1981 XJ650 Alaskan Bobber Project
Discussion in 'XJ Modifications' started by Roguesaint, Nov 1, 2012.
  1. Ted
    Ted Member
    Sioux Falls, SD
    Yeah looks great man! Where'd you get the fender? TC Bros?
  2. aktoddc
    aktoddc Member
    Kenai, Alaska
    the fender came from a local trailer supply store…just your basic 6" wide steel trailer fender…..its fits surprisingly well.
  3. Ted
    Ted Member
    Sioux Falls, SD
    Huh. I've seen some pretty ugly trailer fenders on these bikes but that one looks great!
    (googling local trailer supply stores :D)
  4. aktoddc
    aktoddc Member
    Kenai, Alaska
    Yeah, its a little flatter than I would have liked, but it came with the bike so I decided to use it:)
  5. Voxboy
    Voxboy Member
    Canada
    Awesome build. I have the same bike and will be doing the same backbone mod. I was wondering about the neck gussets. I find them somewhat bulky looking. Would it be possible for me to cut out the entire gusset section on the neck and replace with thicker gussets. The material on the neck gussets is pretty thin, but....there was reinforcement with the triple BB. Just a thought.
    Not exactly but something like this...
  6. Orange-n-Black
    Memphis Area
    Something like that would work well and thicker material would be a must if eliminating the triple backbone.
  7. aktoddc
    aktoddc Member
    Kenai, Alaska
    I was going to remove the stock gusseting all together and run a gusset tube as shown in your picture, but once the tank was mounted the stock gusseting didn't really look that bad, so I left it intact.
    -Todd
  8. Orange-n-Black
    Memphis Area
    Got to remember the stock gusset thickness was engineered for the triple backbone. So you need to either add a single bar under the backbone(similar to the same place as the triple), or use thicker gusset material. Then you need to make sure the back is strong enough too. In your case, it probably is.
  9. peganit2
    peganit2 Member
    Davison Mi
    The concentricity of that fender around the tire is PERFECT!
    It's a make or break detail that gets broke more often you would hope.
  10. aktoddc
    aktoddc Member
    Kenai, Alaska
    Battery box before welding…….
    I couldn't think of a reason not to just weld it to the frame….so I did!
    peganit2 likes this.
  11. Orange-n-Black
    Memphis Area
    Look's nice.
  12. Voxboy
    Voxboy Member
    Canada
    Enjoying this build thread...a lot. Any updates?
  13. Voxboy
    Voxboy Member
    Canada
    Agree. I find that once the bike is chopped in the back the stock tank makes the front half of the bike look "bloated" as well once the bobber seat is added you can see the tab, but even if its cut the tab area of the tank does not flow due to the original seat covering it. I have seen a few that are ok.... but custom tank is much nicer. I love this tank.
  14. Skwerly
    Skwerly Member
    Yucaipa, CA
    This is definitely a cool build. subbing.
  15. aktoddc
    aktoddc Member
    Kenai, Alaska
    Sorry guys….no new updates. I tore the top half of the motor down due to low compression numbers. Looks like I may get by with just a hone job and new rings. The head has some scoring on one of the cam seats, so I'm looking for a replacement head also.
    -Todd
  16. peganit2
    peganit2 Member
    Davison Mi
    You HAVE to finish this!
    (no pressure;))
  17. Havoc09
    Havoc09 New Member
    Anchorage AK
    Looks great! cool to see another XJ mod in Alaska! Im in the middle of my first build.
    maximmac likes this.
  18. maximmac
    maximmac New Member
    Washington
    Yeah good work... I just started my 82 550 max mod yesterday... so excited, I cant sit still.
  19. aktoddc
    aktoddc Member
    Kenai, Alaska
    Fatty front tire conversion done…really like the stance of the bike now. Less of a chopper-ish look and more burly. It also lowered the front down to match the back.
    Comparison of the stock front wheel/tire to new. The new tire is a 120/80-16. Its about 1.5" wider than the original.
  20. aktoddc
    aktoddc Member
    Kenai, Alaska
    Spin-on oil filter conversion kit from XJ4ever installed. Highly recommend this item for ease of oil changes and better filtration. Still waiting on valve stem seals before I can put the top end together.
  21. Skwerly
    Skwerly Member
    Yucaipa, CA
    Sweet! Lawzy, it's fun watching this bike become.
  22. Voxboy
    Voxboy Member
    Canada
    Looks great. Im picking my frame up tomorrow from the welder. When you have time, would you elaborate more on the front wheel conversion. Is that a kit you bought from some guy who used to be on this board or is that your own fabrication. Thanks
  23. aktoddc
    aktoddc Member
    Kenai, Alaska
  24. Voxboy
    Voxboy Member
    Canada
  25. Orange-n-Black
    Memphis Area
    You can always put a bigger tire on your original front rim. My son in law put a 110/90-19 on his 700Max, looked good and handled better. Had to shim the front fender/brace, but if your going fenderless that wouldn't be an issue. If you go fenderless, I recommend a fork brace, these front ends need them.
  26. peganit2
    peganit2 Member
    Davison Mi
    Dude I like your taste. The slightly smaller front wheel is the right way to go when doing the fatty front tire.
    And you talked me into the spin on conversion.
  27. rocs82650
    rocs82650 Well-Known Member
    Middle Tennessee
    +1.
    Gary H.
  28. peganit2
    peganit2 Member
    Davison Mi
    Just had a thought; Is there any reason you can't lower the triple tree clamps on the fork tubes to even out the bike even better? As long as you don't interfere with the travel, why not?:confused:
  29. aktoddc
    aktoddc Member
    Kenai, Alaska
    If you look close in the pics, you can see that I have already raised the fork tubes up into the tree till they are just about touching the drag bars. Probably about 3/4" lower than stock. I will be able to fine tune the ride height once I get the motor back in and see where I'm at. I'm a little concerned about clearance for the pipes, the bike is gonna be really low!
    -Todd
  30. MattiThundrrr
    MattiThundrrr Not a guru
    America's friendly hat
    Damn. I looked too closely at the pics. Now I want your bike lift/work table. Sweet setup. Also, what's the info on that Phazer sled in the background? Oh yeah, bike looks good too! Stance is pretty sick. You gonna run a fork brace? When's the engine going back in? No pressure, I just wanna see how it looks in there!
  31. aktoddc
    aktoddc Member
    Kenai, Alaska
    The lift table was purchase through these folks:
    http://www.cemlifts.com/motorbike-lifts/
    I paid $700 and it comes with a very nice wheel clamp, rear drop-out and scissor jack. I'm very impressed with the quality/sturdiness for it being constructed overseas.
    I picked up that old Phazer this year for my son....he graduated from a Sno Sport...I love those old Yamaha machines!
    I hadn't planned on running a fork brace, but may after the recommendation of many on the board. The previous owner ground off the fender mounting tabs, so I'll have to fabricate some new ones. Hoping to get the motor installed in the next couple of weeks. I'm also building an XS400 café for my son and its taken priority over my bike:)
    -Todd
  32. MattiThundrrr
    You sound like an ok dad, I guess! Interested in adopting a full grown adult who's still kind of a child?
  33. peganit2
    peganit2 Member
    Davison Mi
    Harbor Freight has those lifts on sale with a coupon for $299 USD.
    Yeah that Phazer is cool too.
  34. aktoddc
    aktoddc Member
    Kenai, Alaska
    Harbor Freight definitely does not have lift tables like mine for sale. The ones for $299 are junk!
  35. MattiThundrrr
    I don't even know what Harbor Freight is. Never seen one in Canada!
  36. aktoddc
    aktoddc Member
    Kenai, Alaska
    Hello All,
    Well, I would like to get some input form the group. I finally got the top half of the motor together and I'm having some issues with the cam timing. I can't get the marks on the cams to line up perfectly, they are off about .035" on the intake cam and .025" on the exhaust. Is this enough to cause a problem with timing? I had the head milled to take out some imperfections on the sealing surface, the machinist said he only took about .005" off….maybe he took off more and is not telling me? I have verified TDC on the timing indicator with a dial indicator on the piston, so I know its spot on. I've rotated the motor several times by hand and everything else seems fine. I think if I jump the cams 1 tooth, it will be way off. Here are a couple of pics:
  37. aktoddc
    aktoddc Member
    Kenai, Alaska
    Anyone have input on the cam timing pics? Getting back on this project, now that summer is winding down!
  38. rocs82650
    Middle Tennessee
    You missed a step.
    "Once the cam caps are fully tightened make any final adjustment necessary to align the cam timing dot with the fixed index mark on cap No 2. Spanner flats are provided on the cams for this purpose." Hope this helps.
    Gary H.
  39. aktoddc
    aktoddc Member
    Kenai, Alaska
    I'm not following you? The pointer is at verified TDC, if I move the cams one tooth either way, they will be off even more.
  40. rocs82650
    Middle Tennessee
    Got a manual? Go back and read the section for assembling the head. Hope this helps.
    Gary H.
  41. rocs82650
    Middle Tennessee
    I was at work on break when I posted this...had to get back. The above step should have been done prior to lifting the sprockets/chain onto the locating shoulders of the cams. Haynes Manual Pg. 108, paragraph 6. Hope this helps.
    Gary H.
  42. aktoddc
    aktoddc Member
    Kenai, Alaska
    Head was assembled using the service manual. I wonder if its possible that the timing chain is stretched?
    -Todd
  43. rocs82650
    Middle Tennessee
    It's possible. So your saying after you dropped the cams in and tightened the caps you used a wrench on each cam to align the dots with the cap arrows prior to locating the sprockets and chain? I'm asking because the dots are where they should be before doing this step.
    Gary H.
  44. aktoddc
    aktoddc Member
    Kenai, Alaska
    Yep…after tensioning the chain and aligning to the TDC mark, the pics show were the cams ended up at.
  45. rocs82650
    Middle Tennessee
    Did you remove the slack in the chain via the exhaust sprocket prior to installing it? Did you rotate the engine to align the C on the timing plate with the pointer before you installed the tensioner?
    Gary H.
  46. rocs82650
    Middle Tennessee
    If this ⬆ doesn't solve the problem we may need chacal, k-moe, hog, polock, toomany, bigshank, bigt or other members to tell whether the chain jumped a tooth. I'm thinking you would have visually seen it jump when you rotated the mill. I could be wrong.
    Gary H.
  47. jayrodoh
    jayrodoh YimYam
    Cleveland
    I ran into the same issue tonight and thought of this thread since I ended up exactly where you are at. Are you pulling the slack on the exhaust side or intake side?
    I mistakenly pulled the intake side when putting my head on but was successful by setting the intake cam as shown below with the expectation that the tensioner would make up the difference:
    Installed the tensioner at the C mark and 2 revolutions later I had this:
    rocs82650 likes this.
  48. rocs82650
    Middle Tennessee
    I can't see the images.
    Gary H.
  49. jayrodoh
    jayrodoh YimYam
    Cleveland
    Fixed.
  50. Polock
    if you rotate the engine a few times in the normal direction, then stop at tdc and the marks are the same as the pictures, your good to go. you should also check the pointer on the case to be sure "T" is really tdc. bring the piston almost to tdc then with a plastic straw feel when it dwells at the top and in normal rotation it should move down as the rotor passes the "T" mark. It could have gotten bumped it it's past life
