1982 XJ750 Maxim Tracker O.E.M. +
Discussion in 'XJ Modifications' started by eurosnap53, Aug 27, 2014.
  1. eurosnap53
    eurosnap53 Member
    Fresh Aftermarket parts:
    Emgo Headlight mounts
    Metal valve stems
    UNI crank case breather filter (UNI foam pods to match soon)
  2. eurosnap53
    eurosnap53 Member
    YICS block off tuning tool via XJ4ever.com, very nice piece.
  3. eurosnap53
    eurosnap53 Member
    And last, but not least...
    My custom Kerker knock off...it started its life as a baffled MAC (puke for quality; when my tig skills improve, i'll try and make a custom stainless) but decided to cut that out, install a perforated sheet metal tube w/ 4 stroke packing. Regretfully, I shortened it and ended up not liking it so I'm probably just going to buy the R6 Akrapovic GP slip-on as I had originally planned. And also, on a test ride it fell off, bummer dude.
  4. eurosnap53
    eurosnap53 Member
    Testing VHT engine paint on my valve cover...the color is Flat Black Engine Enamel rated @ 500 degrees fahrenheit. I previously used Dupl-Color Satin Black high temp enamel; very nice finish but didn't use the primer and had some areas where it flaked a little. For prep I used Aircraft striper to remove old paint, then soda blasted it. Compressed air and alcohol sprayed on to clean off residue, then final alcohol wipe down.
    Next is the VHT Engine Enamel primer, first 2 coats...
    Now paint, which I did 4 passes; 2 pass over everything with the second coat concentrating on creating even finish, nice quick, almost full bursts out of the aerosol from at least 12" but no more then 14". Small passes with that distance worked best for me. After letting those coats dry, paint and primer was removed with 320 sand paper for the raised area on top of the cover. Once all paint is removed, alcohol rinse and wipe down with blue tape neatly applied with almost no overhang on the raised areas. I hit the outside edges withe the sander while making the 90 turn down, so these two more coats will cover that all up. Again, concentrating on light areas with no glossy or runny areas. The last 2 coats was really 2 light coats, then 10 minutes, then two more light coats.
  5. eurosnap53
    eurosnap53 Member
    Got some more engine work done: Started soda blasting prep on the motor, taped off cylinders and holes.
    Drilled and tapped 3 seized intake boot holes for new aluminum slugs that were threaded on the lathe. Red loktite on all three slugs made then tightened in all the way. Once the loktite is dry, I'll put it in the mill and machine the slugs down to face the cylinder head.
  6. BrosefStalin
    BrosefStalin Member
    Pittsburgh, PA
    Everything looks good! I really like that tank choice.
    Regarding your new front brake setup: Did you use stock length braided lines, or are they a custom length? I'm doing my brakes all around this winter and I like the idea of that GSXR MC/Lever setup; mine's in bad shape.
  7. eurosnap53
    eurosnap53 Member
    Thanks, everything is slowly starting to come together once the head repair is complete (I'll have updates on that tonight)...I'm using stock size, XJ650 Goodrich steel braided lines; three hoses and using the stock junction box. They feel very firm, all though, I was looking here on XJ4ever and saw they now sell aftermarket caliper seals that are the correct fit for mine so I'm going to swap that out soon to make sure its close to perfect.
  8. eurosnap53
    eurosnap53 Member
    So all should be good, just need to reassemble once all my gaskets and I-rings come in for the top end. May re-ring just because I'm down there...Anyhoo, milled down the 3 plugs but couldn't go all the way due to the cylinder head intake face being at almost a 4-5 degree angle. So we got it really close then hand filled VERY slowly and carefully. Got it almost flat then made my drill marks by installing an intake boot on the head and punch marked the center of drill hole. Drilled out with 5mm drill bit, tapped @ M6x1. Measured left and right and 90 degrees below of the said holes to make sure they were even lengths on all three points insuring as close to center as poss. Still nervous but it should be good once the carbs go on...
    After I tapped all of them, I sanded the faces berry carefully with 1000 on a block
  9. eurosnap53
    eurosnap53 Member
    Chased all 8 holes with the tap with grease, cleaning the dirty grease off each hole and re-greasing.
  10. Polock
    nice work. did you consider putting ss studs in those holes, then that will never happen again
  11. eurosnap53
    eurosnap53 Member
    No, it would have been too difficult for what it was. The aluminum was much easier to work with as I had to drill the holes by hand...plus cause it was only 3. A little anti seize on all the bolts and it should be good to go.
  12. Polock
    what i was trying to say was, make the intake side like the exhaust side
  13. eurosnap53
    eurosnap53 Member
    Ohhhh...I didn't and that's a great idea! Thanks for the tip... Something like this but shorter.
  14. Polock
    when you test fit the manifolds to the head, check for a lip where they meet. i smoothed mine out with a dremel tool. that square edge just didn't seem like it should be there
  15. eurosnap53
    eurosnap53 Member
    Got one round of aircraft paint stripper on the frame, nasty stuff...re welded the tank mounts and seat mounts a little while ago. Hopefully will have the frame painted next week.
  16. eurosnap53
    eurosnap53 Member
    Just finished sandblasting the frame...off to buy some etching primer [​IMG]
  17. eurosnap53
    eurosnap53 Member
    So I was looking at the step you're talking about (first noticed it when I was marking the holes I needed to drill). It looks like the head has a bevel on the inside, where the intake boot mounts causing a step...that lip? Did you Dremel the inner edge the make it smoother and more curved? Did you notice a difference in power and/or feel?
  18. Polock
    the hole in my manifold was smaller than the port in the head. so i took some rubber off the manifold.
    couldn't really say if it made any difference but it gives me that warm fuzzy feeling sometimes :)
  19. eurosnap53
    eurosnap53 Member
    First coat of primer, exactly one can! Prep cleaned frame with Compressed air and two wipe downs with Acetone.
    Cheers!
  20. eurosnap53
    eurosnap53 Member
    Hey guys...here is a sneak peak of my frame color.
    As mentioned above, prep steps:
    1) Sandblast
    2) Blow off w/ air then Acetone wipe down
    3) Rustolium Self etching primer
    4) Rustolium Automtive Black semi-gloss
