1982 Yamaha Seca 750 Loping Idle, Needs Choke to Run
Discussion in 'XJ Technical Chat' started by Mark Wyzgala, Jun 3, 2021.
  1. Mark Wyzgala
    Mark Wyzgala Member
    Seattle
    OK, long story, get something to drink, then read this missive.
    I put up my 1982 Seca 750 about 17 years ago in my garage. Last year after retiring I decided to crank it up again. The front brakes were frozen so I disassembled them and rebuild the master and brake cylinders. After laboriously bleeding them, they work fine now. Now I understand why you should flush the brake fluid ever few years. The brake fluid had changed to yellow crust.
    When I got a new battery, I was able to change the oil, put gas back in it and it started right up. It had a loping idle that eventually stalled out but it ran. I got turned on to XJ4ever by my nephew so I could find parts for the bike. Removed the Carb rack and used carb cleaner spray to rinse out all of the passages. When carbs replaced the bike didn’t run better so I checked for vacuum leaks with carb spray and found a big one at the gasket between the intake runner and the head. The gasket had crumbled over the years so I bought new ones and replaced the rubber intake runners too since they were old and cracked. After reassembly the bike ran better, but not right. I retested the vacuum and found a smaller leak at the throttle shaft seal. Talked to Len and got replacement float bowl & throttle shaft seals, , idle mix screw O ring and fuel runner O rings and replaced them. I also polished the CV piston and cylinder until it passed the Plunk test. Inspected the diaphragm with a strong light, it has no holes and is still flexible and supple. Still rough idle.
    I then tested coils for primary and secondary resistance. Coils are in spec but plug caps were out so I got new 10k and 5k Caps and put them on. Replaced plugs also with non-resistor plugs. I synchronized carbs and Colortuned them (~3 to3.5 turns out). Got the bike to run better. Took it out around the block over several weeks to test it out, and ended the season in November. But at the end it started to run badly again.
    Pulled the carb rack again and found one of the diaphragms had slipped out from under the carb hat. Drained the fuel tank, took it off and sprayed WD-40 inside to store. When draining the tank, getting the last few drops with a turkey baster, the long tip fell off in the gas can. I thought it was Polypropylene and was impervious to gas, so I left in until I could drain the gas can later. I dry then wet set the carb float heights, but had much difficulty getting replicable wet numbers.
    Then I rebuilt the forks and anti-dives since the seals were leaking. In February I reassembled everything and filled it with the gas from last year. It ran terrible. Couldn’t get it to idle very long and it would stall. When I refilled the gas can I realized the turkey baster had disappeared! Apparently, it was not PP but some other plastic that dissolved in gas. This is what the carbs had in them. When the gas dried in the carbs a coating of plastic was left.
    I cleaned out the tank, got a new gas can and fuel line and disposed of the contaminated gas at the hazardous waste station. I disassembled the carbs completely, but again, and used carb cleaner spray and brushes to completely clean out everything. I found the fuel inlet screen on carb 4 was completely covered with gummy plastic. I sprayed out all of the passages several times and poked them out with the thin wires. I did this until all passages sprayed out carb cleaner as a forceful jet of fluid. I then replaced the floats, seats, screens and needle valves. (Floats looked like they were starting to crumble.) I then set the dry and wet float heights several times to get down to 3-3.5 mm (I’m getting pretty good at this now).
    Still won’t idle right and won’t stay running without some choke on. I’ve tested spark from all plugs and it looks weak to me (however I’m used to HEI ignition sparks), but is blue/white and will jump a 6mm+ gap. Plugs have carboned constantly, even on some cylinders before I put it in storage. I’ve tested the pickup coils cold and they meet spec ( 634 and 645 ohms, spec 650 +/- 20%). I tested the spark on an old plug against the block. When I turn on the ignition, plugs 1-4 give the single spark as 2 seconds, but Plugs 2-3 give no spark. I probed the Coil leads from the TCI (black box Transistor Controlled Ignition) and 1-4 lead goes up to 10.8 V then drops to 0.5 V after 2 seconds. The TCI lead to Coil 2-3 goes up to 10.8V and stays there permanently. If I switch the coil leads so the signal from the TCI for coils 1-4 goes to coil 2-3 then 2-3 sparks. I reflowed one poor looking solder joint on the TCI, but didn’t help.
    I took apart all connectors and fuses on the bike and cleaned them with DeOxIt contact cleaner. The TCI big connector was very corroded. Probed TCI lead to coil. Orange (1-4 coil) line compared to ground is >20M-ohms, the 2-3 grey lead shows 17.6 M-Ohms.
    I wish there was a way of testing the TCI at all and coils at high frequency and voltage, as I suspect them. I also think I’ll have to pull the carb rack and see if I missed any plastic goop.
    So, this is my tale of woe. I’ve gone through all of my ideas and drained Len of all his ideas, so does anybody have any other ideas.
  2. Toyobaru866
    Toyobaru866 Active Member
    Netherlands
    Wow that was a lot of work... You probably did but the only thing I'm missing (or overlooked in your story) is performing a running sync on the carbs and adjusting the idle conforming.
    hogfiddles likes this.
  3. Franz
    Check the valve clearances too.
  4. Rooster53
    The set of plugs that spark is dependent upon the physical location of the reluctor. You should be able to bump the starter or turn the engine over manually and find a spot where the 2, 3 plugs will spark approximately two seconds after turning the key on.
    The actual change should be when the key is turned on one set will go low for approximately two seconds and then when going high that set will produce a spark. The going high feature is built into the TCI to disable coil current to protect it from overheating. The TCI will become active again as soon as an input signal from the pick-up coil is detected.
    Not sure exactly how this was done (was everything disconnected except the one wire to the coil?), but either way resistance greater than 10 megohm on the primary side would certainly be considered open and not an issue.
    Likely not an issue, but XJ750 Seca 81-83 should be 5K per cap (4K to 6Kohms)
    Running only with choke on is so typical of clogged jets / passages and I would be thinking about the turkey baster plastic still being in there. It sounds like it slowly dissolved, so it makes sense that it would take some extended soaking to remove.
    Do all the exhaust pipes appear to heat evenly when first started, or at least all getting good and hot? Maybe try to keep it running with a bit of throttle and without the choke as that might help identify a particular cylinder that is having issues with the pilot circuit.
    And as suggested what about the valves, do you know the history and have they been checked / adjusted? How many miles on the bike?
    Has a compression check been done recently? That's always a good place to start with any motor that has been out of service for an extended period.
    StarGeneral likes this.
  5. Mark Wyzgala
    Mark Wyzgala Member
    Seattle
    Yes, I’ve done that 2-3 times with the colortune and manometers. There are probably some things I was too bleary eyed to remember.
  6. Mark Wyzgala
    Mark Wyzgala Member
    Seattle
    Checked valve clearances last year. They were in spec.
  7. Mark Wyzgala
    Mark Wyzgala Member
    Seattle
    Just did compression test cold, got from 140 to 149psi across the cylinders ( did it cold because some cylinders were not firing then). But even cold this seems ok. Read orange box on this. Some of my replies mingled with quote text.
    Again I appreciate the review and ideas.
    Jetfixer likes this.
  8. Franz
    Cold compression test is the right thing to do make sure the compression is right for starting.
  9. Mark Wyzgala
    Mark Wyzgala Member
    Seattle
    Thanks, Franz
  10. Jetfixer
    Okay if you read any of my posts on my Johnny Cash bike, I went through a mine field here are some items . Did you do a FULL tear down of carbs , all rubber seals removed . I use Berrymans carb dip 1 gallon container soak each carb bodies for several hours. Or boiling the carbs is another option . I could not get my carbs to run right finally figured it out problem number two slide would not move all the way up , and number four the diaphragm was not fully in the groove under hat . (You said you had that problem as well) did you do a bench synch on carbs ? I'm don't mean to insult you in anyway , it is the little things that get overlooked.
  11. Toyobaru866
    Netherlands
    Maybe I'm crazy and I know this is going to sound weird... But what I do after rebuilding the carbs. I suck the vacuum port of each carb with my mouth... You can tell by feel if the same suction is needed to move the piston completely up. Just my scientific way to check the sealing of the diaphragm.
  12. XJ550H
    thats not what lifts the slides, the tiny hole in the bottom of the slide make it rise.
    air sucked out of the little hole creates a vacuum it the top portion of the carb hat above the diaphram and the slide lifts.
    it lifts and drops with the opening and closing of the intake valve.
  13. Mark Wyzgala
    Mark Wyzgala Member
    Seattle
    Jetfixer, I did a full tear down of the carbs, taking all apart down to separate pieces ( seals, emulsion tube, inlet valve seat and screen, jets etc. I sprayed cleaner several times into all passages a blew them out. I didn’t boil them or soak them in Berryman. Did this Berryman soak take off the carb body finish and dull them? I also found the diaphragm seal test of blowing into the oval hole on the intake and seeing if the slide raised. Also, bench synced the carbs with a paper clip. As for insulting me, don’t worry, I’ll take all the ideas I can get. After 4 or 5 carb rack removals you get a much more mellow disposition (AFTER removing and replacing the rack, not during). Thanks for all your help.
    Beck likes this.
  14. Mark Wyzgala
    Mark Wyzgala Member
    Seattle
    I now do that test, but blowing into the oval hole.
    Beck likes this.
  15. Mark Wyzgala
    Mark Wyzgala Member
    Seattle
  16. Jetfixer
    The only true way to get into the small passages is to soak or boil . The Berrymans carb cleaner as long as you don't leave it for several days, I've never had any problems . Used this to do both of my Seca's carbs . Spray cleaner just will not get into the small passages, if your bike sat as long as you stated , it could be really gummed up . Although I doubt it is the problem, have you checked the petcock, are you running it on PRI or ON ? It is possible the diaphragm for the the vacuum is not giving enough flow.
  17. Mark Wyzgala
    Mark Wyzgala Member
    Seattle
    I have an auxiliary tank I use so the tank & petcock are out of the equation. I was going to try the Berrymans but wasn’t sure if it would wreck the finish. Thanks for the info Jetfixer.
  18. Toyobaru866
    Netherlands
    Hahaha, one single malt too many and it was 01:00 am but blowing the oval hole is it!
  19. Toyobaru866
    Netherlands
    No doubt you're right. But blowing the oval hole as Mark said doesn't do the trick either? Because it does move the piston but maybe another reason?
  20. Mark Wyzgala
    Mark Wyzgala Member
    Seattle
    I believe the oval connects to the chamber under the diaphragm. If the diaphragm seals the higher pressure under the diaphragm lifts the piston. If the diaphragm Is not sealed the added pressure leaks to both sides of the diaphragm so the added pressure doesn’t push up the piston.
  21. Mark Wyzgala
    Mark Wyzgala Member
    Seattle
  22. Toyobaru866
    Netherlands
    You're absolutely right I think. Just looked at my spare set of carbs. IMG_20210605_220121.jpg IMG_20210605_220105.jpg
  23. Toyobaru866
    Netherlands
    Took me a while to picture this but I get it now, learning curve... Thnx!
  24. Mark Wyzgala
    Mark Wyzgala Member
    Seattle
    Found that test online after having a carb problem turn out to be a slipped diaphragm.
  25. Toyobaru866
    Netherlands
    I discovered it by accident, sitting on the couch making love to my beautifully rebuilt carbs :)
  26. Mark Wyzgala
    Mark Wyzgala Member
    Seattle
    I’ve rebuilt these carbs half a dozen times. They don’t do nothing for me.
    Toyobaru866 likes this.
  27. XJ550H
    that will lift the slide what you are doing is "inflating " the diaphram from the underside.
    that portal is to feed air to the airjets
  28. Mark Wyzgala
    Mark Wyzgala Member
    Seattle
    Yes
  29. Rooster53
    Try removing the pickup cover and rotate the engine until the reluctor is adjacent to the bottom pickup. If that doesn't do it then rotate the reluctor until it is adjacent to the upper pickup.
    I really think it is a bit irrelevant since you have verified spark on all four and verified all pipes are getting hot. Now I suppose it could be marginal on the 2, 3 side, but the only way to really test a TCI (excepting special test equipment) is to try it in another bike to see how it performs over RPM range.
  30. Mark Wyzgala
    Mark Wyzgala Member
    Seattle
    OK, thanks Rooster. I thought this may be an indication of a failure in the TCI. But you’re right, all cylinders were running so it must be firing when running. I’m getting an ignition test light tomorrow and can confirm proper fire of all cylinders. This TCI is literally the definition of a black box that’s impossible to tell what goes on inside.
  31. Jetfixer
    I have a TCI That has an issue , when I plugged it in bike idled higher and would quit running after a short period. So took cover off was corroded on the circuit board . Needless to say it is in my stache of parts . You might pull the cover and make sure it is not corroded, you can spray it down with contact cleaner .
  32. Mark Wyzgala
    Mark Wyzgala Member
    Seattle
    Thanks for the idea. I’ve already cleaned all the TCI contacts, then took the cover off, inspected the solder joints and reflowed one that looked bad. It was not corroded inside tho. Didn’t help.
  33. Jetfixer
    Okay I bought a another set of carbs off of eBay so I have a spare set , you could always buy another set off of Dave Fox ...sure he would have a good set he would part with . I know the feeling of WTF is wrong, trying every trick you can think of , almost tempted to pour two gallons of gas and a match and torching it ( please realize it is sarcasm). Sometimes it is something simple , that is overlooked. I once had an airbus A320 that had half of the power bus INOP, I swapped out the power panel, did countless power resets , I had 9 years of experience and had tried everything we could think of , we grounded the aircraft and towed it off the gate , a co worker was sitting in the cockpit, he had his hand on the glare shield , he pushed the master reset switch out of habit with his thumb ....and everything powered up ...we looked at each other and had a shazam moment ...the switch had been pushed in my Mr. Copliot to hard and it was stuck in ...we replaced the switch and no more problem. My long winded story is this is similar it is always the little things ...even if it sometimes the little things . Cheers
    Franz, chacal and Toyobaru866 like this.
  34. Mark Wyzgala
    Mark Wyzgala Member
    Seattle
    Thanks, Jetfixer. I was getting very frustrated after a year of putzing with this. My Father was a truck mechanic, so I grew up working on cars. So I’m sure I can fix this if I just think it through. I remember when I rebuilt the variable valve mechanism on my old Maxima. When I was done I tried to turn over the engine manually and It wouldn’t rotate very far. It was an interference engine and I thought I had the timing chain on wrong and bent the valves. I just sat down in front of the engine and stared at it for a half an hour. Finally had a flash and realized it was still in gear. Put it in neutral and it spun freely. I’m hoping for one of those flashes of inspiration here.
  35. Rooster53
    Is it running so poorly you haven't even put it on the road lately? The point is at least with my Seca (may not be right) is that too many cold starts / idle time with choke and not getting it on the road can actually foul plugs. It starts with choke and is a little lumpy on startup but just once through the gears it smooths right out.
  36. Mark Wyzgala
    Mark Wyzgala Member
    Seattle
    Yes, I can’t get it to stay lit. I can only get it to idle with the choke on, but I wouldn’t take it out on the street. Besides my driveway is somewhat steep and I don’t want to try pushing it up the driveway. And yes the plugs are fouling with all of the idling. I don’t rev it much when I’m trying to run it at idle. However this isn’t new. I remember before I put it up for storage, plugs 3 and occasionally 1 would foul during normal use.
  37. Jetfixer
    For shits and giggles you might try putting in new plugs , try a set of Autolite Ap63 or 63 these are equivalent to NGK . Change plugs but try to run it out riding , letting it idle especially with choke on can definitely cause plugs to foul out and , cleaning with a wire wheel might and might not save plug. I do have a question for you when you had carbs off did you clean the float bowl enrichment jets ? If one or more is plugged it can cause a only one or two carbs to run cold this could be a possibility and would mimic a loping idle . I once had a Honda CB750 ( never should have sold it but that is another story) number two cylinder you could hold onto the exhaust header at the cylinder, turned out the plug cap was toast .
  38. Mark Wyzgala
    Mark Wyzgala Member
    Seattle
    Yes, when I had the carbs apart I followed Lens advice, got a wire and made sure they were cleaned out. A pipe cleaner was useful to clean the port down in the bowl. I made sure
    I got a strong, straight stream out of each enrichment tube, and could see light through them. Unfortunately I also made sure to blast carb cleaner and air through the pilot circuit passages. I plugged the idle mix port and air jet port with Q tips and made sure I got a good jet of fluid out of all three idle ports in the throttle throat when I squirted into the pilot intake. Perhaps something loosened and went down stream after I reassembled the bike.
  39. Mark Wyzgala
    Mark Wyzgala Member
    Seattle
    Ok, I think I’ve solved the idle issue. I’ve pulled and disassembled the carbs yet again and found that there was black globs of assembly lube clogging the bowl inlet screens. Apparently the assembly lube doesn’t dissolve in gasoline as I’d expected, but just beaks up and embolises downstream to clog up everything. And I used this assembly lube because I was afraid the silicone lube would embolise and clog things.
    StarGeneral, Jetfixer and XJ550H like this.
  40. Andyam5
    Andyam5 Member
    Luton, UK
    Pilot passages, just sayin'
  41. Fuller56
    Fuller56 Well-Known Member
    just curious....... where did you put assembly lube that it would end up in the carb fuel flow path?
  42. Mark Wyzgala
    Mark Wyzgala Member
    Seattle
    I used it to lube the fuel rail “o” rings to be able to slip the rail tube into the carb body. It’s supposed to dissolve in the fuel. It just broke up into globs that flowed downstream into the inlet screens and clogged them.
  43. hogfiddles
    Good grief, how much lube did you use?? And what kind, that would make black globs?
    I use just the thinnest smear of silicone grease, barely anything, hardly even visible... just enough to let the o-rings slide in.
  44. Mark Wyzgala
    Mark Wyzgala Member
    Seattle
    I used just enough to slip the parts together. However, when you push the fuel line with the O ring in, it wipes the lube into a ring of lube, and that's what washed off. I hate to use silicone grease because if it wipes off and floats downstream nothing will dissolve it if it gets into blind places like the pilot passages. However I am stuck with it, so I will wipe it very thin when lubing the joints.
  45. hogfiddles
    NEVER have had that happen, and never HEARD of that happening, either.
  46. Polock
    silicone grease does dissolve in gas, so does ptfe grease and moly grease
    now my fingers smell like gas :)
  47. Mark Wyzgala
    Mark Wyzgala Member
    Seattle
    I stand corrected. Silicone grease can be solubilized in organic solvents, like gasoline. I don’t know how quickly, but then so should assembly lube. It is persistent though. It’s not allowed anywhere near electronic chip manufacturing areas because it can never be cleaned up. The silicone just spreads everywhere and contaminates the equipment.
    Anyhow I’ve bitten the bullet and re-disassembled the carbs.m I didn’t get any color with the colortune on cylinders #1&2 so I knew I had an idle circuit issue. I found I had good luck using a Q tip to plug the pilot inlet tube ( with the jet removed), and the hole where the idle mix screw goes, filling the air pilot jet hole with brake cleaner or carb cleaner, then plugging it with a Q tip. Then I set it aside for 10 minutes to soak, then unplug the idle mix and intake holes and spray brake cleaner in the fuel intake port and out the idle screw port. Then I blow it out with air and use a thin wire to clean out the tiny idle ports in the throttle throat. Then blow out from the fuel inlet to the unplugged air jet port. I’ve done a similar operation on the choke passages. I’ve cleaned out stuff that was not shifted by any other cleaning process. I’m ready to reassemble now, so we’ll see what progress has been made. If I take one thing away from this is that if you think your done and want to reassemble the rack, do another cleaning cycle ad make sure it is zestfully clean.
  48. Mark Wyzgala
    Mark Wyzgala Member
    Seattle
    OK, I've just reassembled the carbs and racks and put them back in the Seca (with the usually swearing). I put the auxiliary fuel tank on and filled the fuel bowls and it started right up. It idles more evenly now and I think that's due to the electrical contact Spring cleaning. It doesn't surge anymore. I Synched the carbs, then used the Colortune plug on all cylinders to set the idle mix screws. I can see a much brighter spark on the Colortunes, but also the proper color of the cylinder firing on all. Before I was always getting one or two plugs with no discernable color and believe this is due to the cylinder not firing fuel. Now I can get color on all cylinders, set the idle mixture screw properly and properly synch it. I can do all of this because the motorcycle starts right up, warms up quickly so I can shut off the choke, and it doesn't lope along until it stalls; it stays lit. I believe the trick was the soaking and rinsing out of the pilot and choke passages as described in my 7/6/21 reply , along with the electrical contact cleaning. It runs like a champ now, will idle all day long fairly evenly and it will rev instantly when I twist the grip (before the engine would hesitate then speed up). Thanks to Chacal, Rooster53, Jetfixer and all that helped me with this.
    Huntchuks and Toyobaru866 like this.
  49. Mark Wyzgala
    Mark Wyzgala Member
    Seattle
    I have a Colortune question. The Colortune instructions say for pre-1985 engines you adjust the pilot mix screws until you get yellow or orange color ( rich), then lean out the mixture until color is deep blue, lean out the mixture more until the engine runs rough, then set the mix screw 1/2 way between the blue setting and the rough running setting. Is this valid for our YICS engines? Others here on XJ4Ever say to just leave it at the blue richer setting.
  50. k-moe
    You want it to be right in the middle of the blue range. Dosen't matter what intake system the engine has.
