1982 xj650 complete engine rebuild and bobber conversion
Discussion in 'XJ Modifications' started by Eurotas, Apr 24, 2016.
  1. Eurotas
    Eurotas Member
    Edmonton
    On another note, I'm in the process of copper plating the shock springs. I haven't mentioned it yet, but the theme for this bike is going to be copper and flat black.
  2. Proar
    Proar Member
    Denmark
    funny. was actually going for a copper look myself. looks awsome so far! jealous of the fork x(
  3. Eurotas
    Eurotas Member
    Edmonton
    Lol yeah it's definitely a work in progress, hopefully I'll have it on two wheels on the ground sometime next week.
  4. Chance
    Chance Member
    Rockland, Ontario, Canada
    Hadn't thought of those two together before but ya that makes sense, nice combo colors, can't wait to see it...
  5. Eurotas
    Eurotas Member
    Edmonton
    Machine shop didn't call me today. They'll probably call me tomorrow.
  6. Eurotas
    Eurotas Member
    Edmonton
    Gonna pick up the frame on Friday! I'll post pics then with the front end all together.
  7. Eurotas
    Eurotas Member
    Edmonton
    Can someone give me the specs for the max cylinder diameter? Max out of round, max taper, etc? I want to measure the sleeves and see if they're worn out, and I need to buy new pistons and machine the sleeves.
  8. Eurotas
    Eurotas Member
    Edmonton
    Well here she is all installed. Don't ever let someone tell you something can't be done. f*** that! I'm living proof!
    d_mayes_91 and WolfknivesXJ650 like this.
  9. Eurotas
    Eurotas Member
    Edmonton
  10. Chance
    Chance Member
    That looks sharp.
    Eurotas likes this.
  11. jayrodoh
    jayrodoh YimYam
    Cleveland
    Looks great! Are you putting a dust cap over the upper bearing?
  12. chacal
    all 650cc:
    Standard bore: 63.00mm
    Limit before boring required: 63.10mm
    Taper limit: 0.05mm
    Out-of-round limit: 0.01mm
    Oversizes: plus .25mm, .50mm, .75mm, 1.00mm
    Piston-to-wall clearance: 0.03 - 0.05mm
    Max. clearance: 0.10mm
  13. Eurotas
    Eurotas Member
    Edmonton
    I'm just gonna use the stock cap as it fits perfectly, I'll need to get another one for the bottom though!
  14. Eurotas
    Eurotas Member
    Edmonton
    Damnit, I just measured one of the Pistons and I'm getting like 62.75....so what's a .25 oversize piston kit gonna cost me?
  15. Eurotas
    Eurotas Member
    Edmonton
    Hey fellas, I was thinking of doing a totally different intake set up than what you're used to seeing. I know there's probably a lot of math involved in terms of air flow, but I was wondering what you guys think.
    Since we all know the stock air box is huge, bulky, and doesn't look good. As well, the pod filters can give you a flat spot in your power curve. I was thinking of fabing up an air intake manifold made out of aluminum. Kind of like an exhaust manifold I guess you could say, and then install one large air filter on the right side of the bike. Maybe in the same spot where Harley's have them?
    I guess the purpose of this would be to allow a better amount of vacuum going into the engine, but with a cool look to it cause let's face it, the stock box is ugly and the pods can be a pain the ass to tune your engine from what I've read.
    The only thing I can't really decide on is the size of piping. I was thinking maybe 2 inches max, but what kind of constrictions would I be running up against? Is 2 inches enough? Too much? I was kind of hoping one of our members is an engineer and can give me some pointers lol.
  16. k-moe
    Do a search. There are several people who have made custom intake manifolds for the XJ series.
  17. Eurotas
    Eurotas Member
    Edmonton
  18. k-moe
    Sure, but it doesn't meet all of your criteria. The turbo intake is uglier than the aitbox you have. It's also more restrictive without having the turbo to pressurize it under load.
  19. Eurotas
    Eurotas Member
    Edmonton
    Hmm it was just an idea
  20. k-moe
    Not a bad one. The airbox is cheap enough that you could give it a try (without modifying it) and if it dosen't work sell it and get your money back.
  21. Eurotas
    Eurotas Member
    Edmonton
    Nah I think I'm just gonna fab up a two inch aluminum pipe, tig weld it, throw on a big Harley style air filter and let her buck.
  22. a100man
    a100man Well-Known Member
    Bedford, UK
    'ckin loads of money - if you can even source them. Better off looking at some better jugs/pistons off ebay and maybe spring for some new rings, they'll be about 200 USD though I would think, rings that is..
  23. Eurotas
    Eurotas Member
    Edmonton
    Yeah, I'm looking at $1400 CND just for Pistons and rings, that's absolutely insane. But people are claiming that the parts are unavailable, and that's why there's such a high cost. I call bs, cause obviously people can still get them, and so can I, but like $300 a piston? Really? I'd expect that for a car, not a bike
  24. k-moe
    They really and truly are no longer available from Yamaha. The factory supply for oversize pistons and rings dried up years ago, so everything you are finding is from someone's NOS stash, or from a manufacturer like Weisco. It doesn't matter what the piston is for, production costs are nearly the same, and short runs have to recoup setup and tooling costs faster than long runs do. Lack of demand really does drive up the price.
    You can try http://japan.webike.net. They tend to carry more parts for older japanese bikes, but you'll have a big shipping cost. You could also try a Japanese or German auction site. The XJ series still has a large following in both countries.
  25. Eurotas
    Eurotas Member
    Edmonton
    Gave that site a try, and no dice :(
  26. Eurotas
    Eurotas Member
    Edmonton
  27. Eurotas
    Eurotas Member
    Edmonton
    image.jpeg Yay my goodies finally showed up! Here they are!
  28. Eurotas
    Eurotas Member
    Edmonton
  29. Eurotas
    Eurotas Member
    Edmonton
  30. Eurotas
    Eurotas Member
    Edmonton
    DeanXJ750 likes this.
  31. Eurotas
    Eurotas Member
    Edmonton
    So what ya think boys?
  32. chacal
    I think it's great looking and super cool that you are assembling it in your kitchen............!
  33. Eurotas
    Eurotas Member
    Edmonton
    Yeah I didn't wanna be in the garage tonight haha. I sent you a pm, did you get it?
  34. Eurotas
    Eurotas Member
    Edmonton
    Forgot to put this pic up
  35. k-moe
    Well, it is still winter there.
  36. Eurotas
    Eurotas Member
    Edmonton
    Naaaaah, it'll be a balmy 75 today
  37. k-moe
    That was the overnight low here :p
  38. TheCrazyGnat
    Central PA
    Love the look so far! That copper looks good. Are you going to keep the tank unpainted like that? I like the way it looks.
  39. Eurotas
    Eurotas Member
    Edmonton
    Haha ya ya, this isn't the desert here.
  40. Eurotas
    Eurotas Member
    Edmonton
    Well the tank is bare metal right now, so no I can't leave it unpainted haha. I haven't decided on what I'm gonna do with the tank yet as far as colour goes. I was thinking of going all black with just some copper notes here and there. I dunno, we'll see as it comes more and more together!
  41. Eurotas
    Eurotas Member
    Edmonton
    So I finally finished copper plating the springs, not quite a match with the front end. I'll probably polish them and see how they turn out. If not, I might just scrap the whole idea and go to these below instead.
    TheCrazyGnat likes this.
  42. k-moe
    You may need to electroplate at a higher current.
  43. Eurotas
    Eurotas Member
    Edmonton
    Why's that?
  44. k-moe
    You get a thicker, shinier coating.
  45. Eurotas
    Eurotas Member
    Edmonton
    This is true, I'm just trying it out to see how it looks. Once it's all sort of together, I'll make the decision then whether or not to keep em. I was just super bored lol.
  46. Eurotas
    Eurotas Member
    Edmonton
    Look what we inherited boys....a gem that's been sitting for 15 years.
  47. k-moe
    I love inheriting cool things. Family stuff is the best for passing down.
    That bicycle on the wall needs a motor on it :)
  48. Eurotas
    Eurotas Member
    Edmonton
    Haha it's not mine, it belongs to my roommates gramps. We're gonna fix it up, and he gets to keep the heirloom. It's an xs 850, 3 cyl. The 3 cyl just keeps weirding me out....
  49. Eurotas
    Eurotas Member
    Edmonton
    That bike is way too small for my daughter now lol. I don't even know why I still have it.
  50. k-moe
    I do. My son's pedal bikes are in the shed. Grandkids (hopefully) will get them someday.
