1983 XV750 Carburetor
Discussion in 'Other Motorcycles' started by Tyson M., Jan 20, 2020.
  1. Tyson M.
    Tyson M. New Member
    Wisconsin
    I have a 1983 XV750 midnight edition
    Are the carburetors compatible between 82 and 83? Planning on just buying a rebuilt one.
  2. Door dude
    Door dude Active Member
    Mountain Home Arkansas
    Did you mean xj 750 ? I have a 82 xj 750 maxim and a 83 xj 750 midnight maxim. Put the 2 carbs side by side they look to be the same. It"s been a while but i believe that all of the jets are the same, so i would say yes. Someone here on the forum might say different.
  3. Tyson M.
    Tyson M. New Member
    Wisconsin
    No, the virago
  4. Timbox
  5. Tyson M.
    Tyson M. New Member
    Wisconsin
    Thanks timbox, you're the man!
  6. Jetfixer
    I had an 82 Virago , yes carbs were the same from 81-83 here is a tip the K&L overhaul kits came with 122 jets these are fine for 84-87. However the early carbs require 124 front and 134 rear cylinder what ever you do keep the airbox and filter....because the starter suck and you want easy starting . I made the mistake of using the 122 main the rear pipe would glow orange , I found out about the jets by a small blurb in the manual, switched these out and it fixed this problem. Going up one size on the pilot jet help idle and starting .
  7. Timbox
    Lots of V twins run a richer rear head because the air hitting the head is already warm. I had a Suzuki Madura 1400 and even the rear carb was different than the front one.
  8. Tyson M.
    Tyson M. New Member
    Wisconsin
    Guy says needles were shimmed for better performance lol. I'll ask about that to clear it up
