1981 xj650: oil filter seals from fram bad?
Discussion in 'XJ Technical Chat' started by Alain, Jul 27, 2017.
  1. Alain
    Alain Member
    Is it just me or are the provided o-ring seals provided by FRAM (ch6003) bad? I'm talking about the larger o-ring seal that comes folded in the box. The one that goes around the filter case.
    The first time I did it, I had a leak around the filter case that no matter how tight I tightened it, kept leaking. Like oil very slowly leaks out during riding causing small drips when the bike is parked.
    Then I bought an OEM Yamaha o-ring and it solved the problem.
    Next I changed it again with a new FRAM filter and it's been leaking for 6 months.
    Is there something I'm missing about the seals? Am I supposed to leave it soaked in oil to "moisten" it? On my notes, I noted that the oem oil seal is slightly thicker.
  2. Simmy
    Your experience is the same as mine. Throw the Fram o-ring in the trash.
  3. Stumplifter
    Stumplifter Well-Known Member
    near Irma, WI
    Used the CH6003 for many years, smear a little oil on it, determine which side is going to lay best in the groove (cause like you said they kinda fold it in the box), button things up and no leak problems.
  4. Chitwood
    Chitwood Well-Known Member
    Fort Atkinson, Wisconsin
    I've been using a Napa gold (wix) filter simply because it's readily available to me and I've had no problems with leaks or anything
  5. Alain
    Alain Member
    I bought a Yamaha OEM large O-ring oil seal (93210-87723) and that solved my leak problem. Unfortunately, the FRAM O-ring (from filter CH6003) , twice i tried, doesn't work for me.
  6. BigT
    BigT Active Member
    Airville, Pa
    I have never had a problem with the frame o-ring, it can be a real pain to get to lay flat after it's been smashed into the box, but it always seems to seal well.
    Just my experience.
  7. Jetfixer
    I upgraded to xj4ever spin on oil filter conversion kit...no leaks (and cool factor :cool:)
    TheCrazyGnat and Stumplifter like this.
  8. cgutz
    cgutz Well-Known Member
    SE South Dakota
    I've never had an issue with Wix brand filter rubber gaskets.
  9. Toomanybikes
    Tsawwassen bc
    We should band together and send fram an email about there crappy oring.
    They have an 800#
  10. MattiThundrrr
    MattiThundrrr Not a guru
    America's friendly hat
    Does the spin on filter provide the same cooling as the finned aluminum cover? I would think that has the "cool factor". ;) Len's oil cooler kit really ups the cool factor!
    Cooling factor?
