Wanted 1982 Seca 750 Antidive Blockoff Plates
Discussion in 'For Sale, Trade/Swap, Wanted' started by mason79, Oct 11, 2026.
  1. mason79
    mason79 New Member
    los angeles
    cleaning up my forks, and can't /don't want to put the antidive back in, and don't really want to fabricate, thank you
  2. chacal
    You can write to us at:
    info@xj4ever.com
    for more information about these products!
    NOTE: if you want to disable your anti-dive system, you will need to remove the hose from the caliper to the anti-dive unit (and replace the caliper end double-depth union bolt with the single-depth union bolt used at the anti-dive unit end of the hose) and block-off the anti-dive fluid port with this plug:
    HCP12991 Aftermarket brake system fluid port BLOCK-OFF PLUG, correct size hex-drive set-screw is used to replace a brake hose union bolt when not in use. Use 1 per anti-dive unit.
    $ 6.95
    or an even more stylish alternative is to use these custom-made BLOCK-OFF PLATES that completely replace the upper section of the anti-dive unit:
    HCP22861 Aftermarket anti-dive upper housing BLOCK-OFF PLATE, beautiful machined aluminum cover plates completely replace the upper portion of your anti-dive units, fully disabling their function. Black-anondized covers come complete with mounting screws. Sold in a matched LH/RH set. Fits all XJ750 Seca and XJ750 Euro models using anti-dive forks.
  3. mason79
    mason79 New Member
    los angeles
    just bought the bike, they already took off the brake lines, i need to fix a leaky fork seal, i don't want to need to clean out the antidive, i bought a cover kit from fast from the past, yours only covers the brake top section but leaves the bottom part attached?
    no pictures, i read thru the fork pars section today
