1981 Yamaha XJ550H Maxim Front Forks. What type I have?
Discussion in 'XJ Technical Chat' started by j_ondrusek, Apr 14, 2018.
  1. j_ondrusek
    j_ondrusek New Member
    Seattle, WA
    Hi XJ folks!
    I just opened my Maxim's front forks. Dimensions of the inner tubes: 36mm diameter, 26 1/8" = 664mm length. They are bent and pitted, not financially viable to repair.
    Looking at some aftermarket manufacturers, there is no such thing for XJ 550 Maxim. It lists 35mm (5F8-23110-00) or 36mm (3KN-23110-00) diameter, 585mm length for XJ 550 tubes.
    • Is this for the Seca?
    • OEM part # should be 5K5-23110-01-00, alas I cannot find the dimensions. Could anybody please post the correct dimensions?
    • Can you tell if my forks come from another, possibly higher model?
    • Is this potentially affecting my trial angle and should I swap back to whatever OEM tubes are?
    Thanks!
    seca 550 is a 35mm tube maxim 550 is a 36mm tube
    you could put a different fork set up on there or buy used. a 750 setup would give you a dual disk setup
  3. XJ550H
  4. j_ondrusek
    Seattle, WA
    Thanks for the reply! I know I am looking for 36mm diameter, just trying to figure out of the 664mm length is correct. Finding mixed data so far.
  5. XJ550H
    chacal or supporting vendor sells the tubes you need start a conversation with him.
    you can go to his website and email him and look up the part www.xj4ever and it will be the correct tube
    j_ondrusek likes this.
  6. XJ550H
    post a photo of your lower fork tubes to help ID them.
    unless you are going for a full restore of bike you may consider a used set off of ebay
  7. chacal
    We do have these in stock, and they are approx. 660mm in overall length:
    HCP8522 Aftermarket chrome INNER FORK TUBE, fits left or right side, for all XJ550 Maxim models, each:
  8. j_ondrusek
    Seattle, WA
    Awesome, this is exactly was I was looking for!
    I considered:
    1. used set off of eBay, unfortunately pretty much everything is pitted
    2. restoring the pair I already have, that will come to $300 for resurfacing + straightening
    3. new aftermarket set or NOS, same cost as restoring
