1983 XJ750 Maxim Build (Updates and Questions)
Discussion in 'XJ Technical Chat' started by XJ750DB, Dec 16, 2017.
  1. XJ750DB
    XJ750DB Member
    Chicago
    Recently I picked up a 1983 XJ750 Maxim with 33xxx miles on it with the plane to make a brat/cafe style bike. I started a thread in the hangout lounge forum but I am going to start posting here updates and questions I have to get some more action. I plan on rebuilding the forks, carbs, calipers, and changing all the fluids myself before I start making any customizations.
    So I am working on rebuilding the front forks and I cannot remove the 19mm cap bolt to access the spring. Does anyone have any tips on how to get these off?
    I also found why one fork was leaking oil like crazy, the washer the goes on top of the oil seal between the clip was missing. Also they used the wrong length bolt and stuffed washers on it and lots of locktite to make it work.
    I was able to remove the air valve but I can't remove to 19mm bolt
    Missing washer and wrong bolt
  2. mlew
    mlew Well-Known Member
    Apex, NC
    I always break then loose before removing from the triple tree. You could bolt them back in, it makes a handy clamp to hold them.
    A air impact wrench will take it off, be sure to use a 6 point socket.
    Last but not my favorite it to clamp in a vise with wood blocks to protect the inner tube. This method will sometimes does not hold well and the tube will rotate in the blocks. Don't clamp the tube directly in the vise jaws, it will mar the chrome finish.
  3. XJ550H
    it is threaded in place soak with kroil to loosen rust
    haynes manual recomends soft cloth around tube and place it in a vise
    leaving it in the tripple tree is safer
  4. XJ550H
    just remember to loosen the top triple tree clamp so you are not fighting the clamp.
    its late you can also extend the tube section above the triple tree to be able to use upper and lower clamp
    could be some thread lock on the cap maybe some heat to soften it
  5. hogfiddles
    I don't recall mine being threaded... I do remember having to push it down to remove a circlip.
    I do recall that the xj700 and virago forks are threaded, and the take a pretty good-sized Allen drive
  6. MattiThundrrr
    MattiThundrrr Not a guru
    America's friendly hat
    Is that the one which can be substituted with a reversed spark plug socket? Where you use an extension on the ratchet and use the hex on the back of the socket instead of the normal orientation? I vaguely remember reading about the process, but not enough to recall the application.
  7. hogfiddles
    That for at the bottom of the fork tube so you can remove the retaining bolt
  8. Simmy
    The reverse spark plug wrench fits the damper bolt inside the fork
  9. XJ550H
    I haven,t done my 83 750 yet but the haynes manual does say that it is a change for that year and is threaded.
    manual could be wrong.
    with the torque spec at 6.8 ftlbs it shouldn't be that hard to turn unless it is frozen or thread lock compound was used by po when he redid the tues. it could also be stuck to the seal
  10. chacal
    Actually, that one fork tube has a spacer washer that shouldn't be there..........no spacer washer was used with original seals (or, aftermarket seals which have the same height as the original seals).
    Cap bolt is threaded. Penetrating oil will (eventually) do the trick.
  11. XJ750DB
    XJ750DB Member
    Chicago
    Quick update here. I followed most of the advice here and I was able to get one side apart after putting it back in the triple tree.
    I let it soak in some liquid wrench and hit it with my impact gun.
    On the other side I learned a very valuable lesson about the importance of six point sockets. I completed rounded off the bolt.
    I am going to let it sit with the penetrating oil and try to weld a larger bolt on top. Unless any of you have better recommendations.
    Thanks, I will discard the spacer as I have already purchased the correct seals from you.
    I am going to replace bolt caps, do you happen to have any of those in stock?
  12. hogfiddles
    I just don't remember unscrewing mine.....probably cuz I only had to do that set once, and have done a lot of the others.... Oh well, my bad.
  13. XJ550H
    you could try a bolt the size of the air nipple and lock it down with a nut then see if you can unscrew it using the inserted bolt
  14. hogfiddles
    That bolt would just turn back out.
    I would resign myself getting a new cap in advance, then either use a big easy-out in the Schrader hole, or weld a good-sized nut to the top and try turning it out that way. Maybe welding a nut on should be first choice-- if it turns out, the nut can be detached and weld residue ground off, allowing the plug to potentially be re-used
  15. XJ750DB
    XJ750DB Member
    Chicago
    Quick update. I have tried welding a nut on top with no luck. The welds kept braking when I tried turning the nut. I had a bolt that fit into the schrader valve hole and tacked that into the threads. The bolt snapped in half. I picked up some kroil and let it sit overnight. I bought a set of extractor sockets which only rounded the bolt more.
    I am going to try to find a more powerful welder and weld another large nut on top.
  16. joe elliff
    joe elliff Active Member
    illinois
    Oh that Kroil is good stuff!!
  17. hogfiddles
    Pretty soon it's gonna be less expensive to get a different fork
  18. Chitwood
    Chitwood Well-Known Member
    Fort Atkinson, Wisconsin
    When you weld a bit onto a fastener for extraction, making sure you get the best possible penetration into the piece you want extracted is key. Then once you have it stuck on there real good, let it cool for awhile before you start trying to turn it. Once you start trying to turn it, start by carefully working the fastener back and forth little by little, adding penetrating oil as you go.
    Stumplifter likes this.
  19. XJ750DB
    XJ750DB Member
    Chicago
    Well I have tried everything in my power to get the nut to budge with no luck.
    I found a straight pair of forks on ebay which I snagged for $50 +free shipping. I should have them in a week.
  20. hogfiddles
    I might be interested in that fork just to keep trying
  21. Paul Howells
    Paul Howells Active Member
    Victoria, BC
    Masochist.
  22. XJ750DB
    XJ750DB Member
    Chicago
    The issues continue on the new forks I received. I was able to remove the to cop with ease on this pair.
    But the socket head cap screw on the bottom completely rounded off... At least this should be easier to drill out and the kit from XJbikes comes with a replacement screw. :/ 20180106_170945.jpg
  23. XJ750DB
    XJ750DB Member
    Chicago
    After letting the bolt sit with some kroil I decided to take another crack at it with an extractor. I drilled out the head and got the extractor in place. It was not budging so I gave it some heat with a torch and it broke loose. I had to used the trick with the upside down spark plug socket and the extensions to get it completely off. The threads were packed with a hard black substance. After I get the forks back together I will be taking on the carbs.
  24. Simmy
    Good job
    XJ750DB likes this.
  25. k-moe
    That hard black substance is thread locking compound. Be sure to degrease the threads, and reapply a medium-strength thread locking compound before reassembly. Having the damper rod disconnect from the fork lower while riding may result in the sort of adventure that nobody wants.
    Also get a new bolt. Chacal should have them in stock.
  26. XJ750DB
    XJ750DB Member
    Chicago
    I definitely do not want that happening. Should I put any anti-seaze on the top cap?
    I bought the full rebuild kit from chacal so o already have replacement screws.
  27. hogfiddles
    Yaaay!!!
  28. XJ750DB
    XJ750DB Member
    Chicago
    I figured you guys could use a good laugh on my behalf. After I finished rebuilding both forks and I immediately realized something was off. I had rebuilt the wrong replacement fork and now had 2 right forks on my bike. 20180120_151424.jpg
    I rebuilt the correct one and had the same issues with the bolt being stuck in the bottom and rounding off the hex head. I drilled the head off and swapped over the parts for the other fork. After that I put air in the forks, put new handle bars on, headlight, and horns.
    I'm working on replacing the wheel bearings right now so I can take the bike off the jack stands. I also just got braided lines in for the brakes so I will be replacing those soon. Following the brakes I plan on doing the carbs and getting it running again.
    20180120_160938.jpg 20180120_161006.jpg 20180121_160307.jpg 20180121_160313.jpg
    Ketchup likes this.
  29. hogfiddles
    2 wrights made an airplane-----
    k-moe and XJ750DB like this.
  30. chacal
    You could have just run two fenders..
    hogfiddles and XJ750DB like this.
  31. k-moe
    Yes, but just a little.
    XJ750DB likes this.
  32. XJ750DB
    XJ750DB Member
    Chicago
    I just got around to putting the front wheel and brake calipers back on after replacing the seals on the front forks. When reinstalling the calipers the right fork was too close to the rotor the fit the caliper on. I had to loosen the nut on the wheel to get the caliper to fit on. The spacer is on this side of the wheel. Is there something I am missing or can this be a little tight after changing the brake pads?
    Also I have taken my carbs to church and reassembled the rack. I still need to bench sync and adjust the float levels. I am going to wait until I get a sight tube to take care of the carbs. Next I plan on checking valve clearances. I got a new valve cover gasket since there is a terrible mess all over my engine from the valve cover leaking all over. Is there anything else I should look for while I have the valve cover off?
  33. XJ750DB
    XJ750DB Member
    Chicago
  34. chacal
    XJ750DB likes this.
  35. XJ550H
    maybe get some donuts for the bolts if yours are hard
    could be the fork tubes have moved the triple tree out of alinement
    Chitwood likes this.
  36. XJ550H
    main jet washer looks cupped may cause you problems letting unwanted fuel to pass
  37. XJ750DB
    XJ750DB Member
    Chicago
    Could you elaborate on this? I am not sure what any of this means.
    Whats is the best way to check the alignment of the triple tree?
    The main jet washer was definitely cupped on all 4 carbs. I figured they were supposed to be that way. Can I pick up replacements at the hardware store?
  38. chacal
    Just gently beat them flat with a hammer. Or we have new replacements available.
    http://xjbikes.com/forums/threads/valve-cover-donut-tool-now-with-how-to-pics.40308/
  39. XJ750DB
    XJ750DB Member
    Chicago
  40. XJ750DB
    XJ750DB Member
    Chicago
    I got the bike put back together this weekend with the valve clearances in spec, a new valve gasket and donuts. I set the carb float levels and got the carbs on the bike. I was planning on doing the colortune and vacuum sync but my tach was not working.
    All of the fuses are working and I have the ATC style fuse block installed. Is there a separate fuse for the tach/flasher? The bulb in the tach is working but the tach itself is not moving at all.
    I have not wired any of my lights on the bike yet and it sounds like I am having a similar issues to this thread but I didn't find the resolution.
    http://www.xjbikes.com/forums/threa...ach-and-others-not-working.66126/#post-463726
  41. XJ550H
    gray wire goes to the coil it is the signal wire to tach
    black wire is ground
    Brown wire goes to signal fuse
    tach570k.JPG do a continuity test on the Gray wire from the coil to connector could be bad connector connection at tci or coil connector plug
    so the ground should be good because the bulb works.
    check for 12 volts at Brown wire at connector
  42. k-moe
    It is possible for the tachometer to fail. Corrosion on the component board, or broken solder joints are likely suspects.
  43. XJ750DB
    XJ750DB Member
    Chicago
    Thank you for the tips! I will try this weekend and let you know what I find.
  44. XJ750DB
    XJ750DB Member
    Chicago
    I checked continuity from the coil to gray and it passed. The voltage on the brown with bike running was 14V.
    I am testing the coil where it is mounted to the frame. Is this the correct way to check?
  45. XJ750DB
    XJ750DB Member
    Chicago
    Well I disassembled the tach to look at the circuit board and connections. Everything looked good so I hooked it back up to the bike and it started working. I must have had a bad connection somewhere that got fixed when I put it all back together. Now on to syncing and colortune.
  46. k-moe
    One thing to do is to go through all of the connectors, deox them, and apply dielectric grease to prevent future corrosion.
    XJ750DB likes this.
  47. XJ750DB
    XJ750DB Member
    Chicago
    Yes that is on the list to do when I install the lights.
    I did not have any luck syncing the carbs today. They were not drawing enough vacuum and the gauges stayed at "late valve timing or leak at intake manifold or heat riser"
    The engine had a rough idle and when i would blip the throttle the rpms would hang at 4K and very slowly come back down. I have never used this tool before and I think that may be why I am having issues. I did build the yics tool I found on another thread and I had it installed during the process. Any tips would be appreciated.
    I checked the compression on 1-4 and they read 120,90,90,90.
    The valve clearances are in spec and the spark plugs are new. 1,3, and 4 plugs looked good buy 2 looked a little lean.
  48. XJ550H
    when using vacuum Gauges you have to put a restrictor in the hose to slow down the jumping of the needle. a hose splice with the red tube from carb spray epoxied into it works well.
  49. XJ750DB
    XJ750DB Member
    Chicago
    The gauges I bought came with with bleeder screws and I was able to control the needle movement.
  50. k-moe
    Did the gauges come with restrictors to put in the vacuum lines? The screws are for adjusting the baseline of the manometer (by connecing all of the lines to one vacuum port, and setting all of the gauges to read the same).
