1984 XJ600 Swingarm angle - Help please.
Discussion in 'XJ Modifications' started by Rich N, Sep 25, 2020.
  1. Rich N
    Rich N New Member
    Hello everyone.
    I have a 1984 XJ600, which I am rebuilding. The cross-member for the rear shock was twisted.
    I cut it out and purchased an aftermarket shock absorber. I believe I have the correct position for the new cross-member, but I would like to double-check. Could someone please measure the rear swingarm angle - the angle of the swingarm to ground level? Thank you all in advance. Cheers
  2. bensalf
    bensalf Well-Known Member
    yorkshire ,england
    do you want the angle with the rear wheel off the ground , or with the weight of the bike on the wheels?
  3. bigfitz52
    Do the 600s weigh that much? Or is their suspension uber-cushy? When I pop my 550 off the stand, the weight of the bike alone doesn't compress the rear suspension.
  4. Franz
    Ground levels won't be the same. Might be better measuring them in garages with level concrete floors. Could an angle be taken from the arm to the frame for comparison with other bikes?
  5. bigfitz52
    The only dimension you truly need is the distance from the swingarm pivot to the ground. The length of the arm from pivot to axle is known or easily measurable, as is the distance from the rear axle to the ground (half the diameter of the rear wheel/tire assembly.) You're only missing one leg of the triangle...
  6. 50gary
    50gary Active Member
    Saginaw, Mi. USA
    It should have some sag, likely the springs are too stiff or the preload is set too high.
    Cheers, 50gary
  7. bigfitz52
    Nope. The 550 Seca only weighs ~425lb wet. No sag til I sit down and add a couple hundred pounds.
  8. bensalf
    yorkshire ,england
    IMG_0717.JPG ok, so i took some measurements today ,after i had the bike out to clean it after a wet and windy camping weekend.
    hope they are what you're after
    so, on a "reasonably" level garage floor.
    the spirit level is "level", the angle guage is pointing from the rear axle nut to the centre of the swing arm spindle , and the degree angle is 10 degrees .this is with the bike on centre stand ,with rear tyre just touching the floor
    with the bike on its wheels, and as near verticle as i dare, the angle is 3 degrees
    i hope this helps.
    stu
    Franz likes this.
  9. bensalf
    yorkshire ,england
  10. bensalf
    yorkshire ,england
    don't you just love it when that happens,
    this is 7 days ago ,and no response, took me well above an hour to level bike up and measure angles for him
    :mad::(
    but then maybe there's a good reason?
    o_O
    stu
