1982 Xj750 Maxim vs Seca are the Carbs the same?
Discussion in 'XJ Technical Chat' started by vashtsdaytona, Feb 10, 2019.
  1. vashtsdaytona
    vashtsdaytona Active Member
    Fargo
    What I hope to be a simple question. are the 750 seca and maxim carbs the same? My memory is telling me yes they are. Hoping someone might confirm that?
    Perhaps jetting was different, but the basic bodies are the same right?
    Same carbs, same jetting for the aircooled 750. It's the 650 carbs that are jetted differently from the 750.
    Keeferheydude and Nuch like this.
  3. vashtsdaytona
    Fargo
    Thank you that's what I needed. Does that mean that the 650 uses the same bodies as well with just different jets? Or are they all the way different. Just expanding my parts search
    Yes. Same bodies, different main jet and jet needle.
    Keeferheydude likes this.
  5. XJ550H
    carb specs
    http://xjbikes.wikidot.com/carb-specs
    XJ750 Models:
    Years & Models: 1981-3 XJ750 Maxim, Midnight Maxim, and Seca USA models
    Carb Manufacturer: Hitachi
    Carb Series: HSC32
    Carb Model ID: 15R00 (Maxim, Midnight Maxim)
    Carb Model ID: 5G200 (Seca)
    Main FUEL Jet Size: #120
    Pilot FUEL Jet Size: #40
    Main AIR Jet Size: #80
    Pilot AIR Jet Size: #225
    AIR COMPENSATOR Jet Size: #36
    Starter FUEL Jet Size: #40 (non-replaceable, in float bowl)
    Main jet NEEDLE ID: #Y-13
    Main needle JET Size: #3.2mm (the main needle JET is also known as the "power valve" or "emulsion tube").
    Fuel Level in float bowls: 3mm +/- 1mm (.118" +/- .039")
    Idle RPM's: 1,050 rpms
  6. Nuch
    Nuch Well-Known Member
    Suffolk County, NY
    This is why I love this place...
    XJ550H and k-moe like this.
