1982 Yamaha Xj650 Seca Wiring Diagram
Discussion in 'XJ DIY How-To Instructions' started by XJ650SECATAY, Nov 28, 2017.
  1. XJ650SECATAY
    XJ650SECATAY Member
    Salt Lake City
    I have a 1982 Yamaha xj650 Seca that needs to be re-wired. Does anyone have/know where to find a wiring diagram for this bike?
  2. kosel
    MInneapolis, MN
    straight from the back of the manual
  3. XJ650SECATAY
    XJ650SECATAY Member
    Salt Lake City
    Thank you so much. this will help out a lot. Is your bike the same XJ 650 on youtube? I've seen a few videos about it.
  4. kosel
    MInneapolis, MN
    Nope, not mine.
  5. XJ650SECATAY
    XJ650SECATAY Member
    Salt Lake City
    Do you know a lot about the 82 seca 650’s?
  6. kosel
    MInneapolis, MN
    Not nearly as much as many of the people here, but I've been working on mine since spring 2017 and have learned a ton. This is my first bike and the most I've ever done with engine work and I couldn't have done any of it without this group.
    In the "XJ Technical Chat" section, start a thread for your bike. Spend some time doing the required reading and researching issues before posting questions. You'll find that most things you encounter aren't unique to you or your bike and have been thoroughly addressed earlier. That and a single thread for your bike will save time for everyone, including you. As you work on it, post your progress and questions so everyone can see the history of what's been done.
    Good luck!
  7. kboehringer
    kboehringer Active Member
    Peachtree City, Georgia
    XJ650SECATAY,
    You did not mention what the exact reason the bike needed a rewire. But, one problem that is typical of these old bikes is the fuse box. The old glass fuse holders get weak and very frequently do not provide a proper contact. The holders are very brittle after 30++ years. They may "look" good, but they are often not. Personally, the very first repair I complete when restoring one of these old bikes is to upgrade the OEM fuses to modern push fuses. I've done this using a couple different methods. However, XJ4Ever (Chacal) offers a nice complete kit that will upgrade that fuse box extremely professionally. You may find that a bunch of electrical gremlins immediately disappear and systems start working properly the moment that old fuse holder is replaced. That's just my 2-cents...
    Sincerely,
    Kurt
    XJ650SECATAY likes this.
  8. XJ550H
  9. Juan Carlos
    Juan Carlos New Member
    Fremont, CA
    Is the wiring diagram you posted also for the 1981 750 Seca?
  10. XJ550H
    750 is different from 650
  11. kosel
    MInneapolis, MN
    No. I posted the diagram for the bike requested. The 1982 650 Seca (XJ650RJ).
  12. hogfiddles
    That might be why it says ' xj650rj ' right at te top of the page, too.....;)
  13. Trace Harris
    Trace Harris New Member
    New Albany Indiana
    Does anyone have a wiring diagram for the xj650lj seca turbo
  14. XJ650SECATAY
    XJ650SECATAY Member
    Salt Lake City
    if anyone does it’s probably hogfiddles. You should be able to find them online too
  15. Franz
  16. Trace Harris
    New Albany Indiana
    Do you know where I can get a main harness for my 1982 Yamaha xj650lj seca turbo
