1982 xj550 charging problems
Discussion in 'XJ Technical Chat' started by Rebel92, Mar 24, 2017.
  1. Rebel92
    Rebel92 New Member
    Ohio
    Hello i currently obtained a 1982 xj550 it had a dead cell in the battery i ended up replacing that my voltage regulator ingnitor and my alternator brushes and stators reads 11.5 volts when running at 4500 rpm and started with 12 volts now down to 11.7 after riding 2 hours help im lost
    I think that I know what you did, and what you are asking, but I'm not totally sure.
    Would you mind adding some punctuation so your post is easier to read?
    I don't want to try giving you answers until I'm totally sure what the situation is.
  3. Rebel92
    Rebel92 New Member
    Ohio
    Ok i have replaced my battery,voltage regulator,ignitor,stator and alternator brushes it only reads 11.5 volts while running and drains the battery any ideas?
  4. XJ550H
    you replaced battery
    replaced voltage regulator
    replaced ignitor
    replaced stator
    replaced alt brushes
    did you replace stator?? or just the brushes?
    you need to clean the 2 copper rings that the brushes ride on . did you replace brushes as an assembly? springs may be week.
    read this thread first few paragraphs ELECTRICAL SYSTEM OVERVIEW: then skip down to this heading DOUBLE BONUS ROUND!! Charging System Electrical Specifications:
    ohm out your charging system as discribed in the link posted above
    also a new battery can still be a bad battery
