1982 xj650 gas tank leak
Discussion in 'XJ Technical Chat' started by Glen F., Jul 20, 2022.
  1. Glen F.
    Glen F. Active Member
    Winnipeg Manitoba Canada
    Just came back from a nice ride and filled up before I got home. When I parked the bike in the garage, I noticed the smell of gas. Seems like I have a pin hole leak under the decorative trim on the tank. Is the anything special I need to remove the trim to see exactly where the leak is?
  2. Dan Gardner
    Minneapolis, MN
    650 Maxim? Original trim?
    Should be able to carefully pry it off.
  3. Glen F.
    Will JB Weld SteelStik work to seal the small hole?
  4. Dan Gardner
    Minneapolis, MN
    Is the leak actually in the seam? That might be tricky but I suppose it’s worth a try. Might be temporary
  5. jayrodoh
    jayrodoh YimYam
    Cleveland
    Pull the tank first and look around the petcock, could be leaking where it meets the tank and running down to the lower seam/trim section.
  6. Glen F.
    It's a small leak on the other side of the tank.
    jayrodoh likes this.
  7. Huntchuks
    Huntchuks Well-Known Member
    East Rochester, NY
    I used Seal-All on a pinhole leak on son's gas tank. It is clear and is working fine so far.
  8. Glen F.
    The leak is on the inside above the seam. I tried JB Weld. Waiting for it to cure
  9. Glen F.
    No more leak. See how long it lasts now.
  10. Simmy
    I sealed up an FZ tank with the gas tank sealer.
    If it does start leaking again and it’s not in a visible spot you can coat a sheet metal screw in the same epoxy and drive it into the pinhole. Obviously not for a showbike but it can be a permanent repair
    Glen F. likes this.
  11. Glen F.
    The leak was just above the trim on the underside of the tank. Just a small hole. Sanded it down and cleaned with acetone, then the JB Weld.
  12. k-moe
    In the long run it's better to clean and line the tank with an epoxy liner, such as Caswells.
    Rust never sleeps, but it can be cut off from its oxygen source.
    Glen F. and Andrew Nichols like this.
  13. Andrew Nichols
    Andrew Nichols Active Member
    Minneapolis, MN
    I've had good luck with POR15 tank sealer after letting the tank sit full of vinegar for a week first.
  14. Franz
    Has anyone with metal working skills tried making an aluminium tank for their XJ?
  15. Glen F.
    I did coat the tank before with Redcoat. I didn't want to put it on to thick and cause problems. Maybe it was too thin. Is it possible to apply a second coat over top of the previous coating?
  16. k-moe
    I'd call Red-Kote and ask them.
    FWIW I've seen Red-Kote fail, even with proper tank prep.
    Glen F. likes this.
