Wanted 1983 XJ750 Maxim Gauge Cluster
Discussion in 'For Sale, Trade/Swap, Wanted' started by Xander S, Sep 12, 2023.
  1. Xander S
    Xander S Member
    Missouri
    Looking for a 1983 XJ750J Gauge Cluster in relatively good shape, but as long as the tach and speedo are accurate, I can fix one up cosmetically as well. I hopefully want one for under $50 if possible.
  2. Toomanybikes
    Tsawwassen bc
    Your 83 shares gauge cluster with 82,83 xj650 maxim if you can't find one closer I think I have one
  3. Dan Gardner
    Minneapolis, MN
    @Xander S - Do you need the entire cluster or just a speedometer??
  4. Xander S
    Xander S Member
    Missouri
    I am unsure whether my tachometer reads correctly, since it does seem more sporadic rather than smooth, but if I could get a working speedometer, I can hear the rpms fine enough
  5. Xander S
    Xander S Member
    Missouri
    Do people just sell the speedometer part? Does it fit in the 83 Gauge cluster?
  6. Dan Gardner
    Minneapolis, MN
    Sure, sometimes
    The speedo is the same part on 1980-1983 Maxim 650s and the 83 Maxim 750. The tach is the same on the 82-83 Maxim 650s and the 83 Maxim 750 (the 80-81 Maxim 650s have a mechanical tach and wouldn't work)
    I may have a speedo from a 650 Maxim where the tach (which was mechanical anyway) got damaged. Let me take a look.
  7. Xander S
    Xander S Member
    Missouri
    Alright, thanks
  8. Xander S
    Xander S Member
    Missouri
    Any luck finding it? I assume not, but just checking.
  9. Dan Gardner
    Minneapolis, MN
    Sorry. Had to go dig it out. Here’s what I found. About 13000 and change on the clock.
  10. Dan Gardner
    Minneapolis, MN
    Found a complete set with electronic tach too!!
  11. Xander S
    Xander S Member
    Missouri
    How much you want? I don't have much since one of my cylinders stopped firing right, and I've spent $50+ to just try to diagnose the issue. This one also has a similar milage to the speedo I had on there (the broke one)
  12. Dan Gardner
    Minneapolis, MN
    Started private conversation...
    Xander S likes this.
