Wanted 1982 Yamaha Seca 550 Triple Tree
Discussion in 'For Sale, Trade/Swap, Wanted' started by Jacob Wood, May 14, 2019.
  1. Jacob Wood
    Jacob Wood New Member
    Saint Paul
    Hello everyone,
    I really need a 82 Seca 550 triple clamp setup. The bike I bought was in a front end collision and upon attempting to replace the bent forks with 81 Suzuki GS750L bodies, I realized that the stem on my setup was also bent forward. I am going to attempt to make the Suzuki triple tree work, but concerned about the spacing between bearings.
    If anyone has one or willing to part ways with one please message me!!!!!
    Jacob
  2. xtmag
    xtmag Member
    Rochester, MA
    I have a 82 xj750 maxim tree. Not sure if it fits?
  3. Jacob Wood
    Saint Paul
    AH, nope the xj750 has 37mm clamps. The Suzuki fork I'm converting to (have already purchased and rebuilt, seals) is 35mm.
    Thanks for the reply though.
    xtmag likes this.
  4. joe elliff
    joe elliff Active Member
    illinois
    I think I actually still have one. It’s not marked tho so if u have a pic that I can match it to send me a pm
    Jetfixer likes this.
  5. Jacob Wood
    Saint Paul
    @joe elliff, thanks for searching. I actually found one on eBay finally! Someone posted one. I'm sorry to waste your time. I'll take down this thread.
  6. XJ550H
    it would have those cast risers straight up. cast into the top tree similar to the 650 bracket except it is not split at the back . 650 is split and uses an allen bolt to clamp it closed
    edited
  7. Jacob Wood
    Saint Paul
    Angled risers are indicative of Maxim models I believe. My Seca had straight risers originally.
  8. XJ550H
    I will revise that cast risers straight up. cast into the top tree similar to the 650 bracket except it is not split at the back . 650 is split and uses an allen bolt to clamp it closed
  9. k-moe
    If the steering stem was bent then it is highly likely that the frame was bent as well.
    hogfiddles and Xjrider92117 like this.
  10. Jacob Wood
    Saint Paul
    Frame seems to be okay. Local bike restoration shop took a look at it while replacing the head bearings. New races fit right in. Any other tells that would tip me off to a bent frame? I would like to keep this bike, but it has definitely turned into quite the project.
    Good thing it was only $350.
    Will post pictures once the front end is swapped out and it is not raining.
  11. Gary Potter
    Gary Potter Member
    Manassas, Virginia
    I have a 82 xj650 Maxim triple tree. Let me know.
    Gary Potter
  12. Gary Potter
    Gary Potter Member
    Manassas, Virginia
    I have one for a 82 xj650. That might work.
    Gary Potter
  13. hogfiddles
    2-yr old forum
