plus shipping.
  2. Novascotiamark
    Nova Scotia, Canada
