1981 maxim xj550 front sprocket question
Discussion in 'XJ Technical Chat' started by Hardy12000, May 22, 2017.
Tags:
  1. Hardy12000
    Hardy12000 New Member
    Northern michigan
    Hello all,
    So I snapped a chain the other day, bout a real nice EK chain, and when I went to put the new one on I realized nothing was holding the front sprocket on. It has the retainer washer and bolts but that's it. I put like 600 miles on it like that, and I'm wondering what piece I'm missing, if any. I have to assume I am. The sprocket can just move on its own. Any Info would be appreciated. Thanks
  2. lostboy
    lostboy Well-Known Member
    Tillsonburg, Ontario, Canada
    If you can pull the front sprocket off the retainer maybe bad. The retainer goes on the splines of the output shaft then turns about a 1/8 th of a turn in a grove to keep the sprocket on the shaft.
    Hardy12000 likes this.
  3. Hardy12000
    Northern michigan
    Ok. The sprocket pulled right off with the retainer on it still. The last owner said he changed the sprockets. Is it possible he put it on upside down, or some other messed up way that it wouldn't grip, even if it is bolted onto the sprocket. The teeth on the retainer line up to the sprocket perfect when it's bolted on and it just slides on. How would I turn it?
  4. lostboy
    You need a new retainer. Click the upper right flashing icon to get the best parts and service you have ever witnessed.
  5. Xjrider92117
    Xjrider92117 Active Member
    San Jose Ca
    If you bought a nice new chain... Nice new sprockets would go well with it. ;) If they aren't already. Make sure the chain is properly adjusted as well.
    Stumplifter likes this.
  6. Hardy12000
    Northern michigan
    The sprockets were replaced not long ago. They look real good. And I have the chain at about 1.3-1.5 inches of slack. I thought it seemed loose. But from the info I got its good
  7. XJ550H
  8. Hardy12000
    Northern michigan
    and those will fit my 81 550 maxim?
    Just have to be sure, it doesn't say anywhere on that page
  9. XJ550H
  10. XJ550H
    you can order on line or just go to dealership. my dealership does not charge shipping if he has to order the part, dealer may have one in stock
  11. Hardy12000
    Northern michigan
    What category would it be under. There's no sprocket/chain section
  12. XJ550H
    do you have a factory repair manual or clymers repair manual?
    transmission
  13. Hardy12000
    Northern michigan
    I do not
  14. XJ550H
    its just an kind of oval shaped part with mating splines that slide on the shaft turn to aling bolt holes and bolt on
  15. XJ550H
  16. Hardy12000
    Northern michigan
    I know what it is. I replaced the chain.
    I bought the new pieces
  17. Hardy12000
    Northern michigan
    That was my issue. I didn't remove my bolts and retainer from the sprocket when I took it off. It just kinda slid right off.
  18. XJ550H
    yes I understand that the retainer is made to wear out instead of the shaft. I would stop riding it for now
    check your inbox at top of page
  19. Hardy12000
    Northern michigan
    Definitely not riding. That was a pricey chain and I want it to last. Retainer and bolts ordered. Hopefully will have them in time for the weekend
  20. XJ550H
    did you get an oring or x ring chain or the standard chain
  21. Hardy12000
    Northern michigan
    Got the EK Quadra X Ring.
    Used some wd 40 to clean the white grease off then lubed it with o ring safe, wax based, Teflon chain protector and lube.
  22. Timbox
    Love that stuff! Get your chain warm and then hit it with that stuff, less noise and does not hold dirt as much as wet lube.
