1982 XJ750 Seca Rear Brake Switch
Discussion in 'XJ Technical Chat' started by Tiavarone, Jul 15, 2022.
  1. Tiavarone
    Tiavarone New Member
    Rhode Island
    Hello All, I recently purchased the bike and noticed the brake switch was bad on my bike and bought a new one. Question is how do I install the new brake switch does the passenger foot peg have to come off as well as the foot brake itself? I can't seem to find anything in the owners manual about removing or installing a new switch. The Old Brake switch had a homemade spring that lost its tension so I didn't have to remove anything to take it off.
  2. Jetfixer
    As I recall from replacing mine , I removed the rear brake lever and the rear foot rest bracket (3 large Allen bolts) . The shaft has two ears on it one is where the spring to the end of the switch . You adjust the jamb nut till it shuts off the brake light , reassemble the brake lever push down on the lever see it your brake light illuminates , let off and see if it extinguishs, if does your good they can be a little finicky.
  3. Tiavarone
    Rhode Island
    Thank you so much, I just wanted to make sure I wasn't taking things off that I didn't need to I will give this a go tonight!
