1983 XJ900 Lights & Indicators On Together
Discussion in 'XJ Technical Chat' started by DavidF, Mar 20, 2019.
  1. DavidF
    DavidF Member
    London, England
    OK so finishing my XJ rebuild and have an annoying problem.
    When I turn headlights on (PO or ON), both front turn signals also illuminate. The rear turn signals do not come on, but otherwise work fine ie flash when they should.
    When I operate the turn signal switch, even with the lights on, everything works as it should !
    I’ve checked the earth/ground, I’ve run a separate earth/ground from battery to 9-pin headlight block and I’ve checked the flasher relay. All to no avail.
    I’ve looked at a wiring diagram but can’t see any point where there could be an interface.
    Has anyone come across this before ?
    Cheers
  2. Ryengoth
    Ryengoth Active Member
    Wilmington, NC
    It could be the diode pack in the headlight bucket or the cancellor under the seat. Not sure but they both affect the signal power.
  3. XJ550H
    pull your cancelling unit. it is the only mystery connections in the system
  4. DavidF
    DavidF Member
    London, England
    Thanks to Ryengoth & XJ550......I’ll report back tomorrow
  5. k-moe
    If I'm remembering correctly the 900 has the front turn signals wired to be marker lamps.
    If I'm not right, that is a fairly common modification.
    I'm assuming that you mean the front signals are flashing along with the rears, but are steady-on otherwise.
  6. DavidF
    DavidF Member
    London, England
    Hi K-moe
    To clarify, if the headlights are OFF, none of the indicators are on and front & rear work correctly.
    If the headlight is ON, so are the front left & right indicators (the rear are not on). If the indicators are operated in this mode, they work correctly.
    So, your suggestion that the front indicators are marker lamps could be true......except that would be illegal here in the UK and it wouldn’t pass the statutory MOT examination. So a wiring mod may be required.
    I’m gonna check other components as per upthread before messing with wires !!
    Cheers
  7. bensalf
    bensalf Well-Known Member
    yorkshire ,england
    don't think that is true anymore, a friend has just bought a brand new honda cross runner, and his indicators are wired that way. Headlight and daytime running lights are on permanently (no switch) front indicators are on "steady" then flash when operated, you're good to go.
    stu
  8. DavidF
    DavidF Member
    London, England
    Thanks Stu, that’s interesting !
    Anyway, the upshot is that I’ve sorted it !
    In the headlight bucket is a large black Kioto block (mine has 25P stamped on it) with a 4-pin connector. I unplugged it and all seems to work as I wish.
    Thus it is an easy job to convert back if required.
    I appreciate members input in providing suggestions.
    Ryengoth likes this.
  9. k-moe
    That's the diode block. It is a component of other circuits, not just the signals.
    You will need a replacement.
  10. DavidF
    DavidF Member
    London, England
    I understand what you’re saying k-moe but everything is working fine !?
    What does this diode block do exactly ?
  11. chacal
    Coordinates/controls the action of all the various safety switches and relays in the electrical system.
  12. DavidF
    DavidF Member
    London, England
    Thank you. I think the shakedown run will demonstrate any anomalies !!
  13. k-moe
    Hopefully without becoming stranded alongside the road.
  14. DavidF
    DavidF Member
    London, England
    I’ll have it in my pocket
    XJ550H likes this.
  15. XJ550H
    and a screw driver.
    my wiring diagram shows your diode block as being used only for the oil light test and oil level. blinkers should not be affected.
  16. k-moe
    In which case there is probably a bare wire somewhere in the harness, or a "clever" PO rewiring.
    IMO this is worth investigating and fixing correctly. It's a sign of potential trouble lurking beneath.
  17. DavidF
    DavidF Member
    London, England
    Hi XJ550H
    Is it possible to scan & post that wiring diagram as I’ve not been able to find the correct one on the Net.
    To be sure, my diode Block is in the headlamp bucket and has 4 wires : Black, Brown, Light Blue and Light Blue/White.
    The oil lamp appears to work fine !
    You do realise this is the 83 XJ750E-II.....although in essence a 750 motor in a 900 frame, there are elements that make it a mule and neither manual (750 or 900) indicates what is actually on my bike !!!
  18. k-moe
    Since you're working on your E-II you should have put that in the thread title.
    We've all been working on the assumption that you were working on an XJ900.
    I think @hogfiddles has a XJ750-EII service manual, but it's not in English.
  19. DavidF
    DavidF Member
    London, England
    Sorry everyone, you’re dead right, it would help ?
    I’d love a copy of a service manual, Google is great at translating most.....no doubt Japanese ?!
  20. XJ550H
    I only have xj900 manuals .
    this is the diode block I have in diagrams
    l/w goes to starter button
    B/r goes to oil light and the second B/r wire goes to the solenoid.
    this configuration is for oil light and test circuit
    these 2 diode blocks are from 650G and 650H as you can see there are more diodes and more
    test/function circuits. head light and sidestand shift
  21. DavidF
    DavidF Member
    London, England
    I have both 750 & 900 manuals and, as with other wiring diagrams I’ve researched on the Net, these all seem to show diodes under the seat.
    Mine in question is behind the headlight and has 4 wires to it.
    Since unplugging it, I’ve not yet noticed anything not operating as expected except that the front indicator/marker lights are not now illuminated (which is what I wanted to achieve).
    Perhaps a shakedown run on the road might throw up issues but, for now, I’m happy.
    Thanks to everyone for their help to date, I’ll report back next week !!
    It’ll be MOTd and up for sale soon ! Photo to follow in its present state......
  22. DavidF
    DavidF Member
    London, England
  23. k-moe
    All of the XJ models have the diode blocks located in the headlight bucket. Unfortuantely the diode blocks aren't all alike.
