1983 carburetor issue
Discussion in 'XJ Technical Chat' started by river bringhurst, Oct 25, 2022.
  1. river bringhurst
    river bringhurst New Member
    Utah
    So I have a 1983 xj650 Maxim and it’s been sitting for two years so I cleaned them and got the butterfly valves moving with the throttle because the throttle was locked up but now those 2 things move but the throttle slides don’t move at all
    2nd I tried jumping it with a car to see if all the electronics works but it did nothing however I noticed 2 fuses were blown ( the very left fuse and the very right fuse) would that be why it doesn’t do anything when I jump it, and I’m not sure which side is the positive and negative on the bike
  2. river bringhurst
    Utah
    Okay so I changed the fuses but still nothing happens
  3. jayrodoh
    jayrodoh YimYam
    Cleveland
    Do you mean they don't move with the butterfly valves or you can't move them up and down? They move up by changes in pressure not with the cable. If you can't move them up with a finger then you are pulling carbs to diagnose and rebuild. I'm guessing if the throttle plates were locked up you're gonna have more issues with the carbs.
    There is a lot of safety switches on the bike for the starter and ignition. Do you get a tail light and neutral light (must be in neutral) when key is on? Should see the oil light light up when you press start.
  4. river bringhurst
    Utah
    okay i got everything but the electronics i have no idea whats going on with them, it looks like everything is intact it just does nothing when i turn the key
  5. cds1984
    cds1984 Well-Known Member
    Perth, Western Australia
    Positive (red) goes to the starter solenoid and negative(black) goes to the frame/engine case.
    If you turn on the key and get nothing at all, no dash lights, brake lights, indicators etc, then your ignition switch is the first point of query.
    Use of a multimeter is ideal, check before the ignition switch and after the ignition switch.
    You will need a wiring diagram to really get into it.
    Give these a look.
    https://members.tripod.com/dave_jack/Temp/id39.htm
  6. hogfiddles
    Slides won’t move until the engine is running
