1980 XJ650 Carb Tuning
Discussion in 'XJ Technical Chat' started by Dave30, Oct 7, 2020.
  1. Dave30
    Dave30 Member
    Newport News
    I think i actually do have some wire on a spool around. I also have metric feeler gauges but will need digital calipers and hemostats. Just gasket and sealant as well as those rubber donuts on the bolts that hold the cover down. There isn't a ton of space between the valve cover and the frame, I'm guessing I can still remove it but very carefully. Will be interesting to see how crispy the old gasket will be!
    There is plenty of room to remove the valve cover with the engine in the frame. You might need to remove the horn from the frame (I did to make it easier to pull the cover off).
  3. Dave30
    Dave30 Member
    Newport News
    K-Moe exactly, I saw the horn on there and it's gonna have to come off. Alright i'll give the valve clearance reading a shot this weekend, just need the calipers and hemostats. Will report with the findings!
  4. Huntchuks
    Huntchuks Well-Known Member
    East Rochester, NY
    Curious what you need calipers for? Also you said you wanted to make all the mixture screws the same. You can't do that by aligning the slots because the threads in the holes will not be the same. The only way to make sure they are the same setting, as a start point, is to turn them in to a light bottom and then turning them out the same amount of turns.
    Franz likes this.
  5. Dave30
    Dave30 Member
    Newport News
    I was told to remove the shims and measure them with calipers in the event the numbers are worn off. I did reset the screws, one was higher than the others so i spun them all in and turned 3.5 turns out.
  6. Huntchuks
    East Rochester, NY
    It's not too likely the numbers will be worn off but calipers would not be the best choice for fine thickness measurement. You would be better off with micrometers.
  7. Dave30
    Dave30 Member
    Newport News
    Ill see if i can spot those at the hardware store this weekend should i find any shims missing numbers.
  8. k-moe
    Either works. The shims don't wear in the middle.
    You'd be surprised how many shims got installed with the ink-stamped numbers facing up.
    About 10% of my personal stock have my handwritten numbers on them.
  9. k-moe
    Baseline is 2.5 turns out, with most ending up between 2.75 and 3.00 turns out.
  10. Dave30
    Dave30 Member
    Newport News
    Thanks K-Moe, will correct them a turn in tomorrow. 3.5 was what some of them took to spin back in. I have wire and feeler gauges so at minimum i should be able to read the shims tomorrow and post results.
  11. Huntchuks
    East Rochester, NY
    Calipers are harder to get a good measurement and are only accurate to .0005" or the metric equivalent. Mics are easier to get a good reading and can read to .0001". Convert the measurement to metric and will be more accurate than calipers. Same reason to use metric shims as opposed to standard.
  12. k-moe
    All true, but the required resolution for shim changes is only to 0.05mm (0.002"). More resolution than required to read that isn't needed, and calipers are a more versatile tool. I do have both, but then I have need for a micrometer more often than most hobby mechanics.
  13. Dave30
    Dave30 Member
    Newport News
    Alright, so I've taken measurements and after seeing some other people's measurements I'm wondering if my gauges don't measure in fine enough increments. From 1-4 my measurements are:
    1. I .08mm E .10mm
    2. I .10mm E .13mm
    3. I .10mm E .10mm
    4. I .04mm E .10mm
    Also if these measurements are too broad, could someone suggest a range I should be looking for in order to get better gauges?
  14. k-moe
    If you're using metric feeler gauges then you're doing it right. A fair number of people use SAE feeler gauges, which works, but isn't ideal.
    #1: Intake is tight, Exahust is very tight.
    #2 Intake is tight, Exhaust is tight.
    #3 Intake is tight, Exhaust is very tight.
    #4 Intake is very tight, Exhaust is very tight.
    Odds are that you will be able to swap at least some of the exhaust shims to the intake side.
    Next step is to pull shims one at a time and make a chart of what's installed where.
    Then figure our what can be swapped, and what shims you need.
    Use the chart in the following thread. In-spec is In-spec. Use the size of shims that the chart calls for.
    bigfitzs-airhead-valve-adjustment-with-pics-parts-i-ii.116006
  15. Dave30
    Dave30 Member
    Newport News
    Thanks K-moe, I'll pull them out after lunch and see about getting some numbers.
  16. Dave30
    Dave30 Member
    Newport News
    Ok got the shim numbers, luckily all were legible!
    1. I Y280 E Y265
    2. I Y275 E Y250
    3. I Y275 E Y270
    4. I Y285 E Y 280
    So how i read the chart these would be the replacement numbers:
    1. I 275 E 255
    2. I 270 E 245
    3. I 270 E 260
    4. I 275 E 270
    Meaning that after I swap the 3 I have on hand I will still require:
    245
    255
    260
    270 x2
  17. k-moe
    Your spot-on. Start a conversation with @hogfiddles with a list of which shims you need.
  18. Dave30
    Dave30 Member
    Newport News
    Conversation started! Ill also see about getting replacement gaskets for the side and valve covers.
  19. Dave30
    Dave30 Member
    Newport News
    So the new gasket and shims should be arriving this Saturday and I'm looking forward to vacuum syncing the carbs afterwards. Once that's done i want to go through some safety items with you guys to make sure its not a better running death trap ie. brake lines/drum brake shoes.
  20. k-moe
    Check the date codes on the brake lines. Replace if over 4 years old (unless they are teflon lined/steel braided).
    Rebuid the master cylinder and calipers.
    Replace the rear brake shoes (older shoes will delaminate from the backing plate, and make you go BOOM).
  21. Minimutly
    Minimutly Well-Known Member
    West Wales, uk
    Where does this 4 yr old replacement of brake lines come from? Sounds like overkill to me, 8 or 10 yrs would sound more realistic?
  22. Dave30
    Dave30 Member
    Newport News
    I got a replacement brake lever and master cylinder already but will check it again. I have new OEM brake lines and rear brake shoes coming from Len. I also forgot to order the cam-end plugs so I cant put it all back together today. This may be a sign from divine powers as by the time I get the plugs ill also have the new brake lines/rear drum shoes. No big deal I almost have my other bike up and running. Todays objective is to replace the shims!
  23. k-moe
    From Yamaha.
    It's truly scary how many motorcycles still have their original rubber brake lines after 20, or 30+ years.
    Why You NEED TO REPLACE Original brake lines w/pics
  24. Minimutly
    West Wales, uk
    I kind of guessed that, but it was written 40 years ago, surely the material spec has improved many times since then? What do yamaha specify for more modern times? Allways assuming (that word again) that the lines you can buy now are more modern?
  25. XJ550H
    i would think if you looked in a newer factory repair manual for a newer bike you would find that answer.
  26. k-moe
    Again...it's scary how many motorcycles still have the original brake lines on them after 20 or 30 years.
    They may be more often overlooked than valve clearances.
    My son's 2003 Honda Shadow also called for brake lines to be replaced after less than 10 years (The service manual is still in a box somewhere or I'd quote the actual interval).
  27. Franz
    Steel brake lines that are corroded should be picked up at the MOT test here on older cars in the UK. Motorcycles because they don't have steel lines that can corrode pass if they are not leaking. Sometimes it is easy to overlook the fact that lines are old on our bikes.
  28. Dave30
    Dave30 Member
    Newport News
    New shims are in the bike! Looks like brake lines and rear drum shoes will get here just before I put the valve cover back on.
  29. Dave30
    Dave30 Member
    Newport News
    Update: I got the valve cover back on the bike, replaced the front brake lines, and also replaced the rear shoes. They were bad however I simply didn't want to chance something bad happening. I tried to start the bike in order to get it synced and the battery was so low it wouldn't crank. No big deal, so I bought a new one because I didn't trust the previous owners work after seeing some of the stuff he did while fixing it. Put the new battery in, and now the main fuse pops every single time I try to reconnect the negative side. Perhaps the fuses I'm buying aren't the correct type.. they are 20A AGC Fuses but they look different than the one I pulled out of the bike. That one has fat ends with a thinner middle. The new ones are thin all the way across. I would be lying if I said this didn't completely ruin my day. I finally get it all together and now some unknown electrical issue has stopped be right before getting it back on the road.
  30. Minimutly
    West Wales, uk
    Retrace all your steps to find what you did to cause this. Start with battery polarity -ve to earth....
  31. Dave30
    Dave30 Member
    Newport News
    So I looked at the battery closely, the one that the parts place said fit my bike has the positive on the right. I'm an idiot, no wonder the fuses were popping. SO I got one with the correct terminal placement. There is still an issue even before I switched the batteries which I'm hoping is solved by charging the new one I got. The bike would barely turn over to the point the motor would stop moving and you could hear liquid, presumably fuel being squirt in the carbs or around that area. I will try again when the new battery is charged and installed but i hope nothing else has died on this thing.
  32. Minimutly
    West Wales, uk
    Yes you are an idiot, but the consequences of your actions may not yet have shown themselves yet. The tci is transistor - the "t" in tci. I suspect it won't have enjoyed being reverse polarity'd.
    And to go back up to your comment on " "you could hear liquid.....". This was NOT liquid, there is nothing to squirt it, it was your starter crying in distress, either from not having enough current to drive it, or not getting the available current into the rotor. Most likely due to low battery, but maybe it needs looking at?
  33. Dave30
    Dave30 Member
    Newport News
    I'm charging the new battery right now so I'm hoping it was simply the low battery. Luckily the fuses were popping instantly when I was hooking it up backwards so any damage, if any, was minimal. I rode this thing around right before I took the top end apart and replaced the brake stuff and even then it would sound lazy when starting so I'm hoping it was simply a low battery. We shall see tomorrow... Idiot, out.
  34. Minimutly
    West Wales, uk
    To be fair your parts supplier tee'd you up to make this mistake, but it was still a fundamental error, hope you haven't fried your tci...
    Good luck with it.
  35. Dave30
    Dave30 Member
    Newport News
    Alright, so I charged the battery, mounted it and tried to start the bike. It was still majorly sluggish, and ultimately the engine stopped turning, now all that happens is the neutral and oil level light come on. This behavior was visible BEFORE I even switched the polarities like a dumb. So at this point its got to be electrical right? OH also new development, I tried to use a rubber mallet to tap the back end of the fuel tank to seat it onto those rubber studs and now there's a pinhole in the back corner of the tank leaking fuel. Hidden rust in the bottom of the tank perhaps. If so is that even fixable or would it be easier to get a new fuel tank as a whole?
    Edit: I don't think this is fixable nor would I want to put some sort of temporary fix on the tank just to have it come apart later or worse, clog all the fuel systems I just replaced/cleaned. At this point I'm at a decision to get a new tank and hope the work I've done to it thus far makes it run or abandon the project and sell the bike. I'm just unsure now.
  36. Dave30
    Dave30 Member
    Newport News
    Ok. I am going to attempt to remove the rust on the inside of the tank and seal it with stuff that says it seals pinholes. Its cheap and hopefully it works. I also found a new starter solenoid for 10$ I will try when it comes in. I'm going to work on my other bike next week, this maxim is an emotional rollercoaster.
  37. The Blackwatch
    The Blackwatch New Member
    Pull your starter motor and clean it. Checking your carbon brushes and your insulating washers. This may be the cause of the previously sluggish turnover of the bike and the not starting but have neutral and oil light issue you have now.
  38. k-moe
    Only one fuse is 20 amps (the main). All others are 10 amp.
    What brand of tank liner are you using? Kreem is total crap. Don't waste your money on anything other than Caswell or Red Kote. Use masking tape on the hole so the liner doesn't leak out.
  39. Dave30
    Dave30 Member
    Newport News
    So I used a small patch on the outside and put a bit into the hole, forgive me it was JB Fuel Tank weld. Its cured over 24 hours now and appears solid, its also ugly but its at the back corner of the tank where you really wont see it. The cleaner, rust remover and sealer all came together from KBS. I went with that because everyone has their own stuff they use and process and I figured id have less of a chance to screw something up if I went with a package system.
  40. Dave30
    Dave30 Member
    Newport News
    I'm working on the tank right now, I got some Red-Kote since it seems well liked. Otherwise I installed the new starter solenoid and now the bike clicks audibly when the ignition is turned but just the Oil light comes on. So I cleaned the side stand switch, bike is in neutral, clutch is pulled out of habit and still just a click. I'm putting the battery on a charger right now just to make sure it didn't die in a week of inactivity but that seems unlikely. Before I did anything electronic the bike barely turned over and ultimately stopped altogether. New solenoid happily clicks away but nothing happens afterwards.
    Edit: Solenoid bypass does nothing, perhaps the starter motor being gummed up is why it gradually stopped starting over time.
  41. k-moe
  42. Dave30
    Dave30 Member
    Newport News
    Already pulled and rebuild kit ordered :) going to seal the tank once it dries out hopefully tomorrow.
  43. Dave30
    Dave30 Member
    Newport News
    Awesome news, rebuilt the starter motor with the kit I bought. The copper was completely black along with the rest of the armature and upon cleaning I saw the copper was in pretty rough condition. I sanded it the best I could to make it smooth and replaced the brushes as the old ones were reduced to slivers. Put it back together and assembled to the bike, turned it on and with a bit of praying... pressed the ignition. It turned over at least twice as fast as it used and sounded 10x better! Absolute victory for the night, gas tank is dry and ill be putting some Red Kote in it tomorrow, there is a tad bit of surface rust left after the acid bath in some spots but it says you should be able to put it over some rust and it will seal it.
    chacal likes this.
  44. Minimutly
    West Wales, uk
    Next you should pull the plug on the outside (one or four), set it against the head and crank it over to check for spark. If by some miracle you still have one, do the same on cyl 2 or 3. THEN put the tank back on. If you don't have sparks you should check fuses, power to coils and tci before condemning anything.
  45. Dave30
    Dave30 Member
    Newport News
    Bike is back together and starts strong! No more waiting for the battery to die while starting. I made sure the spark is good as well. Now it's on to tuning! It doesn't seem to idle without choke right now but I only got about 30 minutes to work with it before I had to go to work. I tried vacuum tuning it and I'm unsure if I was lucky or if it simply wasn't set up right but all 4 needles were vibrating in the same direction. I do also have a colortuner that may help me determine if I need to adjust the mixture screws which are out 2 3/4 turns. Adventures for tomorrow!
  46. XJ550H
    thats a known issue and yamaha makes a fix for it
  47. Dave30
    Dave30 Member
    Newport News
    I was able to figure it out with the assistance of another member. The starter motor was in desperate need of a rebuild and afterwards it worked just fine.
  48. XJ550H
    if you look at the battery schmatic you will see adaptor bars because the original batterys have a different set up on the battery posts then replacments (reversed)
    so you end up with extensions on batterys to fit them instead of a proper length battery cable to fit directly. just one of the quirks of yamaha. they could have just offered longer cables for when you replaced the battery
  49. Dave30
    Dave30 Member
    Newport News
    Yes the store I got it from was able to give me the same battery but with the terminals swapped. Convenient, although I would have rather gotten the correct terminal setup before I potentially fried my electronics. Its also tight fit but I can still get the covers over it. So a new battery, starter solenoid, coils, wires, plug caps, plugs and rebuilt starter now means the bike starts very quickly which is awesome. It still has the old fuse box which aside from the dust that was on it seems to be working just fine.
  50. Dave30
    Dave30 Member
    Newport News
    Update: So I was able to ride it without any issues for the first time today. It takes a bit to warm up but I can ride it with a bit of choke on until its warm and then it does ok. There still must be some kind of issue as I can get it to idle at 1500-2000 rpm no problem but if it falls below that it will slowly die. Aside from that I pulled the spark plugs and they're all very close to being the same condition which is also great! It pulls strong and no longer backfires on deceleration as well! I ordered new tires to put on, Dunlop 404's as the ones on it are from 2007. Overall extremely happy that its come this far. I cant thank all of you enough for the assistance and will be coming back if there are any more issues. For now I'm just going to deal with its little quirks and enjoy the rides.
    Franz and Rooster53 like this.
