For Sale 1982 xj650 SECA parts
Discussion in 'For Sale, Trade/Swap, Wanted' started by Jesse Wilson, May 1, 2020.
  1. Jesse Wilson
    Jesse Wilson New Member
    Eau Claire, WI
    Located in Eau Claire, Wisconsin. Pick up parts or I can ship them out at the expense of the buyer.
    I accept payment in cash, venmo, or paypal.
    Picture of parts is all the parts I have, the picture of the assembled bike is what it was prior to disassembly for reference.
    Lot's of parts for sale for a 1982 xj650 Seca, the frame has a Wisconsin title, the engine I can either part out or if someone wants it I will sell whole, no idea if it runs - it sat out under a tarp for years with no carbs or plugs unfortunately (not my doing!). What I can see through the spark plug holes, the pistons are a bit rusty but I'm sure it's salvageable.
    I can get individual pictures/info at anyones request for any of the parts pictured or listed.. I do not know if everything works but if you know of a way I can test something that you want, please just let me know I'll try to help out as much as I can.
    From what I can tell all parts are original....
    Front wheel - tire is probably shot
    Rear wheel - good tire with lots of tread, holds air
    Seat - no rips or tears
    Seat plastic - has both blinkers, no cracks
    SECA 650 side panels - both in great condition
    Swing arm/drive shaft/hub
    Front fender
    Wire Harness/Fuse box
    Ignition coils
    Relays
    Solenoid
    Starter
    Air box - has a small crack in the plastic on the side of it, it happened when I was removing it (!#$%), no chunks missing or anything and can easily be repaired.
    Air Filter
    CDI box
    Voltage Regulator
    Panel that the CDI box and Voltage Regulator go on
    Brake Lever with master cylinder
    Right mirror
    Speedometer with cable
    Tachometer cable? (at least thats what I think it is)
    Speedo/Tacho mount
    Clutch Cable
    Choke cable
    2 Brake Lines
    Battery box
    Lock storage box (for the chain lock)
    Rear brake hub
    Rear brake control cable (thing?)
    Rear fender
    Rear tire cover/splash shield?
    Headlight case (has a dent in the back, but seems very usable still)
    Horn - has a slight bend in the bracket
    Rear shocks
    Forks
    Tree
    Front & Rear axle with nut and washer
    Carb boots - one has some surface cracks but overall they look okay
    I want to say rear? peg mounts
    Please let me know if you have any questions or want to see some close up pictures!
  2. hogfiddles
    Pm’d
  3. JBurch
    JBurch Active Member
    Owego, NY
    Pm'd
  4. Jesse Wilson
    Eau Claire, WI
    Had a few inquires about the TANK, I should have added that it is not part of this sale. Thanks everyone!
  5. XJ550H
    the horn bracket is nice for giving the 750s a 700 look with the horns sticking out from frame bolts right on
  6. joejr2
    Santa Fe,NM
    Is the FRM box still available ?
  7. joejr2
    Santa Fe,NM
    I typed cdi. This site keeps posting different words than I have typed
  8. hogfiddles
    That’s really BACON. I typed the word “weird” but bacon keeps showing up.:D:D
    Maybe turn off your auto-complete
  9. Jesse Wilson
    Eau Claire, WI
    CDI is available
  10. hogfiddles
    Anyway, it’s a TCI......not CDI
  11. Jesse Wilson
    Eau Claire, WI
    FRM, CDI, TCI, ABC, XYZ. Either way, the little black box is available ;):)
  12. hogfiddles
    TCI. If you’re gonna be on here, and especially if you want to sell something...... it would be a really good idea to learn the correct names of the parts.
  13. Jesse Wilson
    Eau Claire, WI
    Update on parts availability:
    I can send detailed pictures of anything you want to see, just let me know where to send the pictures!
    Front wheel / axle - tire is probably shot $10
    Rear wheel / axle - good tire with lots of tread, holds air $10
    Seat - no rips or tears $50
    Solenoid $5
    Air box - has a small crack in the plastic on the side of it $10
    Voltage Regulator $25
    Panel that the TCI and Voltage Regulator go on $5
    Front Brake Lever with master cylinder $10
    Right mirror $10 Tachometer cable $5
    Speedo/Tacho mount (w/ dash lights) $10
    Clutch Cable $5 Choke cable $5
    2 Brake Lines $5
    Battery box $10
    Lock storage box (for the chain lock) $5
    Rear brake control cable $5
    Rear fender $10
    Rear tire cover/splash shield $10
    Headlight case (has a dent in the back, but seems very usable) $5
    Rear shocks $20
    Triple tree $20
    Carb boots - one has some surface cracks but overall they look okay $10
    Rear peg mount plates $10
  14. joejr2
    Santa Fe,NM
    Have you still got the inner annd outer rear fender ?
