1981 Maxim XJ 650 restore project
Discussion in 'XJ Technical Chat' started by Glen F., May 13, 2019.
  1. k-moe
    HOW TO: Rebuild Your Master Cylinder
    Rebuild the calipers too. They will be just as bad.
  2. Glen F.
    Glen F. Active Member
    Winnipeg Manitoba Canada
    I looked at the haynes book, and turns out I had the choke and throttle cables backwards. Changed them and it ran great. Slaps forehead open palm.
  3. XJ550H
    your welcome. always check the simple things first
    Glen F. and k-moe like this.
    We've all done it at least once.
    Glen F. likes this.
  5. XJ550H
    maybe twice
    k-moe and Glen F. like this.
  6. Glen F.
    I took the master cylinder off. All crusty and dried out. Cleaned it up a bit, but one of the two holes in the cylinder doesn't seem to be drilled right through. Is this normal? I thought one was for a return. Going to pick up some brake cleaner and clean it up good. The piston boot and seals are still very soft.
  7. firebane
    firebane Active Member
    Calgary, AB
    They just magically fit in either spot!
  8. Glen F.
    I should have said in the reservoir.
  9. Glen F.
    Master cylinder all cleaned up. Sight glass is a bit swollen. I'll replace it another day. Trying to remove the front tire today. Took out the cotter pin, took off the nut, loosened the pinch bolt and took off the caliper and speedo cable, but I can't get the axel out. Tried to smack the threaded end with a block of wood and a mallet, but it's in there good. Any helpful ideas out there?
  10. XJ550H
    c
  11. Glen F.
    Well that was helpful. Lol
  12. Glen F.
    Well, I used some heat on the shaft. A few light taps with a hammer and out it came. I don't think it has ever been removed before. I applied a thin layer of white grease to the shaft after cleaning it up. Waiting to get a new front tire to replace the original. One day at a time.
  13. Glen F.
    Tried getting the rear wheel off tonight. I got the axel out, but the wheel won't budge. Any help would be appreciated!
  14. k-moe
    Rubber mallet. Tap around the side of the wheel as you turn it. Not too hard.
    Drop the air pressure to help the tire clear the fender when you roll it out.
    Also, use moly grease on the splines after you clean them (and on both axles).
    Glen F. likes this.
  15. Glen F.
    Tomorrow is another day. I will give it a go.
  16. Glen F.
    Seeing as my bike is a shaft drive, should I be pulling the tire straight back?
  17. Simmy
    With the axle removed you need to move it away from the final drive unit.
    The wheel and final drive have mating splines which need to be separated, this is what K-moe suggested with the rubber mallet.
    Glen F. likes this.
  18. Glen F.
    So if I understand you correctly, I am not pulling the wheel straight back, but trying to move it away from the final drive on the rear brake side.
  19. Simmy
    correct, move it away from the final drive, your brake plate (entire wheel) will be touching the RH side of the swingarm at that point and will drop right out.
    Glen F. likes this.
  20. Glen F.
    Seeing as has probably never been taken off before, would it be ok to hit it up with some PB blaster and let it sit for a while?
  21. k-moe
    Only in the axle bore. The penetrant can't get to the splines from the outside at all, but it can help free-up the spacer. You don't want it anywhere near the brake drum (right side of the wheel).
    Glen F. likes this.
  22. Polock
    i take the right shock off, just for some extra wiggle room
    Glen F. likes this.
  23. Glen F.
    Just a few dozen taps on the tire with a rubber mallet and off it came. Brakes aren't rusty at all, but going to change them up anyways. Thanks for all the help everyone! Much appreciated!!!
  24. Glen F.
    So after spending more than a hour in +30c heat, I can't seem to get the hub to go back in all the way. Is it possible when I was tapping out the axel, I might have pushed something into where the bearing is?
  25. Glen F.
    Tried again this morning to get the wheel back on with no luck. Any help would be fantastic.
  26. XJ550H
    there should be a spacer coming out of the hub see if yours is out to far pull it out clean the hole lube and reinstall it is about 3 inches long
    it rests against the wheel bearing
    Glen F. likes this.
  27. Glen F.
    I'll check again, but the spacer doesn't seem to go in any farther. I'll try lightly tapping it to see if it will go in any more.
  28. k-moe
    The spacer should not need any tapping, and should not be tapped or it can deform.
    Pull it out and clean the bore with solvent.
    Getting the drive splines to line up can be a bit tricky, and that may be what's keeping the wheel from sliding into place. Wiggle it...just a little bit...
    Glen F. likes this.
  29. Glen F.
    Wiggled it...just a lot, but it went back in. Thanks for the help!!!
